查看: 1304|回复: 6
[美国VPS] 各位MJJ们,OVH法国这个速度正常嘛
发表于 2024-4-2 07:19:17 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
  3. #                     v2024-03-05                    #
  6. Mon Apr  1 23:10:28 UTC 2024
  7. Basic System Information:
  9. Uptime     : 0 days, 2 hours, 14 minutes
  10. Processor  : Intel(R) Xeon(R) CPU E3-1245 V2 [url=home.php?mod=space&uid=175]@[/url] 3.40GHz
  11. CPU cores  : 8 @ 2435.203 MHz
  12. AES-NI     : ✔ Enabled
  13. VM-x/AMD-V : ✔ Enabled
  14. RAM        : 31.2 GiB
  15. Swap       : 1024.0 MiB
  16. Disk       : 438.4 GiB
  17. Distro     : Debian GNU/Linux 12 (bookworm)
  18. Kernel     : 6.1.0-18-amd64
  19. VM Type    : NONE
  20. IPv4/IPv6  : ✔ Online / ✔ Online
  21. IPv6 Network Information:
  23. ISP        : OVH SAS
  24. ASN        : AS16276 OVH SAS
  25. Host       : OVH SAS
  26. Location   : Lille, Hauts-de-France (HDF)
  27. Country    : France
  28. fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/md3):
  32. Read       | 215.69 MB/s  (53.9k) | 258.93 MB/s   (4.0k)
  33. Write      | 216.26 MB/s  (54.0k) | 260.29 MB/s   (4.0k)
  34. Total      | 431.95 MB/s (107.9k) | 519.22 MB/s   (8.1k)
  38. Read       | 256.93 MB/s    (501) | 242.91 MB/s    (237)
  39. Write      | 270.58 MB/s    (528) | 259.09 MB/s    (253)
  40. Total      | 527.51 MB/s   (1.0k) | 502.01 MB/s    (490)
  45. Clouvider       | London, UK (10G)          | 95.9 Mbits/sec  | 524 Mbits/sec   | 3.77 ms
  46. Eranium         | Amsterdam, NL (10G)       | 95.7 Mbits/sec  | 938 Mbits/sec   | 6.85 ms
  47. Telia           | Helsinki, FI (10G)        | 60.7 Mbits/sec  | 161 Mbits/sec   | 35.8 ms
  48. Uztelecom       | Tashkent, UZ (10G)        | 30.9 Mbits/sec  | 151 Mbits/sec   | 98.6 ms
  49. Leaseweb        | Singapore, SG (10G)       | 12.6 Mbits/sec  | 316 Mbits/sec   | --
  50. Clouvider       | Los Angeles, CA, US (10G) | 20.3 Mbits/sec  | 166 Mbits/sec   | 133 ms
  51. Leaseweb        | NYC, NY, US (10G)         | 38.1 Mbits/sec  | 366 Mbits/sec   | 76.0 ms
  52. Edgoo           | Sao Paulo, BR (1G)        | 11.9 Mbits/sec  | 15.2 Mbits/sec  | 144 ms
  53. iperf3 Network Speed Tests (IPv6):
  54. ---------------------------------
  55. Provider        | Location (Link)           | Send Speed      | Recv Speed      | Ping
  56. -----           | -----                     | ----            | ----            | ----
  57. Clouvider       | London, UK (10G)          | 94.5 Mbits/sec  | 527 Mbits/sec   | 3.77 ms
  58. Eranium         | Amsterdam, NL (10G)       | 93.8 Mbits/sec  | 927 Mbits/sec   | 7.05 ms
  59. Uztelecom       | Tashkent, UZ (10G)        | 28.7 Mbits/sec  | 319 Mbits/sec   | 98.5 ms
  60. Leaseweb        | Singapore, SG (10G)       | 10.9 Mbits/sec  | 290 Mbits/sec   | 237 ms
  61. Clouvider       | Los Angeles, CA, US (10G) | 20.3 Mbits/sec  | busy            | 133 ms
  62. Leaseweb        | NYC, NY, US (10G)         | 34.2 Mbits/sec  | 390 Mbits/sec   | 76.0 ms
