查看: 1427|回复: 8
Layer | AMD Ryzen 7950X 4C 8G 只測不評
发表于 2024-1-30 23:36:11 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
YABS
Yet-Another-Bench-Script
v2024-01-01
https://github.com/masonr/yet-another-bench-script
Tue Jan 30 10:59:06 PM HKT 2024
Basic System Information:
Uptime : 0 days, 0 hours, 13 minutes
Processor : AMD Ryzen 9 7950X 16-Core Processor
CPU cores : 4 @ 4491.540 MHz
AES-NI : ✔ Enabled
VM-x/AMD-V : ❌ Disabled
RAM : 7.7 GiB
Swap : 0.0 KiB
Disk : 99.9 GiB
Distro : Debian GNU/Linux 12 (bookworm)
Kernel : 6.1.0-9-amd64
VM Type : KVM
IPv4/IPv6 : ✔ Online / ✔ Online
IPv6 Network Information:
ISP : Layer Marketing Services L.L.C
ASN : AS216382 LAYER MARKETING SERVICES L.L.C
Host : Layer
Country : United States
fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/vda3):
Block Size        4k (IOPS)        64k (IOPS)
Read        432.81 MB/s (108.2k)        3.09 GB/s (48.4k)
Write        433.95 MB/s (108.4k)        3.11 GB/s (48.6k)
Total        866.77 MB/s (216.6k)        6.21 GB/s (97.0k)
Block Size        512k (IOPS)        1m (IOPS)
Read        3.48 GB/s (6.7k)        3.72 GB/s (3.6k)
Write        3.66 GB/s (7.1k)        3.97 GB/s (3.8k)
Total        7.14 GB/s (13.9k)        7.69 GB/s (7.5k)
Provider        Location (Link)        Send Speed        Recv Speed        Ping
Clouvider        London, UK (10G)        1.41 Gbits/sec        1.62 Gbits/sec        136 ms
Scaleway        Paris, FR (10G)        6.60 Gbits/sec        busy        149 ms
NovoServe        North Holland, NL (40G)        1.29 Gbits/sec        1.47 Gbits/sec        144 ms
Uztelecom        Tashkent, UZ (10G)        1.08 Gbits/sec        892 Mbits/sec        234 ms
Clouvider        NYC, NY, US (10G)        busy        3.52 Gbits/sec        66.7 ms
Clouvider        Dallas, TX, US (10G)        2.74 Gbits/sec        2.49 Gbits/sec        72.3 ms
Clouvider        Los Angeles, CA, US (10G)        4.53 Gbits/sec        4.12 Gbits/sec        37.4 ms
iperf3 Network Speed Tests (IPv6):
Clouvider        London, UK (10G)        1.31 Gbits/sec        1.35 Gbits/sec        136 ms
Scaleway        Paris, FR (10G)        busy        busy        142 ms
NovoServe        North Holland, NL (40G)        1.19 Gbits/sec        1.37 Gbits/sec        144 ms
Uztelecom        Tashkent, UZ (10G)        701 Mbits/sec        307 Mbits/sec        234 ms
Clouvider        NYC, NY, US (10G)        2.75 Gbits/sec        3.51 Gbits/sec        66.5 ms
Clouvider        Dallas, TX, US (10G)        2.58 Gbits/sec        busy        72.5 ms
Clouvider        Los Angeles, CA, US (10G)        5.01 Gbits/sec        4.58 Gbits/sec        37.4 ms
Geekbench 6 Benchmark Test:
Test | Value
Single Core | 2584
Multi Core | 7432
Full Test | https://browser.geekbench.com/v6/cpu/4668483
YABS completed in 12 min 44 sec
发表于 2024-1-30 23:37:32 | 只看该作者
多少钱
 楼主| 发表于 2024-1-30 23:38:25 | 只看该作者
融合怪
1 线程测试(单核)得分:          6060 Scores
4 线程测试(多核)得分:          23809 Scores
100MB-4K Block         87.3 MB/s (21.31 IOPS, 1.20s))          115 MB/s (28092 IOPS, 0.91s)
1GB-1M Block           2.9 GB/s (2745 IOPS, 0.36s)             5.8 GB/s (5572 IOPS, 0.18s)
Read       | 442.50 MB/s (110.6k) | 3.69 GB/s    (57.7k)
Write      | 443.67 MB/s (110.9k) | 3.71 GB/s    (58.0k)
