查看: 1726|回复: 9
大佬们帮忙看看这个接口怎么弄?
发表于 2024-4-6 17:13:18 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
post:
https://api.qst8.cn/api/front/upload/img
请求标头:authority:
api.qst8.cn
:method:
POST
:path:
:scheme:
https
Accept:
Accept-Encoding:
gzip, deflate, br, zstd
Accept-Language:
zh-CN,zh;q=0.9
Branchid:
1002
Cache-Control:
no-cache
Channel:
Content-Length:
2066189
Content-Type:
multipart/form-data; boundary=----WebKitFormBoundarywIB4fkxKvaM69fwp
Method:
POST
Origin:
https://qst8.cn
Pragma:
no-cache
Referer:
https://qst8.cn/
Sec-Ch-Ua:
"Google Chrome";v="123", "Not:A-Brand";v="8", "Chromium";v="123"
Sec-Ch-Ua-Mobile:
?0
Sec-Ch-Ua-Platform:
"Windows"
Sec-Fetch-Dest:
empty
Sec-Fetch-Mode:
cors
Sec-Fetch-Site:
same-site
Sign:
bc167104aa367377609e9b64da7d396b
Source:
h5
Tenantid:
3
Timestamp:
1712394675371
Token:
531cd244-5f7e-4fd7-5532-1f539052d71a
User-Agent:
Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/123.0.0.0 Safari/537.36
载荷file: (二进制)
file:
返回的数据格式{
    "code": 200,
    "message": "操作成功",
    "data": "https://img.qst8.cn/custom/pic/xxx.png"
请求标头里的sign值和token值是怎么生成的,怎么对这个接口进行正确的post?
希望大佬们能教一下,谢谢了。
发表于 2024-4-6 17:28:17 | 只看该作者
看起来就是个multipart/form-data类型的上传表单,sign和token哪里来的要去分析前台代码
 楼主| 发表于 2024-4-6 17:30:22 | 只看该作者
个人支付宝接口 发表于 2024-4-6 17:28
看起来就是个multipart/form-data类型的上传表单,sign和token哪里来的要去分析前台代码 ...
老哥能麻烦给个例子吗,我这一直测试上传失败,不知道为什么?
发表于 2024-4-6 17:40:33 | 只看该作者
这个上传入口在哪里
发表于 2024-4-6 17:41:49 | 只看该作者
我,秦始皇,打钱
发表于 2024-4-6 18:47:48 | 只看该作者
[ 本帖最后由 SirW 于 2024-4-6 18:50 编辑 ]\n\n随便写了下,拿去用吧。做图床用的?
[code]<?php
$p = "./response.png";
$pic = upload($p);
echo $pic;
function getHeaders($type, $timestamp, $token = ""){
        $json = array(
                "method" => $type ,
                "timestamp" => $timestamp,
                "source" => "h5",
                "key" => "1F2F58F2220096D7E209224F826B6D67"
        $j = json_encode($json);
        $sign = md5(strtoupper($j));
        $h = array(
                "accept: application/json, text/javascript, */*; q=0.01",
                "Channel:",
                "Method:GET",
                "Referer:",
                "Branchid:1002",
                "Sign:".$sign,
                "Source:h5",
                "Tenantid:3",
                "Timestamp:".$timestamp,
                "User-Agent:Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/123.0.0.0 Safari/537.36",
        if($token != ""){
                $h[] = "Token:".$token;
        return $h;
function upload($filePath){
        $url = "/api/front/user/h5Login";//带上域名,回帖发不了
        $type = "GET";
        $timestamp = (string)(time()*1000+rand(100,999));
        $randToken = uuid();
        $headers = getHeaders($type, $timestamp, $randToken);
        //register Token
        $content = POST($url, "", $headers);
        $d = json_decode($content, true);
        $token = $d["data"]["token"];
        //upload
        $type2 = "POST";
        $url2 = "/api/front/upload/img";//带上域名,回帖发不了
        $headers2 = getHeaders($type2, $timestamp, $token);
        $headers2[] = "Content-Type:multipart/form-data";
        $postData = array(
                'file' => new CURLFile($filePath),
        $c = POST($url2, $postData, $headers2);
        $d = json_decode($c,true);
        return $d["data"];
function POST($url,$post,$headers){
        $c = curl_init();
        curl_setopt($c, CURLOPT_URL, $url);
        curl_setopt($c, CURLOPT_HEADER, 0);
        curl_setopt($c, CURLOPT_NOBODY, 0);
        if($post) {
            curl_setopt($c, CURLOPT_POST, 2);
            curl_setopt($c, CURLOPT_POSTFIELDS, $post);
        if(stripos($url, 'https://') > -1){
            curl_setopt($c, CURLOPT_SSL_VERIFYPEER, FALSE);
            curl_setopt($c, CURLOPT_SSL_VERIFYHOST, FALSE);
        curl_setopt($c, CURLOPT_RETURNTRANSFER, true);
        curl_setopt($c, CURLOPT_CONNECTTIMEOUT, 12);
        curl_setopt($c, CURLOPT_TIMEOUT,12);
        curl_setopt($c, CURLOPT_ENCODING ,'gzip, deflate');
        if(!$ip) {
            $ip_long = array(
                    array('607649792', '608174079'), //36.56.0.0-36.63.255.255
                    array('1038614528', '1039007743'), //61.232.0.0-61.237.255.255
                    array('1783627776', '1784676351'), //106.80.0.0-106.95.255.255
                    array('2035023872', '2035154943'), //121.76.0.0-121.77.255.255
                    array('2078801920', '2079064063'), //123.232.0.0-123.235.255.255
                    array('-1950089216', '-1948778497'), //139.196.0.0-139.215.255.255
                    array('-1425539072', '-1425014785'), //171.8.0.0-171.15.255.255
                    array('-1236271104', '-1235419137'), //182.80.0.0-182.92.255.255
                    array('-770113536', '-768606209'), //210.25.0.0-210.47.255.255
                    array('-569376768', '-564133889'), //222.16.0.0-222.95.255.255
            $rand_key = mt_rand(0, 9);
            $ip= long2ip(mt_rand($ip_long[$rand_key][0], $ip_long[$rand_key][1]));
        $headers[] = 'X-Forwarded-For:'.$ip;
        $headers[] = 'x-real-ip:'.$ip;
        $headers[] = 'CLIENT_IP:'.$ip;
        curl_setopt($c, CURLOPT_HTTPHEADER, $headers);
        // curl_setopt($c, CURLOPT_FOLLOWLOCATION, 1);
        $content = curl_exec($c);
        curl_close($c);
        return $content;
function uuid() {
    $data = openssl_random_pseudo_bytes(16);
    assert(strlen($data) == 16);
    // Set version to 0100
    $data[6] = chr(ord($data[6]) & 0x0f | 0x40);
    // Set bits 6-7 to 10
    $data[8] = chr(ord($data[8]) & 0x3f | 0x80);
    return vsprintf('%s%s-%s-%s-%s-%s%s%s', str_split(bin2hex($data), 4));
} [/code]
 楼主| 发表于 2024-4-6 19:27:56 | 只看该作者
大佬,这段代码不太理解为什么这么写,不会用啊。
发表于 2024-4-6 21:58:44 来自手机 | 只看该作者
youhei 发表于 2024-4-6 17:40
这个上传入口在哪里
平台投诉里面就有
发表于 2024-4-7 12:07:48 | 只看该作者
是php代码
GMT+8, 2026-4-18 23:18 , Processed in 0.067023 second(s), 11 queries , Gzip On, MemCache On.