  63. Edgoo           | Sao Paulo, BR (1G)        | 9.77 Mbits/sec  | 166 Mbits/sec   | 144 ms
 楼主| 发表于 2024-4-2 07:49:08 | 只看该作者
补一个bench.sh
  1. -------------------- A Bench.sh Script By Teddysun -------------------
  2. Version            : v2023-10-15
  3. Usage              : wget -qO- bench.sh | bash
  4. ----------------------------------------------------------------------
  5. CPU Model          : Intel(R) Xeon(R) CPU E3-1245 V2 [url=home.php?mod=space&uid=175]@[/url] 3.40GHz
  6. CPU Cores          : 8 @ 2471.878 MHz
  7. CPU Cache          : 8192 KB
  8. AES-NI             : ✓ Enabled
  9. VM-x/AMD-V         : ✓ Enabled
  10. Total Disk         : 439.4 GB (1.2 GB Used)
  11. Total Mem          : 31.3 GB (616.4 MB Used)
  12. Total Swap         : 1024.0 MB (0 Used)
  13. System uptime      : 0 days, 2 hour 33 min
  14. Load average       : 0.42, 1.65, 1.17
  15. OS                 : Debian GNU/Linux 12
  16. Arch               : x86_64 (64 Bit)
  17. Kernel             : 6.1.0-18-amd64
  18. TCP CC             :
  19. Virtualization     : Dedicated
  20. IPv4/IPv6          : ✓ Online / ✓ Online
  21. Organization       : AS16276 OVH SAS
  22. Location           : Calais / FR
  23. Region             : Hauts-de-France
  24. ----------------------------------------------------------------------
  25. I/O Speed(1st run) : 403 MB/s
  26. I/O Speed(2nd run) : 404 MB/s
  27. I/O Speed(3rd run) : 403 MB/s
  28. I/O Speed(average) : 403.3 MB/s
  29. ----------------------------------------------------------------------
  30. Node Name        Upload Speed      Download Speed      Latency
  31. Speedtest.net    29.60 Mbps        90.06 Mbps          0.92 ms
  32. Los Angeles, US  17.73 Mbps        323.96 Mbps         136.18 ms
  33. Dallas, US       22.04 Mbps        283.33 Mbps         108.57 ms
  34. Montreal, CA     31.21 Mbps        740.44 Mbps         86.39 ms
  35. Amsterdam, NL    87.41 Mbps        545.24 Mbps         10.25 ms
  36. Shanghai, CN     11.82 Mbps        332.08 Mbps         193.84 ms
  37. Hongkong, CN     12.56 Mbps        453.62 Mbps         247.25 ms
  38. Mumbai, IN       16.62 Mbps        267.47 Mbps         119.98 ms
  39. Singapore, SG    12.27 Mbps        213.24 Mbps         244.98 ms
  40. Tokyo, JP        11.17 Mbps        208.25 Mbps         227.87 ms
  41. ----------------------------------------------------------------------
  42. Finished in        : 5 min 19 sec
  43. Timestamp          : 2024-04-01 23:35:23 UTC
  44. ----------------------------------------------------------------------
发表于 2024-4-2 07:57:18 来自手机 | 只看该作者
不正常,除了cn百兆应该基本能跑满
发表于 2024-4-2 08:13:54 来自手机 | 只看该作者
你可以永远相信OVH新加坡
发表于 2024-4-2 08:20:39 | 只看该作者
这个没太**意义,具体还是要看真正得访问体验,访问体验贼拉跨
 楼主| 发表于 2024-4-2 08:35:35 | 只看该作者
这个都这样了,访问体验更不用说了
 楼主| 发表于 2024-4-2 08:40:21 | 只看该作者
ningchaitong1 发表于 2024-4-2 07:57
不正常,除了cn百兆应该基本能跑满
我感觉也是,倒是不追求国内速度
GMT+8, 2025-12-31 23:40 , Processed in 0.210370 second(s), 10 queries , Gzip On, MemCache On.
