查看: 3602|回复: 16
[Windows VPS] 独服的 dd 只有2.3 MB/s
发表于 2012-6-3 11:17:47 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
[root@server ~]# dd if=/dev/zero of=test bs=64k count=4k oflag=dsync
4096+0 records in
4096+0 records out
268435456 bytes (268 MB) copied, 116.102 seconds, 2.3 MB/s
  1. [root@server ~]# smartctl -a /dev/sda
  2. smartctl version 5.38 [x86_64-redhat-linux-gnu] Copyright (C) 2002-8 Bruce Allen
  3. Home page is ttp://smartmontools.sourceforge.net/
  4. === START OF INFORMATION SECTION ===
  5. Device Model:     ST1000DM003-9YN162
  6. Serial Number:    W1D0WRTT
  7. Firmware Version: CC4D
  8. User Capacity:    1,000,204,886,016 bytes
  9. Device is:        Not in smartctl database [for details use: -P showall]
  10. ATA Version is:   8
  11. ATA Standard is:  ATA-8-ACS revision 4
  12. Local Time is:    Sun Jun  3 05:19:46 2012 CEST
  13. SMART support is: Available - device has SMART capability.
  14. SMART support is: Enabled
  15. === START OF READ SMART DATA SECTION ===
  16. SMART overall-health self-assessment test result: PASSED
  17. General SMART Values:
  18. Offline data collection status:  (0x00)        Offline data collection activity
  19.                                         was never started.
  20.                                         Auto Offline Data Collection: Disabled.
  21. Self-test execution status:      (   0)        The previous self-test routine completed
  22.                                         without error or no self-test has ever
  23.                                         been run.
  24. Total time to complete Offline
  25. data collection:                  ( 575) seconds.
  26. Offline data collection
  27. capabilities:                          (0x73) SMART execute Offline immediate.
  28.                                         Auto Offline data collection on/off support.
  29.                                         Suspend Offline collection upon new
  30.                                         command.
  31.                                         No Offline surface scan supported.
  32.                                         Self-test supported.
  33.                                         Conveyance Self-test supported.
  34.                                         Selective Self-test supported.
  35. SMART capabilities:            (0x0003)        Saves SMART data before entering
  36.                                         power-saving mode.
  37.                                         Supports SMART auto save timer.
  38. Error logging capability:        (0x01)        Error logging supported.
  39.                                         General Purpose Logging supported.
  40. Short self-test routine
  41. recommended polling time:          (   1) minutes.
  42. Extended self-test routine
  43. recommended polling time:          ( 115) minutes.
  44. Conveyance self-test routine
  45. recommended polling time:          (   2) minutes.
  46. SCT capabilities:                (0x3085)        SCT Status supported.
  47. SMART Attributes Data Structure revision number: 10
  48. Vendor Specific SMART Attributes with Thresholds:
  49. ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
  50.   1 Raw_Read_Error_Rate     0x000f   113   099   006    Pre-fail  Always       -       54427552
  51.   3 Spin_Up_Time            0x0003   097   097   000    Pre-fail  Always       -       0
  52.   4 Start_Stop_Count        0x0032   100   100   020    Old_age   Always       -       24
  53.   5 Reallocated_Sector_Ct   0x0033   100   100   036    Pre-fail  Always       -       0
  54.   7 Seek_Error_Rate         0x000f   100   253   030    Pre-fail  Always       -       312202
  55.   9 Power_On_Hours          0x0032   100   100   000    Old_age   Always       -       53
  56. 10 Spin_Retry_Count        0x0013   100   100   097    Pre-fail  Always       -       0
  57. 12 Power_Cycle_Count       0x0032   100   100   020    Old_age   Always       -       24
  58. 183 Unknown_Attribute       0x0032   100   100   000    Old_age   Always       -       0
  59. 184 Unknown_Attribute       0x0032   100   100   099    Old_age   Always       -       0
  60. 187 Reported_Uncorrect      0x0032   100   100   000    Old_age   Always       -       0
  61. 188 Unknown_Attribute       0x0032   100   100   000    Old_age   Always       -       0
  62. 189 High_Fly_Writes         0x003a   100   100   000    Old_age   Always       -       0
  63. 190 Airflow_Temperature_Cel 0x0022   062   048   045    Old_age   Always       -       38 (Lifetime Min/Max 34/40)
  64. 191 G-Sense_Error_Rate      0x0032   100   100   000    Old_age   Always       -       0
  65. 192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       23
  66. 193 Load_Cycle_Count        0x0032   100   100   000    Old_age   Always       -       51
  67. 194 Temperature_Celsius     0x0022   038   052   000    Old_age   Always       -       38 (0 26 0 0)
  68. 197 Current_Pending_Sector  0x0012   100   100   000    Old_age   Always       -       0
  69. 198 Offline_Uncorrectable   0x0010   100   100   000    Old_age   Offline      -       0
  70. 199 UDMA_CRC_Error_Count    0x003e   200   200   000    Old_age   Always       -       0
  71. 240 Head_Flying_Hours       0x0000   100   253   000    Old_age   Offline      -       69788923592748
  72. 241 Unknown_Attribute       0x0000   100   253   000    Old_age   Offline      -       73669293185
  73. 242 Unknown_Attribute       0x0000   100   253   000    Old_age   Offline      -       186694490553
  74. SMART Error Log Version: 1
  75. No Errors Logged
  76. SMART Self-test log structure revision number 1
  77. Num  Test_Description    Status                  Remaining  LifeTime(hours)  LBA_of_first_error
  78. # 1  Short offline       Completed without error       00%        14         -
  79. # 2  Short offline       Completed without error       00%         8         -
  80. # 3  Short offline       Completed without error       00%         8         -
  81. # 4  Short offline       Completed without error       00%         7         -
  82. # 5  Short offline       Completed without error       00%         0         -
  83. SMART Selective self-test log data structure revision number 1
  84. SPAN  MIN_LBA  MAX_LBA  CURRENT_TEST_STATUS
  85.     1        0        0  Not_testing
  86.     2        0        0  Not_testing
  87.     3        0        0  Not_testing
  88.     4        0        0  Not_testing
  89.     5        0        0  Not_testing
  90. Selective self-test flags (0x0):
  91.   After scanning selected spans, do NOT read-scan remainder of disk.
  92. If Selective self-test is pending on power-up, resume after 0 minute delay.
怎么这么慢?
参与人数 1威望 +1 收起 理由
408904199 + 1 这个东西一点都不准确的
发表于 2012-6-3 11:36:38 | 只看该作者
100M的撸过
发表于 2012-6-3 11:30:02 | 只看该作者
发表于 2012-6-3 11:20:47 | 只看该作者
纳尼
发表于 2012-6-3 11:21:05 | 只看该作者
不要用dsync
发表于 2012-6-3 17:36:20 | 只看该作者
正常的
发表于 2012-6-3 17:36:48 | 只看该作者
哦也,这是传说中的砖头硬盘吗?
 楼主| 发表于 2012-6-3 17:34:41 | 只看该作者
大家都这样吗?
发表于 2012-6-3 17:48:56 | 只看该作者
这个测试是不准确的,正常使用就行了、
受到警告 10#
发表于 2012-6-3 17:48:51 来自手机 | 只看该作者
提示: 该帖被管理员或版主屏蔽
GMT+8, 2026-4-16 07:32 , Processed in 0.067182 second(s), 12 queries , Gzip On, MemCache On.
