查看: 4313|回复: 16
比buyvm还便宜的vps,性能和buyvm一样,超低价
发表于 2012-6-7 11:02:29 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
性能,实测,buyvm 年付15刀的 新装lnmp 新装wordpress 压力测试
60秒响应了217次,
这个VPS响应了204
fastvps.co
15GB Disk Space
1TB Bandwidth
1 Core CPU
128MB RAM
burst 256MB
数据中心在芝加哥ubi 访问稍慢 但是稳定
http://108.62.103.61/p.php
2013.5.1到期
我买的时候付款了11.02 USD  7折就是7.7刀    算45
你没看错 45买到一年和buyvm性能相当的vps 划算到爆
  1. [root@fastvps ~]# dd if=/dev/zero of=test bs=64k count=4k oflag=dsync
  2. 4096+0 records in
  3. 4096+0 records out
  4. 268435456 bytes (268 MB) copied, 7.87192 seconds, 34.1 MB/s
  5. [root@fastvps ~]# dd if=/dev/zero of=test bs=64k count=4k oflag=dsync
  6. 4096+0 records in
  7. 4096+0 records out
  8. 268435456 bytes (268 MB) copied, 6.78542 seconds, 39.6 MB/s
  1.    #    #  #    #  #  #    #          #####   ######  #    #   ####   #    #
  2.    #    #  ##   #  #   #  #           #    #  #       ##   #  #    #  #    #
  3.    #    #  # #  #  #    ##            #####   #####   # #  #  #       ######
  4.    #    #  #  # #  #    ##            #    #  #       #  # #  #       #    #
  5.    #    #  #   ##  #   #  #           #    #  #       #   ##  #    #  #    #
  6.     ####   #    #  #  #    #          #####   ######  #    #   ####   #    #
  7.    Version 5.1.2                      Based on the Byte Magazine Unix Benchmark
  8.    Multi-CPU version                  Version 5 revisions by Ian Smith,
  9.                                       Sunnyvale, CA, USA
  10.    December 22, 2007                  johantheghost at yahoo period com
  11. 1 x Dhrystone 2 using register variables  1 2 3 4 5 6 7 8 9 10
  12. 1 x Double-Precision Whetstone  1 2 3 4 5 6 7 8 9 10
  13. 1 x Execl Throughput  1 2 3
  14. 1 x File Copy 1024 bufsize 2000 maxblocks  1 2 3
  15. 1 x File Copy 256 bufsize 500 maxblocks  1 2 3
  16. 1 x File Copy 4096 bufsize 8000 maxblocks  1 2 3
  17. 1 x Pipe Throughput  1 2 3 4 5 6 7 8 9 10
  18. 1 x Pipe-based Context Switching  1 2 3 4 5 6 7 8 9 10
  19. 1 x Process Creation  1 2 3
  20. 1 x System Call Overhead  1 2 3 4 5 6 7 8 9 10
  21. 1 x Shell Scripts (1 concurrent)  1 2 3
  22. 1 x Shell Scripts (8 concurrent)  1 2 3
  23. ========================================================================
  24.    BYTE UNIX Benchmarks (Version 5.1.2)
  25.    System: fastvps.cc: GNU/Linux
  26.    OS: GNU/Linux -- 2.6.18-308.el5.028stab099.3 -- #1 SMP Wed Mar 7 15:56:00 MSK 2012
  27.    Machine: i686 (i386)
  28.    Language: en_US.utf8 (charmap="UTF-8", collate="UTF-8")
  29.    CPU 0: Intel(R) Xeon(R) CPU E5520 @ 2.27GHz (4533.6 bogomips)
  30.           Hyper-Threading, x86-64, MMX, Physical Address Ext, SYSENTER/SYSEXIT, SYSCALL/SYSRET, Intel virtualization
  31.    21:48:55 up 2 days, 21:05,  1 user,  load average: 0.26, 0.12, 0.04; runlevel 3
  32. ------------------------------------------------------------------------
  33. Benchmark Run: 二  6月 05 2012 21:48:55 - 22:21:29
