查看: 1085|回复: 2
hosteons 后续
发表于 2024-5-11 21:21:50 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
上一贴:
https://loc.qiche.eu.org/forum.php?mo ... ;extra=#pid15531050
根据与他们的约定,他们恢复vps,我删掉视频。
 楼主| 发表于 2024-5-11 21:27:00 | 只看该作者
Hi
You are free to post all the videos and reviews you want, as there is no way are going to allow abuse on our network, in fact it will help keep spammers away from our network
But just giving you benefit of doubt I'm reactivating all your VPS, but if we get more complains I'll have to terminate all your VPS
I would suggest that the first thing you do is reinstall all your VPS because if you are not spamming then your VPS are definitely infected or hacked and being used either to attack others or for spamming
All your VPS should be online in next few minutes
I'm reactivating them, but I'll shutdown so that when you are online you reinstall them and then start them else by the time you try to use them it's possible that they start spamming again which won't be tolerated
These are UNMANAGED VPS, where the client is responsible to make sure your VPS are not being used for spamming
Hetrixtools is not wrong, HetrixTools just checks if the IP is getting new blacklists and it even shares details of the RBL where the IP is getting blacklisted
IP don't get blacklisted for no reason
Regarding the blacklist in December 2023 as you can see we terminated the previous user so the blacklists were all removed before the IP was allocated to you.
Talks
Kapil Jain
发表于 2024-5-11 21:28:44 | 只看该作者
老板名字是印度人名字
另外这个错误hz也会犯,乐
GMT+8, 2026-4-17 08:06 , Processed in 0.063220 second(s), 9 queries , Gzip On, MemCache On.
