查看: 1933|回复: 8
[疑问] 双栈VPS实现http/https IPv4转IPv6
发表于 2023-12-7 11:45:25 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
请教各位黑大大/小粉紧,webhorizon支持IPv6奈飞解锁,但家里网络只支持IPv4,我查看了X-UI,socat,stunnel都没搞明白怎么在这台鸡上实现v4转v6,真诚请教改用什么工具怎么配置。多谢多谢!
我用Layer3扶墙从家里连到了webhorizon,然后用iptables把80/443流量重定向到了本机62789端口,X-UI配置如下:
  "api": {
    "services": [
      "HandlerService",
      "LoggerService",
      "StatsService"
    "tag": "api"
  "inbounds": [
      "listen": "127.0.0.1",
      "port": 62789,
      "protocol": "dokodemo-door",
      "settings": {
        "address": "127.0.0.1"
      "tag": "api"
  "outbounds": [
      "protocol": "freedom",
      "settings": {},
      "tag": "IP-V4"
      "settings": {
          "domainStrategy": "UseIPv6"
      "tag": "IP-V6"
      "protocol": "blackhole",
      "settings": {},
      "tag": "blocked"
  "policy": {
    "system": {
      "statsInboundDownlink": true,
      "statsInboundUplink": true
  "routing": {
    "rules": [
        "type": "field",
        "outboundTag": "IP-V6",
        "domain": [
          "ipget.net",
          "geosite:netflix",
          "geosite:disney"
        "type": "field",
        "outboundTag": "IP4-out",
        "network": "udp,tcp"
        "inboundTag": [
          "api"
        "outboundTag": "api",
        "type": "field"
        "ip": [
          "geoip:private"
        "outboundTag": "blocked",
        "type": "field"
        "protocol": [
          "bittorrent"
        "type": "field"
  "stats": {}
DNS解析没问题:
# dig aaaa netflix.com
; <<>> DiG 9.18.19-1~deb12u1-Debian <<>> aaaa netflix.com
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 50182
;; flags: qr rd ra; QUERY: 1, ANSWER: 3, AUTHORITY: 0, ADDITIONAL: 1
;; OPT PSEUDOSECTION:
; EDNS: version: 0, flags:; udp: 512
;; QUESTION SECTION:
;netflix.com.                   IN      AAAA
;; ANSWER SECTION:
netflix.com.            60      IN      AAAA    2a05:d018:76c:b685:3b38:679d:2640:1ced
netflix.com.            60      IN      AAAA    2a05:d018:76c:b684:8e48:47c9:84aa:b34d
netflix.com.            60      IN      AAAA    2a05:d018:76c:b683:f711:f0cf:5cc7:b815
;; Query time: 5 msec
;; SERVER: 127.0.0.1#53(127.0.0.1) (UDP)
;; WHEN: Thu Dec 07 04:06:34 GMT 2023
;; MSG SIZE  rcvd: 124
发表于 2023-12-7 11:46:53 | 只看该作者
先这样,然后那样,就可以了
发表于 2023-12-7 11:47:07 来自手机 | 只看该作者
xui上把nf分流到v6就行了
发表于 2023-12-7 11:47:27 来自手机 | 只看该作者
Ipv6 outbound 就行啦
发表于 2023-12-7 11:47:53 | 只看该作者
v6优先(默认不需要调试
xui(v6/v4)→中转(v4)→家(v4)
发表于 2023-12-7 11:47:59 | 只看该作者
用nekoray可以实现本地ipv4访问到代理,然后通过代理的ipv6出站
发表于 2023-12-7 11:57:11 | 只看该作者
可以尝试使用NAT64实现IPv4转IPv6。
 楼主| 发表于 2023-12-7 11:58:37 | 只看该作者
谢谢各位恢复,我这样配有什么问题吗:(前提是我用扶墙从家里连到了webhorizon,然后iptables把80/443流量重定向到了本机62789端口)
  "api": {
    "services": [
      "HandlerService",
      "LoggerService",
      "StatsService"
    "tag": "api"
  "inbounds": [
      "port": 62789,
      "settings": {
      "tag": "api"
  "outbounds": [
      "settings": {},
      "tag": "IP-V4"
      "settings": {
      "tag": "IP-V6"
      "settings": {},
      "tag": "blocked"
  "policy": {
    "system": {
  "routing": {
    "rules": [
        "type": "field",
        "domain": [
          "ipget.net",
          "geosite:netflix",
          "geosite:disney"
        "type": "field",
        "inboundTag": [
          "api"
        "type": "field"
        "ip": [
          "geoip:private"
        "type": "field"
        "protocol": [
          "bittorrent"
        "type": "field"
  "stats": {}
DNS解析没问题:
;; Got answer:
;; ANSWER SECTION:
 楼主| 发表于 2023-12-7 12:40:53 | 只看该作者
配置补到主贴了,请指教
GMT+8, 2026-4-26 14:48 , Processed in 0.062150 second(s), 10 queries , Gzip On, MemCache On.