  34. 1 CPU in system; running 1 parallel copy of tests
  35. Dhrystone 2 using register variables        8558015.7 lps   (10.0 s, 7 samples)
  36. Double-Precision Whetstone                     1923.0 MWIPS (10.1 s, 7 samples)
  37. Execl Throughput                               3110.6 lps   (29.6 s, 2 samples)
  38. File Copy 1024 bufsize 2000 maxblocks        320917.8 KBps  (30.0 s, 2 samples)
  39. File Copy 256 bufsize 500 maxblocks           99382.1 KBps  (30.0 s, 2 samples)
  40. File Copy 4096 bufsize 8000 maxblocks        846387.3 KBps  (30.0 s, 2 samples)
  41. Pipe Throughput                              677163.4 lps   (10.0 s, 7 samples)
  42. Pipe-based Context Switching                 201260.2 lps   (10.0 s, 7 samples)
  43. Process Creation                               9895.6 lps   (30.0 s, 2 samples)
  44. Shell Scripts (1 concurrent)                   3236.7 lpm   (60.0 s, 2 samples)
  45. Shell Scripts (8 concurrent)                    411.5 lpm   (60.1 s, 2 samples)
  46. System Call Overhead                         520212.0 lps   (10.0 s, 7 samples)
  47. System Benchmarks Index Values               BASELINE       RESULT    INDEX
  48. Dhrystone 2 using register variables         116700.0    8558015.7    733.3
  49. Double-Precision Whetstone                       55.0       1923.0    349.6
  50. Execl Throughput                                 43.0       3110.6    723.4
  51. File Copy 1024 bufsize 2000 maxblocks          3960.0     320917.8    810.4
  52. File Copy 256 bufsize 500 maxblocks            1655.0      99382.1    600.5
  53. File Copy 4096 bufsize 8000 maxblocks          5800.0     846387.3   1459.3
  54. Pipe Throughput                               12440.0     677163.4    544.3
  55. Pipe-based Context Switching                   4000.0     201260.2    503.2
  56. Process Creation                                126.0       9895.6    785.4
  57. Shell Scripts (1 concurrent)                     42.4       3236.7    763.4
  58. Shell Scripts (8 concurrent)                      6.0        411.5    685.9
  59. System Call Overhead                          15000.0     520212.0    346.8
  60.        ========
  61. System Benchmarks Index Score                                         644.6
发表于 2012-6-7 11:05:01 | 只看该作者
参与人数 1威望 +10 收起 理由
狼族工作室 + 10 亲,俺也有buyvm了
发表于 2012-6-7 11:05:29 | 只看该作者
发表于 2012-6-7 11:06:22 | 只看该作者
 楼主| 发表于 2012-6-7 11:17:26 | 只看该作者
geyunbing 发表于 2012-6-7 11:06
ping  有点高
芝加哥 稍高
发表于 2012-6-7 11:25:48 | 只看该作者
 楼主| 发表于 2012-6-7 11:28:16 | 只看该作者
geyunbing 发表于 2012-6-7 11:25
稳定?
练手不错,这货昨天宕机一次 说是机房遭到了DDOS...   TK回复还算快
我只买了一个星期 也不好评论
发表于 2012-6-7 11:29:01 | 只看该作者
发表于 2012-6-7 11:29:53 | 只看该作者
 楼主| 发表于 2012-6-7 11:30:08 | 只看该作者
geyunbing 发表于 2012-6-7 11:29
放个采集垃圾站 不错吧
嘿   实测和buyvm相当  一样的环境 一样的wp  压力测试的数据
跑分都差不多  buyvm现在上了ssd缓存   dd高一点
GMT+8, 2026-5-3 21:06 , Processed in 0.114001 second(s), 12 queries , Gzip On, MemCache On.
