查看: 2160|回复: 11
抱歉。安装 AMH 失败了?
发表于 2024-1-9 16:40:33 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Libraries have been installed in:
   /usr/local/libiconv-1.16/lib
If you ever happen to want to link against installed libraries
in a given directory, LIBDIR, you must either use libtool, and
specify the full pathname of the library, or use the '-LLIBDIR'
flag during linking and do at least one of the following:
   - add LIBDIR to the 'LD_LIBRARY_PATH' environment variable
     during execution
   - add LIBDIR to the 'LD_RUN_PATH' environment variable
     during linking
   - use the '-Wl,-rpath -Wl,LIBDIR' linker flag
   - have your system administrator add LIBDIR to '/etc/ld.so.conf'
See any operating system documentation about shared libraries for
more information, such as the ld(1) and ld.so(8) manual pages.
make[2]: Leaving directory '/tmp/libiconv-1.16/libcharset/lib'
/bin/bash ./build-aux/mkinstalldirs /usr/local/libiconv-1.16/include
/bin/install -c -m 644 include/libcharset.h /usr/local/libiconv-1.16/include/libcharset.h
/bin/install -c -m 644 include/localcharset.h.inst /usr/local/libiconv-1.16/include/localcharset.h
make[1]: Leaving directory '/tmp/libiconv-1.16/libcharset'
cd lib && make install prefix='/usr/local/libiconv-1.16' exec_prefix='/usr/local/libiconv-1.16' libdir='/usr/local/libiconv-1.16/lib'
make[1]: Entering directory '/tmp/libiconv-1.16/lib'
/bin/bash ../libtool --mode=compile gcc -I. -I. -I../include -I./../include -I.. -I./..  -g -O2 -fvisibility=hidden -DLIBDIR=\"/usr/local/libiconv-1.16/lib\" -DBUILDING_LIBICONV -DBUILDING_DLL -DENABLE_RELOCATABLE=1 -DIN_LIBRARY -DINSTALLDIR=\"/usr/local/libiconv-1.16/lib\" -DNO_XMALLOC -Dset_relocation_prefix=libiconv_set_relocation_prefix -Drelocate=libiconv_relocate -Drelocate2=libiconv_relocate2 -DHAVE_CONFIG_H -c ./iconv.c
libtool: compile:  gcc -I. -I. -I../include -I./../include -I.. -I./.. -g -O2 -fvisibility=hidden -DLIBDIR=\"/usr/local/libiconv-1.16/lib\" -DBUILDING_LIBICONV -DBUILDING_DLL -DENABLE_RELOCATABLE=1 -DIN_LIBRARY -DINSTALLDIR=\"/usr/local/libiconv-1.16/lib\" -DNO_XMALLOC -Dset_relocation_prefix=libiconv_set_relocation_prefix -Drelocate=libiconv_relocate -Drelocate2=libiconv_relocate2 -DHAVE_CONFIG_H -c ./iconv.c  -fPIC -DPIC -o .libs/iconv.o
gcc: fatal error: Killed signal terminated program cc1
compilation terminated.
make[1]: *** [Makefile:82: iconv.lo] Error 1
make: *** [Makefile:52: install] Error 2
make[1]: Leaving directory '/tmp/libiconv-1.16/lib'
[Notice] libiconv-1.16 is not installed.
抱歉。安装 AMH 失败了,
如有需要帮助安装,请联系我们: https://amh.sh/bbs/forum.htm
@Amysql
发表于 2024-1-10 19:22:06 | 只看该作者
金子会发光 发表于 2024-1-10 18:29
嗯解决是解决了,就是改端口没弄懂,你会弄吗?
您好,请登录到amh面板 --> 右上角“设置” ---> 参数设置 ---> 面板HTTP端口
截图参考:https://imgse.com/i/pF9QexS
发表于 2024-1-9 17:29:25 | 只看该作者
楼主您好,这是提示相应的lib已经安装过,amh再编译安装时报错了吗?
 楼主| 发表于 2024-1-9 18:35:41 | 只看该作者
是的你知道要如何解决这个问题吗?
发表于 2024-1-9 19:16:34 | 只看该作者
上面有提示进程被Killed掉了,看服务器内存是否用满了?
与是否全新的系统安装amh,是什么配置的服务器,编译libiconv应该用不了多少内存。
 楼主| 发表于 2024-1-10 12:37:12 | 只看该作者
与是否全新的系统安装amh,是什么配置的服务器,编 ...
以破案,没有所说的128小内存可以安装AMH,换了一个256M的就成功安装上了
现在还有个问题就是要如何修改AMH管理面板8888端口方法?我看到论坛说这样操作对吗?
root@2080:~# amh SetParam amh amh_Listen 38666
[Linux] AMH 7.1
https://amh.sh
[SetParam amh]
[AMH] Please select module:
1) amh-7.1
2) libiconv-1.16
3) lnmp-3.6
4) mysql-generic-5.5
5) nginx-generic-1.24
6) php-generic-7.4
一直停留在这要如何操作?还是说还有别的方法设置端口?
发表于 2024-1-10 15:45:29 | 只看该作者
金子会发光 发表于 2024-1-9 18:35
是的你知道要如何解决这个问题吗?
看到4楼amh已经回复您。且您在5楼已经解决问题了。
 楼主| 发表于 2024-1-10 18:29:55 | 只看该作者
 楼主| 发表于 2024-1-10 19:30:43 | 只看该作者
截图参考:https://imgse. ...
蟹蟹忘记说了我的是NAT的机器只能有限的端口,所以没法登录上去设置只能用命令设置,我找到了命令:https://amh.sh/bbs/post-10717-1-1.htm#re
 楼主| 发表于 2024-1-10 19:31:52 | 只看该作者
NAT的机器设置端口方法:已解决—下面是官方的命令
GMT+8, 2026-4-17 07:51 , Processed in 0.068431 second(s), 11 queries , Gzip On, MemCache On.
