查看: 2087|回复: 7
7折出一台fastvps.co的年付
发表于 2012-6-5 21:41:17 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
15GB Disk Space
1TB Bandwidth
1 Core CPU
128MB RAM
burst 256MB
数据中心在芝加哥ubi 访问稍慢 但是稳定
http://108.62.103.61/p.php
2013.5.1到期
我买的时候付款了11.02 USD  7折就是7.7刀    算45得了
45快 买一年vps  新手练手建站必备
[root@fastvps ~]# dd if=/dev/zero of=test bs=64k count=4k oflag=dsync
4096+0 records in
4096+0 records out
268435456 bytes (268 MB) copied, 7.87192 seconds, 34.1 MB/s
4096+0 records in
4096+0 records out
268435456 bytes (268 MB) copied, 6.78542 seconds, 39.6 MB/s
  1.    #    #  #    #  #  #    #          #####   ######  #    #   ####   #    #
  2.    #    #  ##   #  #   #  #           #    #  #       ##   #  #    #  #    #
  3.    #    #  # #  #  #    ##            #####   #####   # #  #  #       ######
  4.    #    #  #  # #  #    ##            #    #  #       #  # #  #       #    #
  5.    #    #  #   ##  #   #  #           #    #  #       #   ##  #    #  #    #
  6.     ####   #    #  #  #    #          #####   ######  #    #   ####   #    #
  7.    Version 5.1.2                      Based on the Byte Magazine Unix Benchmark
  8.    Multi-CPU version                  Version 5 revisions by Ian Smith,
  9.                                       Sunnyvale, CA, USA
  10.    December 22, 2007                  johantheghost at yahoo period com
  11. 1 x Dhrystone 2 using register variables  1 2 3 4 5 6 7 8 9 10
  12. 1 x Double-Precision Whetstone  1 2 3 4 5 6 7 8 9 10
  13. 1 x Execl Throughput  1 2 3
  14. 1 x File Copy 1024 bufsize 2000 maxblocks  1 2 3
  15. 1 x File Copy 256 bufsize 500 maxblocks  1 2 3
  16. 1 x File Copy 4096 bufsize 8000 maxblocks  1 2 3
  17. 1 x Pipe Throughput  1 2 3 4 5 6 7 8 9 10
  18. 1 x Pipe-based Context Switching  1 2 3 4 5 6 7 8 9 10
  19. 1 x Process Creation  1 2 3
  20. 1 x System Call Overhead  1 2 3 4 5 6 7 8 9 10
  21. 1 x Shell Scripts (1 concurrent)  1 2 3
  22. 1 x Shell Scripts (8 concurrent)  1 2 3
  23. ========================================================================
  24.    BYTE UNIX Benchmarks (Version 5.1.2)
  25.    System: fastvps.cc: GNU/Linux
  26.    OS: GNU/Linux -- 2.6.18-308.el5.028stab099.3 -- #1 SMP Wed Mar 7 15:56:00 MSK 2012
  27.    Machine: i686 (i386)
  28.    Language: en_US.utf8 (charmap="UTF-8", collate="UTF-8")
  29.    CPU 0: Intel(R) Xeon(R) CPU E5520 @ 2.27GHz (4533.6 bogomips)
  30.           Hyper-Threading, x86-64, MMX, Physical Address Ext, SYSENTER/SYSEXIT, SYSCALL/SYSRET, Intel virtualization
  31.    21:48:55 up 2 days, 21:05,  1 user,  load average: 0.26, 0.12, 0.04; runlevel 3
  32. ------------------------------------------------------------------------
  33. Benchmark Run: 二  6月 05 2012 21:48:55 - 22:21:29
  34. 1 CPU in system; running 1 parallel copy of tests
  35. Dhrystone 2 using register variables        8558015.7 lps   (10.0 s, 7 samples)
  36. Double-Precision Whetstone                     1923.0 MWIPS (10.1 s, 7 samples)
  37. Execl Throughput                               3110.6 lps   (29.6 s, 2 samples)
  38. File Copy 1024 bufsize 2000 maxblocks        320917.8 KBps  (30.0 s, 2 samples)
  39. File Copy 256 bufsize 500 maxblocks           99382.1 KBps  (30.0 s, 2 samples)
  40. File Copy 4096 bufsize 8000 maxblocks        846387.3 KBps  (30.0 s, 2 samples)
  41. Pipe Throughput                              677163.4 lps   (10.0 s, 7 samples)
  42. Pipe-based Context Switching                 201260.2 lps   (10.0 s, 7 samples)
  43. Process Creation                               9895.6 lps   (30.0 s, 2 samples)
  44. Shell Scripts (1 concurrent)                   3236.7 lpm   (60.0 s, 2 samples)
  45. Shell Scripts (8 concurrent)                    411.5 lpm   (60.1 s, 2 samples)
  46. System Call Overhead                         520212.0 lps   (10.0 s, 7 samples)
  47. System Benchmarks Index Values               BASELINE       RESULT    INDEX
  48. Dhrystone 2 using register variables         116700.0    8558015.7    733.3
  49. Double-Precision Whetstone                       55.0       1923.0    349.6
  50. Execl Throughput                                 43.0       3110.6    723.4
  51. File Copy 1024 bufsize 2000 maxblocks          3960.0     320917.8    810.4
  52. File Copy 256 bufsize 500 maxblocks            1655.0      99382.1    600.5
  53. File Copy 4096 bufsize 8000 maxblocks          5800.0     846387.3   1459.3
  54. Pipe Throughput                               12440.0     677163.4    544.3
  55. Pipe-based Context Switching                   4000.0     201260.2    503.2
  56. Process Creation                                126.0       9895.6    785.4
  57. Shell Scripts (1 concurrent)                     42.4       3236.7    763.4
  58. Shell Scripts (8 concurrent)                      6.0        411.5    685.9
  59. System Call Overhead                          15000.0     520212.0    346.8
  60.        ========
  61. System Benchmarks Index Score                                         644.6
发表于 2012-6-5 21:42:53 | 只看该作者
支持下 。。 内存小了点
发表于 2012-6-5 22:10:47 | 只看该作者
是慢了点
发表于 2012-6-6 02:19:34 | 只看该作者
慢了点
发表于 2012-6-6 05:41:36 来自手机 | 只看该作者
真便宜……123systems最低10刀……
发表于 2012-6-6 16:38:18 | 只看该作者
一个和一个不能比的
fastvps的还能玩。123的10刀根本不能玩
发表于 2012-6-6 18:02:27 | 只看该作者
edmin 发表于 2012-6-6 16:38
一个和一个不能比的
当年很早买的,256M的那款,15刀一年,现在国人少了居然很稳定了。。。
发表于 2012-6-6 21:49:26 | 只看该作者
不错,价格给力.
GMT+8, 2026-4-14 20:33 , Processed in 0.123221 second(s), 12 queries , Gzip On, MemCache On.
