查看: 1116|回复: 6
晒下unixbench
发表于 2012-6-15 13:19:13 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
虽然Showfom说这处理器性能不好。。。嗯不过我还是来晒下。。
这批完了再说。。
  1. ========================================================================
  2.    BYTE UNIX Benchmarks (Version 5.1.2)
  3.    System: xentest.xen.****.net: GNU/Linux
  4.    OS: GNU/Linux -- 2.6.18-308.8.2.el5xen -- #1 SMP Tue Jun 12 10:39:28 EDT 2012
  5.    Machine: x86_64 (x86_64)
  6.    Language: en_US.utf8 (charmap="UTF-8", collate="UTF-8")
  7.    CPU 0: Intel(R) Xeon(R) CPU L5420 @ 2.50GHz (6237.8 bogomips)
  8.           Hyper-Threading, x86-64, MMX, Physical Address Ext, SYSENTER/SYSEXIT, SYSCALL/SYSRET
  9.    CPU 1: Intel(R) Xeon(R) CPU L5420 @ 2.50GHz (6237.8 bogomips)
  10.           Hyper-Threading, x86-64, MMX, Physical Address Ext, SYSENTER/SYSEXIT, SYSCALL/SYSRET
  11.    CPU 2: Intel(R) Xeon(R) CPU L5420 @ 2.50GHz (6237.8 bogomips)
  12.           Hyper-Threading, x86-64, MMX, Physical Address Ext, SYSENTER/SYSEXIT, SYSCALL/SYSRET
  13.    CPU 3: Intel(R) Xeon(R) CPU L5420 @ 2.50GHz (6237.8 bogomips)
  14.           Hyper-Threading, x86-64, MMX, Physical Address Ext, SYSENTER/SYSEXIT, SYSCALL/SYSRET
  15.    12:21:45 up 47 min,  3 users,  load average: 0.07, 0.11, 0.77; runlevel 3
  16. ------------------------------------------------------------------------
  17. Benchmark Run: Fri Jun 15 2012 12:21:45 - 12:49:58
  18. 4 CPUs in system; running 1 parallel copy of tests
  19. Dhrystone 2 using register variables       13827103.3 lps   (10.0 s, 7 samples)
  20. Double-Precision Whetstone                     2869.2 MWIPS (9.9 s, 7 samples)
  21. Execl Throughput                               1138.4 lps   (29.5 s, 2 samples)
  22. File Copy 1024 bufsize 2000 maxblocks        256552.9 KBps  (30.0 s, 2 samples)
  23. File Copy 256 bufsize 500 maxblocks           64242.9 KBps  (30.0 s, 2 samples)
  24. File Copy 4096 bufsize 8000 maxblocks        571492.0 KBps  (30.0 s, 2 samples)
  25. Pipe Throughput                              373347.4 lps   (10.0 s, 7 samples)
  26. Pipe-based Context Switching                  94371.0 lps   (10.0 s, 7 samples)
  27. Process Creation                               3041.0 lps   (30.0 s, 2 samples)
  28. Shell Scripts (1 concurrent)                   3216.0 lpm   (60.0 s, 2 samples)
  29. Shell Scripts (8 concurrent)                    919.3 lpm   (60.0 s, 2 samples)
  30. System Call Overhead                         252903.6 lps   (10.0 s, 7 samples)
  31. System Benchmarks Index Values               BASELINE       RESULT    INDEX
  32. Dhrystone 2 using register variables         116700.0   13827103.3   1184.8
  33. Double-Precision Whetstone                       55.0       2869.2    521.7
  34. Execl Throughput                                 43.0       1138.4    264.7
  35. File Copy 1024 bufsize 2000 maxblocks          3960.0     256552.9    647.9
  36. File Copy 256 bufsize 500 maxblocks            1655.0      64242.9    388.2
  37. File Copy 4096 bufsize 8000 maxblocks          5800.0     571492.0    985.3
  38. Pipe Throughput                               12440.0     373347.4    300.1
  39. Pipe-based Context Switching                   4000.0      94371.0    235.9
  40. Process Creation                                126.0       3041.0    241.3
  41. Shell Scripts (1 concurrent)                     42.4       3216.0    758.5
  42. Shell Scripts (8 concurrent)                      6.0        919.3   1532.2
  43. System Call Overhead                          15000.0     252903.6    168.6
  44.        ========
  45. System Benchmarks Index Score                                         476.1
  46. ------------------------------------------------------------------------
  47. Benchmark Run: Fri Jun 15 2012 12:49:58 - 13:18:23
  48. 4 CPUs in system; running 4 parallel copies of tests
  49. Dhrystone 2 using register variables       50412885.2 lps   (10.0 s, 7 samples)
  50. Double-Precision Whetstone                    10332.8 MWIPS (9.7 s, 7 samples)
  51. Execl Throughput                               4111.7 lps   (29.9 s, 2 samples)
  52. File Copy 1024 bufsize 2000 maxblocks        107947.4 KBps  (30.0 s, 2 samples)
  53. File Copy 256 bufsize 500 maxblocks           28622.2 KBps  (30.0 s, 2 samples)
  54. File Copy 4096 bufsize 8000 maxblocks        323169.8 KBps  (30.0 s, 2 samples)
  55. Pipe Throughput                             1322771.9 lps   (10.0 s, 7 samples)
  56. Pipe-based Context Switching                 354820.1 lps   (10.0 s, 7 samples)
  57. Process Creation                               9793.4 lps   (30.1 s, 2 samples)
  58. Shell Scripts (1 concurrent)                   8182.1 lpm   (60.0 s, 2 samples)
  59. Shell Scripts (8 concurrent)                   1265.2 lpm   (60.0 s, 2 samples)
  60. System Call Overhead                         963428.2 lps   (10.0 s, 7 samples)
  61. System Benchmarks Index Values               BASELINE       RESULT    INDEX
  62. Dhrystone 2 using register variables         116700.0   50412885.2   4319.9
  63. Double-Precision Whetstone                       55.0      10332.8   1878.7
  64. Execl Throughput                                 43.0       4111.7    956.2
  65. File Copy 1024 bufsize 2000 maxblocks          3960.0     107947.4    272.6
  66. File Copy 256 bufsize 500 maxblocks            1655.0      28622.2    172.9
  67. File Copy 4096 bufsize 8000 maxblocks          5800.0     323169.8    557.2
  68. Pipe Throughput                               12440.0    1322771.9   1063.3
  69. Pipe-based Context Switching                   4000.0     354820.1    887.1
  70. Process Creation                                126.0       9793.4    777.3
  71. Shell Scripts (1 concurrent)                     42.4       8182.1   1929.8
  72. Shell Scripts (8 concurrent)                      6.0       1265.2   2108.7
  73. System Call Overhead                          15000.0     963428.2    642.3
  74.        ========
  75. System Benchmarks Index Score                                         924.7
发表于 2012-6-15 13:20:35 | 只看该作者
看不懂路过
发表于 2012-6-15 13:22:50 | 只看该作者
一般般
发表于 2012-6-15 13:27:31 | 只看该作者
U不行啊。。。缩水版
发表于 2012-6-15 13:33:17 | 只看该作者
不太好
发表于 2012-6-15 13:36:13 | 只看该作者
这分不高
 楼主| 发表于 2012-6-15 13:37:10 | 只看该作者
_____________Cc 发表于 2012-6-15 13:36
这分不高
CPU有点老,硬盘也是SAN。。。
GMT+8, 2026-5-1 02:39 , Processed in 0.067436 second(s), 13 queries , Gzip On, MemCache On.