Total      | 886.18 MB/s (221.5k) | 7.41 GB/s   (115.7k)
Read       | 3.96 GB/s     (7.7k) | 4.31 GB/s     (4.2k)
Write      | 4.17 GB/s     (8.1k) | 4.60 GB/s     (4.4k)
Total      | 8.14 GB/s    (15.9k) | 8.92 GB/s     (8.7k)
以下为IPV4网络测试,若无IPV4网络则无输出
Dazn:                                  Yes (Region: US)
HotStar:                               Yes (Region: US)
Disney+:                               No
有图比 Premium:                       Yes
Amazon Prime Video:                    Yes (Region: US)
iQyi Oversea Region:                   US
Viu.com:                               No
有图比 CDN:                           Seattle, WA
Netflix Preferred CDN:                 Seattle, WA
Spotify Registration:                  Yes (Region: US)
Bing Region:                           US
Instagram Licensed Audio:              Yes
以下为IPV6网络测试,若无IPV6网络则无输出
Dazn:                                  Failed (Network Connection)
Disney+:                               No
Netflix:                               Yes (Region: US)
有图比 Premium:                       Yes
Amazon Prime Video:                    Unsupported
TVBAnywhere+:                          Failed (Network Connection)
iQyi Oversea Region:                   Failed
Viu.com:                               Failed
Steam Currency:                        Failed (Network Connection)
ChatGPT:                               Failed
Bing Region:                           US
Tiktok Region:         【US】
以下为各数据库编号,输出结果后将自带数据库来源对应的编号
欺诈分数(越低越好): 0②
abuse得分(越低越好): 0④
IP类型:
  使用类型(usage_type):hosting①  Commercial⑤  hosting⑧  hosting⑨
  公司类型(company_type):isp①  business⑧
  云服务提供商(cloud_provider):  Yes⑧
  数据中心(datacenter):  No⑥   Yes⑨
  移动网络(mobile):  No⑥
  代理(proxy):  No① ② ⑥ ⑦ ⑧ ⑨ ⑩
  扶墙(扶墙):  No① ② ⑦ ⑧
  TOR(tor):  No① ② ⑦ ⑧ ⑨
  TOR出口(tor_exit):  No⑧
  匿名代理(anonymous):  No⑦ ⑧ ⑨
  攻击方(attacker):  No⑧ ⑨
  滥用者(abuser):  No⑧ ⑨
  威胁(threat):  No⑧ ⑨
  未分配IP(bogon):  No⑧ ⑨
Google搜索可行性:YES
------以下为IPV6检测------
欺诈分数(越低越好): 0②
abuse得分(越低越好): 0④
IP类型: Commercial⑤
国家: US 城市: Spokane 服务商: AS216382 LAYER MARKETING SERVICES L.L.C
北京电信 219.141.136.12  测试超时
上海电信 202.96.209.133  电信163 [普通线路]
上海移动 211.136.112.200 测试超时
广州电信 58.60.188.222   电信163 [普通线路]
成都电信 61.139.2.69     电信163 [普通线路]
成都移动 211.137.96.205  测试超时
广州电信 58.60.188.222
3.37 ms  AS216382  美国, 华盛顿州, 利伯蒂湖, aia.us.com
1.78 ms  *  局域网
11.23 ms  AS2914  美国, 华盛顿州, 西雅图, ntt.com
11.30 ms  AS2914  美国, 华盛顿州, 西雅图, ntt.com
28.14 ms  AS2914  美国, 加利福尼亚州, 圣何塞, ntt.com
52.64 ms  AS4134  美国, 加利福尼亚州, 圣何塞, chinatelecom.com.cn, 电信
220.75 ms  AS4134  中国, 广东, 广州, chinatelecom.com.cn, 电信
218.84 ms  AS4134  中国, 广东, 深圳, chinatelecom.com.cn, 电信
217.73 ms  AS4134  中国, 广东, 深圳, chinatelecom.com.cn, 电信
广州联通 210.21.196.6
17.37 ms  AS216382  美国, 华盛顿州, 利伯蒂湖, aia.us.com
0.24 ms  *  局域网
11.20 ms  AS2914  美国, 华盛顿州, 西雅图, ntt.com
11.96 ms  AS2914  美国, 华盛顿州, 西雅图, ntt.com
11.65 ms  AS2914  美国, 华盛顿州, 西雅图, ntt.com
11.35 ms  AS701  美国, 华盛顿州, 西雅图, verizon.com
38.19 ms  *  美国, 加利福尼亚州, 洛杉矶, verizon.com
283.13 ms  AS701  美国, 加利福尼亚州, 洛杉矶, verizon.com
321.51 ms  AS4837  中国, 广东, 广州, chinaunicom.com, 联通
339.14 ms  AS4837  中国, 广东, 广州, chinaunicom.com, 联通
342.24 ms  AS17816  中国, 广东, 深圳, chinaunicom.com, 联通
352.36 ms  AS17623  中国, 广东, 深圳, chinaunicom.com, 联通
