查看: 1397|回复: 3
atlantic食之无味,弃之可惜
发表于 2024-3-6 21:56:24 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
用小红卡**的,服务器地区所有能选的只有美国,英国,加拿大,还有个新出的新加坡,我以为都新加坡了,总不可能160ms了吧,结果这新加坡开了2个机在大陆全绕路了,绕美国一趟再跑回来,但只能说对于免费一年鸡来说,性能可以的,其他地区的鸡性能就不知道了,并且听别人说这atlantic会意外扣费
Basic System Information:
Uptime     : 0 days, 0 hours, 12 minutes
Processor  : QEMU Virtual CPU version 2.5+
CPU cores  : 1 @ 2500.000 MHz
AES-NI     : ❌ Disabled
VM-x/AMD-V : ✔ Enabled
RAM        : 1.9 GiB
Swap       : 0.0 KiB
Disk       : 49.1 GiB
Distro     : Ubuntu 20.04.4 LTS
Kernel     : 5.4.0-121-generic
VM Type    : KVM
IPv4/IPv6  : ✔ Online / ❌ Offline
IPv4 Network Information:
ISP        : Atlantic.net, Inc.
ASN        : AS6364 Atlantic.net, Inc.
Host       : Atlantic.Net, Inc
Country    : Singapore
fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/sda1):
Read       | 136.18 MB/s  (34.0k) | 2.06 GB/s    (32.3k)
Write      | 136.54 MB/s  (34.1k) | 2.07 GB/s    (32.4k)
Total      | 272.72 MB/s  (68.1k) | 4.14 GB/s    (64.8k)
Read       | 2.23 GB/s     (4.3k) | 2.28 GB/s     (2.2k)
Write      | 2.35 GB/s     (4.5k) | 2.44 GB/s     (2.3k)
Total      | 4.58 GB/s     (8.9k) | 4.72 GB/s     (4.6k)
Provider        | Location (Link)           | Send Speed      | Recv Speed      | Ping
Clouvider       | London, UK (10G)          | busy            | 108 Mbits/sec   | 156 ms
Eranium         | Amsterdam, NL (10G)       | 451 Mbits/sec   | 434 Mbits/sec   | 168 ms
HOSTKEY         | Helsinki, FI (10G)        | busy            | 315 Kbits/sec   | 186 ms
Uztelecom       | Tashkent, UZ (10G)        | busy            | busy            | 238 ms
Leaseweb        | Singapore, SG (10G)       | 704 Mbits/sec   | 596 Mbits/sec   | 1.66 ms
Clouvider       | Los Angeles, CA, US (10G) | 486 Mbits/sec   | 257 Mbits/sec   | 238 ms
Leaseweb        | NYC, NY, US (10G)         | 563 Mbits/sec   | 407 Mbits/sec   | 244 ms
Edgoo           | Sao Paulo, BR (1G)        | 278 Mbits/sec   | 43.7 Mbits/sec  | 312 ms
Geekbench 6 Benchmark Test:
Test            | Value
Single Core     | 824
Multi Core      | 827
发表于 2024-3-6 21:58:00 | 只看该作者
食之无味,弃之可惜,那就送我
 楼主| 发表于 2024-3-6 21:59:12 | 只看该作者
HOH 发表于 2024-3-6 21:58
食之无味,弃之可惜,那就送我
发表于 2024-3-6 22:04:44 | 只看该作者
确实没用,用多了就说你滥用直接封了
GMT+8, 2026-5-2 18:28 , Processed in 0.064919 second(s), 11 queries , Gzip On, MemCache On.
