查看: 4691|回复: 11
[美国VPS] Netcup RS1000 G11 评测
发表于 2024-3-13 03:53:03 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
用了5刀新用户优惠码,36nc17102646894,老用户可以去订阅邮箱然后也可以拿5刀
月付8.24o
Yet-Another-Bench-Script
v2024-03-05
https://github.com/masonr/yet-another-bench-script
Tue Mar 12 03:01:28 PM CET 2024
Basic System Information:
Uptime : 0 days, 0 hours, 59 minutes
Processor : AMD EPYC 9634 84-Core Processor
CPU cores : 4 @ 2246.624 MHz
AES-NI : ✔ Enabled
VM-x/AMD-V : ❌ Disabled
RAM : 7.8 GiB
Swap : 0.0 KiB
Disk : 251.8 GiB
Distro : Ubuntu 22.04.4 LTS
Kernel : 5.15.0-100-generic
VM Type : KVM
IPv4/IPv6 : ✔ Online / ✔ Online
IPv6 Network Information:
ISP : netcup GmbH
ASN : AS197540 netcup GmbH
Host : NETCUP-GMBH
Country : Germany
Preparing system for disk tests...
Generating fio test file...
Running fio random mixed R+W disk test with 4k block size...
Running fio random mixed R+W disk test with 64k block size...
Running fio random mixed R+W disk test with 512k block size...
Running fio random mixed R+W disk test with 1m block size...
fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/vda3):
Block Size | 4k (IOPS) | 64k (IOPS)
Read | 300.39 MB/s (75.0k) | 650.38 MB/s (10.1k)
Write | 301.19 MB/s (75.2k) | 653.81 MB/s (10.2k)
Total | 601.59 MB/s (150.3k) | 1.30 GB/s (20.3k)
Block Size | 512k (IOPS) | 1m (IOPS)
Read | 688.30 MB/s (1.3k) | 878.60 MB/s (858)
Write | 724.87 MB/s (1.4k) | 937.11 MB/s (915)
Total | 1.41 GB/s (2.7k) | 1.81 GB/s (1.7k)
Provider        Location (Link)        Send Speed        Recv Speed        Ping
Performing IPv4 iperf3 send test to Clouvider (Attempt #1 of 3)...
Performing IPv4 iperf3 send test to Clouvider (Attempt #2 of 3)...
Performing IPv4 iperf3 send test to Clouvider (Attempt #3 of 3)...
Performing IPv4 iperf3 recv test from Clouvider (Attempt #1 of 3)...
Performing IPv4 iperf3 recv test from Clouvider (Attempt #2 of 3)...
Performing IPv4 iperf3 recv test from Clouvider (Attempt #3 of 3)...
Clouvider        London, UK (10G)        busy        1.06 Gbits/sec        22.6 ms
Performing IPv4 iperf3 send test to Eranium (Attempt #1 of 3)...
Performing IPv4 iperf3 send test to Eranium (Attempt #2 of 3)...
Performing IPv4 iperf3 send test to Eranium (Attempt #3 of 3)...
Performing IPv4 iperf3 recv test from Eranium (Attempt #1 of 3)...
Performing IPv4 iperf3 recv test from Eranium (Attempt #2 of 3)...
Performing IPv4 iperf3 recv test from Eranium (Attempt #3 of 3)...
Eranium        Amsterdam, NL (10G)        2.69 Gbits/sec        busy        10.5 ms
Performing IPv4 iperf3 send test to HOSTKEY (Attempt #1 of 3)...
Performing IPv4 iperf3 recv test from HOSTKEY (Attempt #1 of 3)...
HOSTKEY        Helsinki, FI (10G)        207 Mbits/sec        437 Mbits/sec        70.1 ms
Performing IPv4 iperf3 send test to Uztelecom (Attempt #1 of 3)...
Performing IPv4 iperf3 recv test from Uztelecom (Attempt #1 of 3)...
Performing IPv4 iperf3 recv test from Uztelecom (Attempt #2 of 3)...
Uztelecom        Tashkent, UZ (10G)        2.46 Gbits/sec        1.63 Gbits/sec        83.1 ms
Performing IPv4 iperf3 send test to Leaseweb (Attempt #1 of 3)...
Performing IPv4 iperf3 send test to Leaseweb (Attempt #2 of 3)...
Performing IPv4 iperf3 recv test from Leaseweb (Attempt #1 of 3)...
Performing IPv4 iperf3 recv test from Leaseweb (Attempt #2 of 3)...
Performing IPv4 iperf3 recv test from Leaseweb (Attempt #3 of 3)...