330.19 ms  AS17623  中国, 广东, 深圳, chinaunicom.com, 联通
广州移动 120.196.165.24
46.31 ms  AS216382  美国, 华盛顿州, 利伯蒂湖, aia.us.com
0.28 ms  *  局域网
11.28 ms  AS2914  美国, 华盛顿州, 西雅图, ntt.com
12.08 ms  AS2914  美国, 华盛顿州, 西雅图, ntt.com
11.81 ms  AS2914  美国, 华盛顿州, 西雅图, ntt.com
31.53 ms  AS2914  美国, 加利福尼亚州, 圣何塞, ntt.com
124.08 ms  AS2914  日本, 东京都, 东京, ntt.com
189.08 ms  AS2914  中国, 香港, ntt.com
270.96 ms  AS58453  中国, 广东, 广州, chinamobile.com, 移动
268.84 ms  AS9808  中国, 广东, 广州, chinamobile.com, 移动
270.93 ms  AS9808  中国, 广东, 广州, chinamobile.com, 移动
285.32 ms  AS9808  中国, 广东, 广州, chinamobile.com, 移动
199.06 ms  AS9808  中国, 广东, 广州, chinamobile.com, 移动
Speedtest.net    8369.55 Mbps    7310.19 Mbps    0.22     0.0%
洛杉矶           2384.70 Mbps    4842.69 Mbps    38.91    0.0%
日本东京         206.72 Mbps     6598.84 Mbps    135.57   77.3%
联通上海5G       644.28 Mbps     5099.23 Mbps    171.03   0.0%
电信Suzhou5G     1060.13 Mbps    4701.03 Mbps    178.08   NULL
电信浙江         336.76 Mbps     1015.03 Mbps    164.83   NULL
移动Chengdu      54.17 Mbps      5033.99 Mbps    464.39   9.7%
移动陕西5G       32.47 Mbps      3220.37 Mbps    235.12   NULL
总共花费      : 7 分 20 秒
时间          : Tue Jan 30 23:33:22 HKT 2024
  短链:
    https://paste.spiritlhl.net/u/UMScxb.txt
 楼主| 发表于 2024-1-30 23:40:29 | 只看该作者
10.5刀 一個月
 楼主| 发表于 2024-1-30 23:50:59 | 只看该作者
Hyperbench
——————————————————————————— HyperSpeed —————————————————————————————
         bash <(wget -qO- https://bench.im/hyperspeed)
         项目修改自: https://github.com/zq/superspeed/
   脚本更新: 2023/4/13 | 组件更新: 2023/11/1 | 组件版本: 0.17.0
  测速类型:    1. 三网测速    2. 取消测速    0. 港澳台日韩
               3. 电信节点    4. 联通节点    5. 移动节点
               6. 教育网IPv4  7. 教育网IPv6  8. 三网IPv6
  请选择测速类型(默认: 1):
  启用八线程测速[y/N](默认: N):
测速服务器信息   ↑     上传/Mbps ↓     下载/Mbps ↕ 延迟/ms ϟ 抖动/ms
电信|江苏镇江5G  ↑     37.4 正常 ↓     99.1 正常 ↕   214.4 ϟ     4.0
电信|江苏南京5G  ↑    142.7 正常 ↓    133.4 正常 ↕   175.1 ϟ    17.9
电信|安徽合肥5G  ↑    121.3 正常 ↓    138.4 正常 ↕   159.1 ϟ     6.5
电信|天津5G      ↑      4.3 正常 ↓      4.2 正常 ↕   200.0 ϟ     6.7
电信|天津        ↑     31.1 正常 ↓    173.0 正常 ↕   209.6 ϟ     5.1
电信|四川成都    ↑    102.5 正常 ↓     53.1 正常 ↕   218.8 ϟ     9.8
联通|河南郑州5G  ↑     38.4 正常 ↓     54.1 正常 ↕   249.6 ϟ    49.4
联通|福建福州    ↑      5.6 正常 ↓     47.4 正常 ↕   303.5 ϟ     8.5
移动|浙江杭州5G  ↑      3.7 正常 ↓     64.9 正常 ↕   217.2 ϟ    57.9
移动|四川成都    ↑    154.6 正常 ↓    268.6 正常 ↕   210.8 ϟ    51.9
移动|甘肃兰州    ↑     32.5 正常 ↓     20.7 正常 ↕   348.7 ϟ    28.3
电信|上海        ↑     79.9 正常 ↓      0.0 断流 ↕   161.2 ϟ    16.4
电信|甘肃兰州    ↑      0.0 取消 ↓      0.0 取消 ↕     0.0 ϟ     0.0
联通|上海5G      ↑      0.0 取消 ↓      0.0 取消 ↕     0.0 ϟ     0.0
联通|江苏无锡    ↑      0.0 取消 ↓      0.0 取消 ↕     0.0 ϟ     0.0
联通|江西南昌    ↑      0.0 失败 ↓      0.0 失败 ↕     0.0 ϟ     0.0
联通|湖南长沙5G  ↑      0.0 取消 ↓      0.0 取消 ↕     0.0 ϟ     0.0
联通|辽宁沈阳    ↑      0.0 断流 ↓      0.0 断流 ↕   386.4 ϟ    13.9
移动|北京        ↑      0.0 取消 ↓      0.0 取消 ↕     0.0 ϟ     0.0
移动|陕西西安5G  ↑      0.6 断流 ↓    301.1 正常 ↕   314.0 ϟ     6.0
发表于 2024-1-31 00:07:39 | 只看该作者
这价格     上不起
发表于 2024-1-31 00:19:23 | 只看该作者
性能不错,但这价格还是不如cc 99刀爽
发表于 2024-1-31 00:46:08 | 只看该作者
性能不错,可惜价格太贵
GMT+8, 2026-5-1 19:28 , Processed in 0.069054 second(s), 10 queries , Gzip On, MemCache On.
