查看: 1121|回复: 2
黑五MLNL荷兰大盘鸡开机了,发个简单评测记录下。
发表于 2023-12-3 20:08:53 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
买的5刀/月
2+ vCPU Cores
500GB+ HDD Storage
2GB+ RAM
5TB+ Bandwidth
1Gbps Network
1 x Dedicated IP
Quantity: 20 + More
$5+/m
Promo code: LETBF23-MLNL-BAE50-DBL (50% + 2 x double resources)
Promo code: LETBF23-MLNL-BAE50 (50% + 1 x double resources)
全球测速
  1. ---------------------------------------------------------------------------
  2. Region: Global  https://bench.monster v1.7.3 2023-10-27
  3. Usage : curl -sL bench.monster | bash -s -- -Global
  4. ---------------------------------------------------------------------------
  5. OS           : Debian GNU/Linux 12 (64 Bit)
  6. Virt/Kernel  : KVM / 6.6.1-bbrplus
  7. CPU Model    : Intel(R) Xeon(R) CPU E5-2650L v3 @ 1.80GHz
  8. CPU Cores    : 2 @ 1797.896 MHz x86_64 30720 KB Cache
  9. CPU Flags    : AES-NI Enabled & VM-x/AMD-V Disabled
  10. Load Average : 0.04, 0.10, 0.03
  11. Total Space  : 981G (1.9G ~1% used)
  12. Total RAM    : 3931 MB (312 MB + 191 MB Buff in use)
  13. Total SWAP   : 4094 MB (0 MB in use)
  14. IPv4/IPv6    : ✔ Online / ❌ Offline
  15. Uptime       : 0 days 0:9
  16. ---------------------------------------------------------------------------
  17. Location     : Germany, Frankfurt (Hesse)
  18. ASN & ISP    : AS3356, Level 3 Communications, Inc. / Private Customer
  19. ---------------------------------------------------------------------------
  20. ## Geekbench v6 CPU Benchmark:
