查看: 1014|回复: 1
出乔治99刀
发表于 2023-12-23 00:15:09 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
原价出,可小刀。要的PM。
#              Yet-Another-Bench-Script              #
#                     v2023-11-30                    #
# https://github.com/masonr/yet-another-bench-script #
Thu 21 Dec 2023 09:51:40 AM EST
Basic System Information:
Uptime     : 1 days, 13 hours, 52 minutes
Processor  : Intel(R) Xeon(R) CPU E5-2630 v3 @ 2.40GHz
CPU cores  : 4 @ 2399.984 MHz
AES-NI     : ? Enabled
VM-x/AMD-V : ? Enabled
RAM        : 31.3 GiB
Swap       : 16.0 GiB
Disk       : 279.4 GiB
Distro     : Debian GNU/Linux 11 (bullseye)
Kernel     : 5.10.0-23-amd64
VM Type    : KVM
IPv4/IPv6  : ? Online / ? Offline
IPv4 Network Information:
ISP        : ReadyDedis, LLC
ASN        : AS397966 ReadyDedis, LLC
Host       : ReadyDedis, LLC
Country    : United States
fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/vda1):
Read       | 303.35 MB/s  (75.8k) | 3.63 GB/s    (56.8k)
Write      | 304.15 MB/s  (76.0k) | 3.65 GB/s    (57.1k)
Total      | 607.51 MB/s (151.8k) | 7.29 GB/s   (113.9k)
Read       | 5.47 GB/s    (10.6k) | 5.29 GB/s     (5.1k)
Write      | 5.76 GB/s    (11.2k) | 5.65 GB/s     (5.5k)
Total      | 11.24 GB/s   (21.9k) | 10.95 GB/s   (10.6k)
Provider        | Location (Link)           | Send Speed      | Recv Speed      | Ping
Clouvider       | London, UK (10G)          | 771 Mbits/sec   | 863 Mbits/sec   | 66.9 ms
Scaleway        | Paris, FR (10G)           | busy            | busy            | 71.8 ms
NovoServe       | North Holland, NL (40G)   | 885 Mbits/sec   | 823 Mbits/sec   | 71.6 ms
Uztelecom       | Tashkent, UZ (10G)        | 629 Mbits/sec   | 416 Mbits/sec   | 167 ms
Clouvider       | NYC, NY, US (10G)         | 920 Mbits/sec   | 941 Mbits/sec   | 1.55 ms
Clouvider       | Dallas, TX, US (10G)      | 859 Mbits/sec   | 927 Mbits/sec   | 34.0 ms
Clouvider       | Los Angeles, CA, US (10G) | 863 Mbits/sec   | 777 Mbits/sec   | 62.6 ms
Geekbench 6 Benchmark Test:
Test            | Value
Single Core     | 1000
Multi Core      | 3027
Full Test       | https://browser.geekbench.com/v6/cpu/4081253
YABS completed in 11 min 41 sec
版本:2023.12.18
更新日志:VPS融合怪测试(集百家之长)
CPU 型号          : Intel(R) Xeon(R) CPU E5-2630 v3 @ 2.40GHz
CPU 核心数        : 4
CPU 频率          : 2399.984 MHz
CPU 缓存          : L1: 128.00 KB / L2: 512.00 KB / L3: 20.00 MB
硬盘空间          : 1.53 GiB / 279.42 GiB
启动盘路径        : /dev/vda1
内存              : 145.88 MiB / 31.35 GiB
Swap              : 0 KiB / 16.00 GiB
系统在线时间      : 0 days, 11 hour 26 min
负载              : 0.14, 0.03, 0.01
AES-NI指令集      : ? Enabled
VM-x/AMD-V支持    : ? Enabled
内核              : 5.10.0-23-amd64
TCP加速方式       : cubic
虚拟化架构        : KVM
NAT类型           : 开放型
IPV4 ASN          : AS397966 ReadyDedis, LLC
IPV4 位置         : New York City / New York / US
1 线程测试(1核)得分:                 830 Scores
4 线程测试(多核)得分:                 3196 Scores
单线程读测试:                20103.53 MB/s
单线程写测试:                14497.85 MB/s