Leaseweb        Singapore, SG (10G)        1.88 Gbits/sec        busy        179 ms
Clouvider        Los Angeles, CA, US (10G)        376 Mbits/sec        487 Mbits/sec        147 ms
Leaseweb        NYC, NY, US (10G)        2.36 Gbits/sec        busy        91.6 ms
Performing IPv4 iperf3 send test to Edgoo (Attempt #1 of 3)...
Performing IPv4 iperf3 recv test from Edgoo (Attempt #1 of 3)...
Edgoo        Sao Paulo, BR (1G)        1.04 Gbits/sec        367 Mbits/sec        163 ms
iperf3 Network Speed Tests (IPv6):
Performing IPv6 iperf3 send test to Clouvider (Attempt #1 of 3)...
Performing IPv6 iperf3 recv test from Clouvider (Attempt #1 of 3)...
Performing IPv6 iperf3 recv test from Clouvider (Attempt #2 of 3)...
Clouvider        London, UK (10G)        2.67 Gbits/sec        2.32 Gbits/sec        22.5 ms
Performing IPv6 iperf3 send test to Eranium (Attempt #1 of 3)...
Performing IPv6 iperf3 recv test from Eranium (Attempt #1 of 3)...
Eranium        Amsterdam, NL (10G)        2.70 Gbits/sec        2.34 Gbits/sec        10.4 ms
Performing IPv6 iperf3 send test to Uztelecom (Attempt #1 of 3)...
Performing IPv6 iperf3 recv test from Uztelecom (Attempt #1 of 3)...
Uztelecom        Tashkent, UZ (10G)        2.43 Gbits/sec        721 Mbits/sec        82.9 ms
Performing IPv6 iperf3 send test to Leaseweb (Attempt #1 of 3)...
Performing IPv6 iperf3 recv test from Leaseweb (Attempt #1 of 3)...
Leaseweb        Singapore, SG (10G)        2.19 Gbits/sec        1.84 Gbits/sec        179 ms
Clouvider        Los Angeles, CA, US (10G)        1.04 Gbits/sec        451 Mbits/sec        147 ms
Performing IPv6 iperf3 send test to Leaseweb (Attempt #2 of 3)...
Performing IPv6 iperf3 send test to Leaseweb (Attempt #3 of 3)...
Leaseweb        NYC, NY, US (10G)        2.51 Gbits/sec        2.00 Gbits/sec        91.6 ms
Performing IPv6 iperf3 send test to Edgoo (Attempt #1 of 3)...
Performing IPv6 iperf3 recv test from Edgoo (Attempt #1 of 3)...
Edgoo        Sao Paulo, BR (1G)        1.78 Gbits/sec        344 Mbits/sec        163 ms
Running GB5 benchmark test... cue elevator music
Geekbench 5 Benchmark Test:
Test | Value
Single Core | 1491
Multi Core | 5260
Full Test | https://browser.geekbench.com/v5/cpu/22313587
Running GB6 benchmark test... cue elevator music
Geekbench 6 Benchmark Test:
Test | Value
Single Core | 1986
Multi Core | 6100
Full Test | https://browser.geekbench.com/v6/cpu/5283820
YABS completed in 14 min 25 sec
发表于 2024-3-13 13:53:57 | 只看该作者
yuewolf 发表于 2024-3-13 13:45
大佬,请教一下。是不是每个月末netcup都会有个硬盘翻倍活动?如果刚好有自己中意的型号,在你这里买个账 ...
是的,以前是这样的月末有翻倍活动,群里会通知的。免税号买任何东西都会除去19%税
发表于 2024-3-13 08:37:08 | 只看该作者
老款和新款的差别是啥?哪个香?
发表于 2024-3-13 08:40:56 | 只看该作者
宁静致远 发表于 2024-3-13 08:37
老款和新款的差别是啥?哪个香?
新款硬件全面升级,但是跑流量不如老款,因为一天跑过3TB会限速到300M
新款适合做站和跑项目的,轻量下载啥的
重度下载,例如下PT的还是老款
 楼主| 发表于 2024-3-13 09:17:33 | 只看该作者
做站和项目用G11
发表于 2024-3-13 09:18:53 | 只看该作者
这个有防御吗
发表于 2024-3-13 09:50:18 | 只看该作者
新款的IO差老款太远了吧。3倍了。
 楼主| 发表于 2024-3-13 12:11:54 来自手机 | 只看该作者
有ddos防御
发表于 2024-3-13 12:21:11 | 只看该作者
https://vpsceping.org/1383.html  评测文章。 现在还可以用优惠码下单老款。
发表于 2024-3-13 13:45:48 | 只看该作者
大佬,请教一下。是不是每个月末netcup都会有个硬盘翻倍活动?如果刚好有自己中意的型号,在你这里买个账号,就可以减税购买?
GMT+8, 2026-5-1 10:05 , Processed in 0.068944 second(s), 11 queries , Gzip On, MemCache On.