  21.   Single Core : 722  (GOOD)
  22.    Multi Core : 1298
  23. ## IO Test
  24. CPU Speed:
  25.     bzip2     :  74.3 MB/s
  26.    sha256     : 121 MB/s
  27.    md5sum     : 328 MB/s
  28. RAM Speed:
  29.    Avg. write : 1638.4 MB/s
  30.    Avg. read  : 4881.1 MB/s
  31. Disk Speed:
  32.    1st run    : 100 MB/s
  33.    2nd run    : 106 MB/s
  34.    3rd run    : 89.5 MB/s
  35.    -----------------------
  36.    Average    : 98.5 MB/s
  37. ## Global Speedtest.net
  38. Location                       Upload           Download         Ping
  39. ---------------------------------------------------------------------------
  40. Nearby                         919.06 Mbit/s    2385.30 Mbit/s   7.463 ms
  41. ---------------------------------------------------------------------------
  42. USA, New York (Hivelocity)     221.54 Mbit/s    602.22 Mbit/s   ping error!
  43. USA, Chicago (Windstream)      166.26 Mbit/s    457.18 Mbit/s   108.516 ms
  44. USA, Houston (Comcast)         152.43 Mbit/s    206.66 Mbit/s   115.882 ms
  45. USA, Miami (Comcast)           156.38 Mbit/s    459.96 Mbit/s   110.023 ms
  46. USA, Los Angeles (Windstream)  109.82 Mbit/s    71.25 Mbit/s    161.234 ms
  47. UK, London (toob Ltd)          676.73 Mbit/s    876.77 Mbit/s     8.539 ms
  48. France, Paris (Orange)         562.06 Mbit/s    1380.70 Mbit/s   13.082 ms
  49. Germany, Berlin (DNS:NET)      579.27 Mbit/s    1688.91 Mbit/s   22.485 ms
  50. Spain, Madrid (MasMovil)       355.72 Mbit/s    755.85 Mbit/s    32.638 ms
  51. Italy, Rome (Unidata)          481.09 Mbit/s    1190.90 Mbit/s   34.861 ms
  52. India, Mumbai (Tatasky)        138.62 Mbit/s    372.33 Mbit/s   131.070 ms
  53. Singapore (StarHub)            112.98 Mbit/s    229.61 Mbit/s   159.206 ms
  54. Japan, Tsukuba (SoftEther)     26.20 Mbit/s     80.85 Mbit/s    246.195 ms
  55. Australia, Sydney (Optus)      11.78 Mbit/s     26.80 Mbit/s    405.420 ms
  56. RSA, Randburg (Cool Ideas)     104.12 Mbit/s    168.67 Mbit/s   167.921 ms
  57. Brazil, Sao Paulo (Criare)     48.85 Mbit/s     147.73 Mbit/s   221.383 ms
  58. ---------------------------------------------------------------------------
  59. Finished in : 17 min 41 sec
  60. Timestamp   : 2023-12-03 12:03:23 GMT
  61. Saved in    : /root/speedtest.log
YABS跑分
  1. Basic System Information:
  3. Uptime     : 0 days, 0 hours, 28 minutes
  4. Processor  : Intel(R) Xeon(R) CPU E5-2650L v3 @ 1.80GHz
  5. CPU cores  : 2 @ 1797.896 MHz
  6. AES-NI     : ✔ Enabled
  7. VM-x/AMD-V : ❌ Disabled
  8. RAM        : 3.8 GiB
  9. Swap       : 4.0 GiB
  10. Disk       : 980.2 GiB
  11. Distro     : Debian GNU/Linux 12 (bookworm)
  12. Kernel     : 6.6.1-bbrplus
  13. VM Type    : KVM
  15. IPv4 Network Information:
  17. ISP        : Level 3 Communications, Inc.
  18. ASN        : AS3356 Level 3 Parent, LLC
  19. Host       : Private Customer
  20. Location   : Frankfurt, Hesse (HE)
  21. Country    : Germany
  22. fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/vda1):
  23. ---------------------------------
  24. Block Size | 4k            (IOPS) | 64k           (IOPS)
  25.   ------   | ---            ----  | ----           ----
  26. Read       | 1.68 MB/s      (420) | 10.43 MB/s     (163)
  27. Write      | 1.70 MB/s      (426) | 10.93 MB/s     (170)
  28. Total      | 3.38 MB/s      (846) | 21.36 MB/s     (333)
  29.            |                      |
