查看: 1353|回复: 7
84 开通了,要我传真资料 =.=,我...
发表于 2012-5-26 23:04:36 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Thank you for signing up with us.
We are currently awaiting the required documentation requested from you, in order to continue processing your order, and deliver service. If you have received this email after service delivery, your service may be suspended if the required documentation is not supplied to us immediately.
----The order has been put on hold/notice status by our Fraud Prevention Dept.
In order for the order to clear this dept and be fulfilled, we require you to fill out one of the following applicable forms:
Credit Card Payments: http://burst.net/policy/ccauth.pdf
Paypal/AlertPay/Liberty Payments: http://burst.net/policy/ppauth.pdf
Check/E-Check Payments: http://burst.net/policy/ckauth.pdf
Directions are near the bottom of the applicable form, please follow them exactly.
我用paypal付之...
擦。。有没简单的办法可以解决? 求指条明路
不传的话多久会suspended我的?
有分   补充一下是vps  不是那1刀, 付完款1分钟就给我开通能login了
发表于 2012-5-26 23:07:11 | 只看该作者
我擦
参与人数 1威望 +3 收起 理由
adochina + 3 ...
发表于 2012-5-26 23:08:28 | 只看该作者
master 发表于 2012-5-26 23:07
我擦
参与人数 1威望 +3 收起 理由
adochina + 3 ...
发表于 2012-5-26 23:14:42 | 只看该作者
发表于 2012-5-26 23:25:34 | 只看该作者
你的paypal是认证的么
参与人数 1威望 +3 收起 理由
adochina + 3 是的, 亲
发表于 2012-5-26 23:56:22 | 只看该作者
那应该就是小概率事件。要不取消重来一次?
参与人数 1威望 +3 收起 理由
adochina + 3 - -
发表于 2012-5-26 23:59:44 | 只看该作者
悲剧了  会退款的  vps不要放数据了
参与人数 1威望 +5 收起 理由
adochina + 5 需要 request cancellation 吗 ?
 楼主| 发表于 2012-5-27 00:05:11 | 只看该作者
wyq1993 发表于 2012-5-26 23:59
悲剧了  会退款的  vps不要放数据了
GMT+8, 2026-4-15 15:33 , Processed in 0.118217 second(s), 14 queries , Gzip On, MemCache On.
