查看: 1708|回复: 0
khanwebhost 要把所有 nat kvm 小鸡迁到 ovz 了
发表于 2024-1-17 03:05:51 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
discord 群发的
https://discord.com/channels/668007062109683712/1124225248414404660/1196447688141570119
  1. I hope this email finds you well. I wanted to inform you about an important update regarding our server infrastructure.
  2. We have successfully deployed all the virtual machines (VMs) on the OpenVZ node with dedicated IPv6 and NAT IPv4. This ensures better performance and stability for your services.
  3. However, please note that the client VPS hosted on the KVM node will remain online until January 20, 2024. After this date, the KVM node will be taken offline. If you have any data on the KVM node, I kindly request you to migrate it to the new OpenVZ node before the deadline to avoid any disruptions.
  4. If you need any assistance or have any questions regarding the migration, please don't hesitate to reach out to our support team. We are here to help you throughout the process.
  5. Thank you for your understanding and cooperation. We apologize for any inconvenience this may cause and appreciate your continued support.
  6. Best regards,
  7. Asad Khan
GMT+8, 2026-5-2 10:04 , Processed in 0.056959 second(s), 10 queries , Gzip On, MemCache On.
