查看: 1134|回复: 12
{已出}出一台ca的KS-LE-1
发表于 2024-5-15 19:51:13 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
标准配置如下
CPU:Intel Xeon E3-1245v2 - 4c/8t - 3.4 GHz/3.8 GHz
RAM:32 GB 1333 MHz
Data disks:2×800 GB SSD SATA
端口 上100 Mbps /  下1000 Mbps
命盘150出,次月1日续费,每月续费14.99欧元。请自备ovh.ie账号,有意PM
 楼主| 发表于 2024-5-15 19:54:09 | 只看该作者
  1. [root@ns502777 ~]# curl -Lso- bench.sh | bash
  2. -------------------- A Bench.sh Script By Teddysun -------------------
  3. Version            : v2023-10-15
  4. Usage              : wget -qO- bench.sh | bash
  5. ----------------------------------------------------------------------
  6. CPU Model          : Intel(R) Xeon(R) CPU E3-1245 V2 [url=home.php?mod=space&uid=175]@[/url] 3.40GHz
  7. CPU Cores          : 8 @ 3600.256 MHz
  8. CPU Cache          : 8192 KB
  9. AES-NI             : ✓ Enabled
  10. VM-x/AMD-V         : ✓ Enabled
  11. Total Disk         : 894.2 GB (2.1 GB Used)
  12. Total Mem          : 31.2 GB (433.2 MB Used)
  13. Total Swap         : 1024.0 MB (0 Used)
  14. System uptime      : 78 days, 2 hour 42 min
  15. Load average       : 0.00, 0.08, 0.12
  16. OS                 : CentOS Linux release 7.9.2009 (Core)
  17. Arch               : x86_64 (64 Bit)
  18. Kernel             : 3.10.0-1160.108.1.el7.x86_64
  19. TCP CC             : cubic
  20. Virtualization     : Dedicated
  21. IPv4/IPv6          : ✓ Online / ✗ Offline
  22. Organization       : AS16276 OVH SAS
  23. Location           : Beauharnois / CA
  24. Region             : Quebec
  25. ----------------------------------------------------------------------
  26. I/O Speed(1st run) : 436 MB/s
  27. I/O Speed(2nd run) : 434 MB/s
  28. I/O Speed(3rd run) : 432 MB/s
  29. I/O Speed(average) : 434.0 MB/s
  30. ----------------------------------------------------------------------
  31. Node Name        Upload Speed      Download Speed      Latency
  32. Speedtest.net    80.98 Mbps        942.08 Mbps         1.27 ms
  33. Los Angeles, US  27.09 Mbps        597.55 Mbps         68.25 ms
  34. Dallas, US       42.18 Mbps        510.35 Mbps         37.92 ms
  35. Montreal, CA     93.55 Mbps        752.06 Mbps         4.23 ms
  36. Amsterdam, NL    21.39 Mbps        330.73 Mbps         84.27 ms
  37. Shanghai, CN     11.27 Mbps        274.86 Mbps         257.36 ms
  38. Chongqing, CN    0.10 Mbps         0.22 Mbps           271.62 ms
  39. Hongkong, CN     13.87 Mbps        110.25 Mbps         226.26 ms
  40. Mumbai, IN       13.30 Mbps        321.94 Mbps         217.52 ms
  41. Singapore, SG    10.05 Mbps        19.67 Mbps          260.50 ms
  42. Tokyo, JP        6.30 Mbps         347.60 Mbps         169.59 ms
  43. ----------------------------------------------------------------------
  44. Finished in        : 5 min 26 sec
  45. Timestamp          : 2024-05-15 11:59:08 UTC
  46. ----------------------------------------------------------------------
发表于 2024-5-15 20:13:38 | 只看该作者
这个是18欧那款吗
发表于 2024-5-15 20:14:58 | 只看该作者
账号单出吗
 楼主| 发表于 2024-5-15 20:19:46 | 只看该作者
fuu 发表于 2024-5-15 20:13
这个是18欧那款吗
不好意思,忘记贴费用了。每月14.99欧元
 楼主| 发表于 2024-5-15 20:20:56 | 只看该作者
不出哦。。还等以后收ks1加拿大
发表于 2024-5-15 20:22:33 | 只看该作者
我的不是ie账号是ca账号,是18美金,好像差不多吧
 楼主| 发表于 2024-5-15 20:25:51 | 只看该作者
18美元 约等于 130人民币
15欧元 约等于 117人民币
差不多
发表于 2024-5-15 20:29:16 来自手机 | 只看该作者
平僧洗头用飘柔 发表于 2024-5-15 20:20
不出哦。。还等以后收ks1加拿大
ks1没有加拿大 不用等了。
发表于 2024-5-15 20:29:50 | 只看该作者
平僧洗头用飘柔 发表于 2024-5-15 20:25
18美元 约等于 130人民币
15欧元 约等于 117人民币
看了下配置不一样
我的cpu是E5 1620  4c8t  RAM  32G  disk 3.6T
GMT+8, 2025-12-25 08:31 , Processed in 0.084452 second(s), 10 queries , Gzip On, MemCache On.