100MB-4K Block                55.2 MB/s (13.47 IOPS, 1.90s))                89.7 MB/s (21905 IOPS, 1.17s)
1GB-1M Block                1.4 GB/s (1352 IOPS, 0.74s)                3.1 GB/s (2953 IOPS, 0.34s)
Read       | 305.12 MB/s  (76.2k) | 2.96 GB/s    (46.3k)
Write      | 305.93 MB/s  (76.4k) | 2.98 GB/s    (46.6k)
Total      | 611.05 MB/s (152.7k) | 5.94 GB/s    (92.9k)           |                      |
Read       | 3.48 GB/s     (6.7k) | 4.11 GB/s     (4.0k)
Write      | 3.66 GB/s     (7.1k) | 4.39 GB/s     (4.2k)
Total      | 7.14 GB/s    (13.9k) | 8.50 GB/s     (8.3k)
[IPv4]
连接方式: 有图比 Video Server
视频缓存节点地域: IAD(IAD30S49)
有图比识别地域: 无信息(null)
[IPv4]
您的出口IP完整解锁Netflix,支持非自制剧的观看
NF所识别的IP地域信息:美国
[IPv6]
您的网络可能没有正常配置IPv6,或者没有IPv6网络接入
[IPv4]
当前IPv4出口解锁DisneyPlus
区域:美国区
以下为IPV4网络测试,若无IPV4网络则无输出
Dazn:                                        Yes (Region: US)
HotStar:                                Yes (Region: US)
Disney+:                                Yes (Region: US)
Netflix:                                Yes (Region: US)
有图比 Premium:                        Yes
Amazon Prime Video:                        Yes (Region: US)
iQyi Oversea Region:                        US
Viu.com:                                No
有图比 CDN:                                Washington DC
Netflix Preferred CDN:                        Washington DC
Spotify Registration:                        No
Steam Currency:                        USD
Bing Region:                                US
以下为IPV6网络测试,若无IPV6网络则无输出
Tiktok Region:                【US】
以下为各数据库编号,输出结果后将自带数据库来源对应的编号
欺诈分数(越低越好): 100②
abuse得分(越低越好): 0④
IP类型:
  使用类型(usage_type):business①  Data Center/Web Hosting/Transit⑤  hosting⑧  business⑨
  公司类型(company_type):hosting①  hosting⑧
  云服务提供商(cloud_provider):  Yes⑧
  数据中心(datacenter):  No⑥ ⑨
  移动网络(mobile):  No⑥
  代理(proxy):  No① ② ⑥ ⑦ ⑧ ⑨ ⑩
  扶墙(扶墙):  No① ② ⑦ ⑧
  TOR(tor):  No① ② ⑦ ⑧ ⑨
  TOR出口(tor_exit):  No⑧
  匿名代理(anonymous):  No⑦ ⑧ ⑨
  攻击方(attacker):  No⑧ ⑨
  滥用者(abuser):  No⑧ ⑨
  威胁(threat):  No⑧ ⑨
  未分配IP(bogon):  No⑧ ⑨
Google搜索可行性:YES
Speedtest.net         925.33 Mbps         941.61 Mbps         31.20          0.0%
洛杉矶                 776.07 Mbps         816.27 Mbps         59.64          NULL
法兰克福         266.70 Mbps         930.89 Mbps         86.41          0.0%
联通WuXi         561.32 Mbps         786.30 Mbps         202.46          0.0%
联通上海5G         9.61 Mbps         9.47 Mbps         217.29          0.0%
电信浙江         256.71 Mbps         10.04 Mbps         232.08          NULL
电信Suzhou5G         363.69 Mbps         640.64 Mbps         218.02          NULL
移动Chengdu         544.49 Mbps         1043.05 Mbps         277.30          0.0%
移动杭州5G         4.59 Mbps         847.74 Mbps         275.76          1.7%
总共花费      : 6 分 56 秒
时间          : Wed Dec 20 07:32:16 EST 2023
VPS
04 VCPU
32GB DDR4
300GB SSD RAID 10
1 IPV4
Port 1Gigabit
10TB Bandwidth
New Jersey
KVM Hypervisor
$99 Year
发表于 2023-12-23 00:22:23 | 只看该作者
绑定,祝早出。
GMT+8, 2026-1-3 09:24 , Processed in 0.101532 second(s), 10 queries , Gzip On, MemCache On.
