查看: 2922|回复: 6
[Windows VPS] 申请过WebNX机房的IP进来,加分
发表于 2012-6-13 21:05:22 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
To expand your block we need a list of all the current IP's on that server, who
is using them, and why they are being used.  Only 80% has to pass justification
to expand your block but we need to know what your doing with them.  Without
this information we can't give out more IP's.  Also something you need to be
aware of, SEO reasons for ip usage will *not* be accepted.  If you want a single
IP for a single website the only acceptable ARIN justification that we know of
is SSL certificates.  If you have a site on a single IP without an SSL
certificate, get one before you submit your justification.  Otherwise it will be
rejected.  Once you have your currant usage justified we also need to know what
your intending to use the additional ips for, this does not need to be detailed,
just a general explanation.
Here is an example of how we would like your current usage to be justified.
IP -- Name of person/website -- Technical reason an IP is needed
192.168.1.2 -- server01.example.com -- Physical Server
192.168.1.3 -- hostnameofavps.com -- VPS server
192.168.1.4 -- ns1.example.com -- authoritative nameserver
192.168.1.5 -- secure.example.com -- SSL Cert
我按照了他们的格式填了,website 要填什么?
发表于 2012-6-13 21:06:06 | 只看该作者
  出租域名。。专门指向 。好申请ip。。。
按天付费。
写你的没个IP的域名。
参与人数 1威望 +4 收起 理由
easyearn + 4 赞一个!
 楼主| 发表于 2012-6-13 21:18:55 | 只看该作者
顶下
发表于 2012-6-13 21:22:07 | 只看该作者
出租域名。。专门指向。好申请。。。按天付费。写你的没个的域名。
发表于 2012-6-13 21:22:50 | 只看该作者
发表于 2012-6-13 21:28:53 | 只看该作者
我都是用自己域名绑定的
参与人数 2威望 +20 收起 理由
wyq1993 + 15 很给力!
easyearn + 5 绑定那个ip?
 楼主| 发表于 2012-6-13 21:30:18 | 只看该作者
小西西 发表于 2012-6-13 21:28
我都是用自己域名绑定的
绑定那个ip?
GMT+8, 2026-4-17 01:30 , Processed in 0.202353 second(s), 14 queries , Gzip On, MemCache On.
