查看: 1411|回复: 7
出KS-LE-2,E3-1231v3/32g/1.96Tx2
发表于 2024-3-15 12:05:07 来自手机 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
v4 100Mbps/1Gbps
v6 1Gbps
月付17欧,4月1日到期。
法国GRA机房,请自备ovh.ie账号,push出。
明盘120出。有兴趣的老板请pm我。
yabs:
  3. #                     v2024-03-05                    #
  6.
  7. Fri 15 Mar 2024 04:05:50 AM UTC
  8.
  9. Basic System Information:
  10. ---------------------------------
  11. Uptime     : 111 days, 12 hours, 26 minutes
  12. Processor  : Intel(R) Xeon(R) CPU E3-1231 v3 [url=home.php?mod=space&uid=175]@[/url] 3.40GHz
  13. CPU cores  : 8 @ 2539.753 MHz
  14. AES-NI     : ✔ Enabled
  15. VM-x/AMD-V : ✔ Enabled
  16. RAM        : 31.3 GiB
  17. Swap       : 1024.0 MiB
  18. Disk       : 1.7 TiB
  19. Distro     : Debian GNU/Linux 11 (bullseye)        Kernel     : 5.10.0-26-amd64
  20. VM Type    : NONE
  21. IPv4/IPv6  : ✔ Online / ✔ Online
  22.
  23. IPv6 Network Information:
  25. ISP        : OVH SAS
  26. ASN        : AS16276 OVH SAS
  27. Host       : OVH SAS
  28. Location   : Lille, Hauts-de-France (HDF)
  29. Country    : France
  30.
  31. fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/md3):
  32. ---------------------------------        Block Size | 4k            (IOPS) | 64k           (IOPS)
  33.   ------   | ---            ----  | ----           ----
  34. Read       | 213.45 MB/s  (53.3k) | 205.81 MB/s   (3.2k)
  35. Write      | 214.01 MB/s  (53.5k) | 206.89 MB/s   (3.2k)
  36. Total      | 427.46 MB/s (106.8k) | 412.70 MB/s   (6.4k)
  37.            |                      |
  38. Block Size | 512k          (IOPS) | 1m            (IOPS)
  40. Read       | 254.97 MB/s    (498) | 256.12 MB/s    (250)
  41. Write      | 268.52 MB/s    (524) | 273.18 MB/s    (266)
  42. Total      | 523.50 MB/s   (1.0k) | 529.31 MB/s    (516)
  43.
  44. iperf3 Network Speed Tests (IPv4):
  45. ---------------------------------
  46. Provider        | Location (Link)           | Send Speed      | Recv Speed      | Ping
  47. -----           | -----                     | ----            | ----            | ----
  48. Performing IPv4 iperf3 recv test from Clouvider (Attempt #1 of 3)..Clouvider       | London, UK (10G)          | 95.3 Mbits/sec  | 940 Mbits/sec   | 7.56 ms
  49. Eranium         | Amsterdam, NL (10G)       | busy            | busy            | 7.52 ms
  50. HOSTKEY         | Helsinki, FI (10G)        | 65.5 Mbits/sec  | 927 Mbits/sec   | 33.9 ms
  51. Performing IPv4 iperf3 recv test from Uztelecom (Attempt #1 of 3)..Uztelecom       | Tashkent, UZ (10G)        | 34.7 Mbits/sec  | 535 Mbits/sec   | 100 ms
  52. Leaseweb        | Singapore, SG (10G)       | 13.6 Mbits/sec  | 612 Mbits/sec   | 242 ms
  53. Performing IPv4 iperf3 recv test from Clouvider (Attempt #1 of 3)..Performing IPv4 iperf3 recv test from Clouvider (Attempt #2 of 3)..Performing IPv4 iperf3 recv te
  54. st from Clouvider (Attempt #3 of 3)..Clouvider       | Los Angeles, CA, US (10G) | 23.5 Mbits/sec  | busy            | 134 ms
  55. Leaseweb        | NYC, NY, US (10G)         | 38.3 Mbits/sec  | 662 Mbits/sec   | 75.6 ms
  56. Edgoo           | Sao Paulo, BR (1G)        | 15.5 Mbits/sec  | 158 Mbits/sec   | 141 ms
  57. iperf3 Network Speed Tests (IPv6):
  58. ---------------------------------
  59. Provider        | Location (Link)           | Send Speed      | Recv Speed      | Ping
  60. -----           | -----                     | ----            | ----            | ----
  61. Performing IPv6 iperf3 recv test from Clouvider (Attempt #1 of 3)..Clouvider       | London, UK (10G)          | 908 Mbits/sec   | 796 Mbits/sec   | 7.51 ms
  62. Eranium         | Amsterdam, NL (10G)       | busy            | busy            | 7.31 ms
  63. Uztelecom       | Tashkent, UZ (10G)        | 771 Mbits/sec   | 773 Mbits/sec   | 100 ms
  64. Leaseweb        | Singapore, SG (10G)       | 3.05 Mbits/sec  | 467 Mbits/sec   | 242 ms
  65. Clouvider       | Los Angeles, CA, US (10G) | 682 Mbits/sec   | 464 Mbits/sec   | 134 ms
  66. Leaseweb        | NYC, NY, US (10G)         | 746 Mbits/sec   | 659 Mbits/sec   | --
  67. Edgoo           | Sao Paulo, BR (1G)        | 746 Mbits/sec   | 40.6 Mbits/sec  | 141 ms
  68. Geekbench 6 Benchmark Test:
  69. ---------------------------------
  70. Test            | Value
  71.                 |
  72. Single Core     | 1321
  73. Multi Core      | 4362
  74. Full Test       | https://browser.geekbench.com/v6/cpu/5319184
  75. YABS completed in 13 min 43 sec
来自 4#
 楼主| 发表于 2024-3-15 12:36:35 | 只看该作者
已出 合作愉快
发表于 2024-3-15 12:19:40 | 只看该作者
可惜没账号的
发表于 2024-3-15 12:36:05 | 只看该作者
好机, 奈何没账号的
发表于 2024-3-15 12:45:38 来自手机 | 只看该作者
想收一个的…
发表于 2024-3-15 12:46:13 | 只看该作者
已完成交易
发表于 2024-3-16 17:10:57 | 只看该作者
错过好几台了 奶奶的
发表于 2024-3-16 17:15:17 | 只看该作者
canxunhulian 发表于 2024-3-16 17:10
错过好几台了 奶奶的
ks-le-2 搶手貨
如果不是換了新獨服也不會放
GMT+8, 2026-4-13 23:56 , Processed in 0.066385 second(s), 11 queries , Gzip On, MemCache On.