  30. Block Size | 512k          (IOPS) | 1m            (IOPS)
  32. Read       | 46.16 MB/s      (90) | 56.86 MB/s      (55)
  33. Write      | 48.80 MB/s      (95) | 61.29 MB/s      (59)
  34. Total      | 94.97 MB/s     (185) | 118.15 MB/s    (114)
  35. Geekbench 6 Benchmark Test:
  36. ---------------------------------
  37. Test            | Value
  38.                 |
  39. Single Core     | 732
  40. Multi Core      | 1307
  41. Full Test       | https://browser.geekbench.com/v6/cpu/3834973
回程线路
  1. 目标:北京电信[219.141.136.12]   回程线路:电信163
  2. 目标:北京联通[202.106.50.1]     回程线路:联通169
  3. 目标:北京移动[221.179.155.161]  回程线路:移动CMI
  4. 目标:上海电信[202.96.209.133]   回程线路:电信163
  5. 目标:上海联通[210.22.97.1]      回程线路:联通AS4837
  6. 目标:上海移动[211.136.112.200]  回程线路:移动CMI
  7. 目标:深圳电信[58.60.188.222]    回程线路:电信163
  8. 目标:深圳联通[210.21.196.6]     回程线路:联通169
  9. 目标:深圳移动[120.196.165.24]   回程线路:移动CMI
三网测速(多线程)
  1. ——————————————————————————— HyperSpeed —————————————————————————————
  2.          bash <(wget -qO- https://bench.im/hyperspeed)
  3.          项目修改自: https://github.com/zq/superspeed/
  4.    脚本更新: 2023/4/13 | 组件更新: 2023/11/1 | 组件版本: 0.17.0
  5. ————————————————————————————————————————————————————————————————————
  6.   测速类型:    1. 三网测速    2. 取消测速    0. 港澳台日韩
  7.                3. 电信节点    4. 联通节点    5. 移动节点
  8.                6. 教育网IPv4  7. 教育网IPv6  8. 三网IPv6
  9.   请选择测速类型(默认: 1): 1
  10.   启用八线程测速[y/N](默认: N): y
  11. ————————————————————————————————————————————————————————————————————
  12. 测速服务器信息   ↑     上传/Mbps ↓     下载/Mbps ↕ 延迟/ms ϟ 抖动/ms
  13. ————————————————————————————————————————————————————————————————————
  14. 电信|上海        ↑    220.0 正常 ↓    793.8 正常 ↕   259.4 ϟ    63.1
  15. 电信|江苏镇江5G  ↑    450.5 正常 ↓    555.3 正常 ↕   264.3 ϟ     9.1
  16. 电信|江苏南京5G  ↑    197.1 正常 ↓    497.0 正常 ↕   229.1 ϟ    35.5
  17. 电信|安徽合肥5G  ↑    416.3 正常 ↓    342.3 正常 ↕   255.9 ϟ    14.3
  18. 电信|天津5G      ↑    224.9 正常 ↓     93.8 正常 ↕   227.7 ϟ    27.4
  19. 电信|天津        ↑    284.8 正常 ↓    918.0 正常 ↕   228.5 ϟ    16.4
  20. 电信|四川成都    ↑     86.2 正常 ↓     12.0 正常 ↕   301.1 ϟ    34.7
  21. 联通|河南郑州5G  ↑    596.1 正常 ↓    477.0 正常 ↕   229.5 ϟ    15.9
  22. 联通|辽宁沈阳    ↑    153.2 正常 ↓     61.1 正常 ↕   234.3 ϟ    17.0
  23. 联通|福建福州    ↑    659.4 正常 ↓    779.6 正常 ↕   229.9 ϟ    16.8
  24. 移动|浙江杭州5G  ↑     17.7 正常 ↓    390.0 正常 ↕   238.9 ϟ   186.4
  25. 移动|陕西西安5G  ↑    168.1 正常 ↓    688.3 正常 ↕   294.6 ϟ    19.0
  26. 移动|四川成都    ↑    743.8 正常 ↓    960.2 正常 ↕   206.9 ϟ    15.4
  27. --------------------------------------------------------------------
  28. 电信|甘肃兰州    ↑      0.0 取消 ↓      0.0 取消 ↕     0.0 ϟ     0.0
  29. 联通|上海5G      ↑      0.0 取消 ↓      0.0 取消 ↕     0.0 ϟ     0.0
  30. 联通|江苏无锡    ↑      0.0 断流 ↓      0.0 断流 ↕   206.4 ϟ    27.8
  31. 联通|江西南昌    ↑      0.0 失败 ↓      0.0 失败 ↕     0.0 ϟ     0.0
  32. 联通|湖南长沙5G  ↑      0.0 取消 ↓      0.0 取消 ↕     0.0 ϟ     0.0
  33. 移动|北京        ↑      0.0 取消 ↓      0.0 取消 ↕     0.0 ϟ     0.0
  34. 移动|甘肃兰州    ↑      0.0 断流 ↓      1.4 正常 ↕   354.9 ϟ     5.9
  35. ————————————————————————————————————————————————————————————————————
  36.   八线程测试完成, 本次测速耗时: 13 分 1 秒
  37.   当前时间: 2023-12-03 20:50:12+08:00
发表于 2023-12-3 20:11:04 | 只看该作者
看起来感觉性价比不高
 楼主| 发表于 2023-12-3 20:12:18 | 只看该作者
ycdxsb 发表于 2023-12-3 20:11
看起来感觉性价比不高
也不知道性价比,月付的入了看看。
GMT+8, 2026-5-2 07:42 , Processed in 0.065329 second(s), 10 queries , Gzip On, MemCache On.
