查看: 2058|回复: 12
坑爹啊,申请IP怎么能这么麻烦呢,求帮助
发表于 2012-5-17 22:52:26 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Hello,
To expand your block we need a list of all the current IP's on that server, who is using them, and why they are being used.  Only 80% has to pass justification to expand your block but we need to know what your doing with them.  Without this information we can't give out more IP's.  Also something you need to be aware of, SEO reasons for ip usage will *not* be accepted.  If you want a single IP for a single website the only acceptable ARIN justification that we know of is SSL certificates.  If you have a site on a single IP without an SSL certificate, get one before you submit your justification.  Otherwise it will be rejected.  Once you have your currant usage justified we also need to know what your intending to use the additional ips for, this does not need to be detailed, just a general explanation.
Here is an example of how we would like your current usage to be justified.
IP -- Name of person/website -- Technical reason an IP is needed
192.168.1.2 -- server01.example.com -- Physical Server
192.168.1.3 -- hostnameofavps.com -- VPS server
192.168.1.4 -- ns1.example.com -- authoritative nameserver
192.168.1.5 -- secure.example.com -- SSL Cert
这机房一台服务器只给我一个IP。。。。申请IP居然这么麻烦,看了下机房的AS,才5K多的IP,难怪啊...
发表于 2012-5-17 22:52:47 | 只看该作者
都这样 IP都难下
发表于 2012-5-17 22:53:34 | 只看该作者
给钱还这么不乐意吗
发表于 2012-5-17 22:57:07 来自手机 | 只看该作者
发表于 2012-5-17 23:00:12 | 只看该作者
自己去ripe或者arin申请一大坨IP 让机房做广播
发表于 2012-5-17 23:39:15 | 只看该作者
这机房SB吧, ARIN从来没要求不能一个IP做一个站, 只需要有网站域名地址就行, 不需要什么SSL
 楼主| 发表于 2012-5-18 07:44:09 | 只看该作者
domin 发表于 2012-5-17 23:39
这机房SB吧, ARIN从来没要求不能一个IP做一个站, 只需要有网站域名地址就行, 不需要什么SSL ...
那我骂这机房去。。。反正我还没付款就给机器了
发表于 2012-5-18 08:22:52 | 只看该作者
发表于 2012-5-18 08:25:58 | 只看该作者
我这边申请IP很简单
只要IP对应域名 一条一个就可以了 不需要理由...
蛮好下的....而且不到1刀
发表于 2012-5-18 08:27:32 | 只看该作者
zlpd 发表于 2012-5-18 08:25
我这边申请IP很简单
对的, 这才是正确的做法. 那些要SSL的其实就是乱搞嘛.
GMT+8, 2026-4-15 21:55 , Processed in 0.162941 second(s), 13 queries , Gzip On, MemCache On.
