查看: 1430|回复: 8
[疑问] 绿云最近总是被反复suspended?
发表于 2024-3-1 12:44:43 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
具体原因如下:
Feb 29 00:01:21 syslog sshd[27565]: Failed password for invalid user hao from 43.***.***.*** port 49456 ssh2 Feb 29 00:03:23 syslog sshd[27595]: Failed password for invalid user blade from 43.***.***.*** port 19158 ssh2 Feb 29 00:05:23 syslog sshd[27616]: Failed password for invalid user shiml from 43.***.***.*** port 52550 ssh2 Feb 29 00:07:33 syslog sshd[27643]: Failed password for invalid user zhengyandong from 43.***.***.*** port 49066 ssh2 Feb 29 00:09:38 syslog sshd[27669]: Failed password for invalid user ohan from 43.***.***.*** port 2864 ssh2 Feb 29 00:11:42 syslog sshd[27701]: Failed password for invalid user prod from 43.***.***.*** port 49556 ssh2 Feb 29 00:13:45 syslog sshd[27739]: Failed password for invalid user zqj from 43.***.***.*** port 38474 ssh2 Feb 29 00:15:47 syslog sshd[27764]: Failed password for invalid user spotligh from 43.***.***.*** port 56194 ssh2 Feb 29 00:17:51 syslog sshd[27791]: Failed password for invalid user xydkdev from 43.***.***.*** port 21426 ssh2 Feb 29 00:19:53 syslog sshd[27836]: Failed password for invalid user root from 43.***.***.*** port 60298 ssh2 Feb 29 00:21:57 syslog sshd[27904]: Failed password for invalid user root from 43.***.***.*** port 9840 ssh2 Feb 29 00:23:57 syslog sshd[28007]: Failed password for invalid user pwdi from 43.***.***.*** port 28016 ssh2 Feb 29 00:26:03 syslog sshd[28035]: Failed password for invalid user zhaojiabei from 43.***.***.*** port 38454 ssh2 Feb 29 00:28:08 syslog sshd[28067]: Failed password for invalid user baoyan from 43.***.***.*** port 41552 ssh2 Feb 29 00:30:08 syslog sshd[28122]: Failed password for invalid user dbgroup from 43.***.***.*** port 15938 ssh2 Feb 29 00:32:10 syslog sshd[28148]: Failed password for invalid user xintong from 43.***.***.*** port 7490 ssh2 Feb 29 00:34:13 syslog sshd[28172]: Failed password for invalid user root from 43.***.***.*** port 44386 ssh2 Feb 29 00:36:13 syslog sshd[28218]: Failed password for invalid user guest-nrbjoy from 43.***.***.*** port 19450 ssh2 Feb 29 00:38:14 syslog sshd[28251]: Failed password for invalid user contact from 43.***.***.*** port 27014 ssh2 Feb 29 00:40:17 syslog sshd[28302]: Failed password for invalid user liuyan from 43.***.***.*** port 34522 ssh2 Feb 29 00:42:18 syslog sshd[28332]: Failed password for invalid user loadrunner from 43.***.***.*** port 26758 ssh2 Feb 29 00:44:25 syslog sshd[28362]: Failed password for invalid user tangliu from 43.***.***.*** port 38022 ssh2 Feb 29 00:46:30 syslog sshd[28386]: Failed password for invalid user chonglin from 43.***.***.*** port 43458 ssh2 Feb 29 00:48:32 syslog sshd[28416]: Failed password for invalid user zcysky from 43.***.***.*** port 59640 ssh2
解释一下,43.***.***.***这个就是我vps的本机ip地址,为什么我会从本机尝试ssh2登陆本机???
我已经全部rebuild过了,重装了之后,怎么还是会出现这种情况???还要请教各位MJJ大佬
发表于 2024-3-1 13:46:28 | 只看该作者
挂代理然后有app反复尝试登录ssh?
发表于 2024-3-1 13:49:44 | 只看该作者
代理给别人用了?
 楼主| 发表于 2024-3-1 13:51:14 | 只看该作者
没啊,自己用的,真特么见鬼了,而且rebuild过了,还这样,真要说难道是这个脚本???
wget -O tcp.sh "https://github.com/ylx2016/Linux-NetSpeed/raw/master/tcp.sh" && chmod +x tcp.sh && ./tcp.sh
应该没问题的吧
还装个x-ui,应该是大家都用的脚本,不会有问题
bash <(curl -Ls https://raw.githubusercontent.com/FranzKafkaYu/x-ui/master/install.sh)
发表于 2024-3-1 14:03:48 来自手机 | 只看该作者
你往外扫才封你,你被扫不会封你,对着呢。
 楼主| 发表于 2024-3-1 14:08:18 | 只看该作者
奇了怪了,都是他们的系统,除开上面2脚本,啥都没搞,说我外扫,莫非是绿云他们自己的linux有毒吧
 楼主| 发表于 2024-3-1 14:10:13 | 只看该作者
而且已经是3次了,过完春节后,也就是我都重装2次了,
另外我其他vps(搬瓦工和rn)也装这俩脚本,一点事没有!!!
 楼主| 发表于 2024-3-1 14:11:41 | 只看该作者
绿云搞啥JB鬼
发表于 2024-3-1 23:58:11 | 只看该作者
另外我其他vps(搬瓦工和rn)也装这俩脚本,一点 ...
默认的版本也要开起安全策略,或者你架设的程序有漏洞。
我上次对外扫描给停机了,当时我还言之凿凿的说我没扫,等给我解封之后,我仔细查看,确实是我用的xampp存在一个漏洞,被人上传了程序,对外扫描了。
GMT+8, 2026-4-24 09:17 , Processed in 0.063322 second(s), 10 queries , Gzip On, MemCache On.
