查看: 2984|回复: 11
[疑问] 甲骨文首尔amd新开得机器又限制50Mbps?
发表于 2023-11-29 17:54:05 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
瞎折腾了一台. 失联
新建dd后测速发现变成50了
发表于 2023-11-29 17:55:22 | 只看该作者
听说现在开的amd机器都是50m
 楼主| 发表于 2023-11-29 17:58:52 | 只看该作者
  1. -------------------- A Bench.sh Script By Teddysun -------------------
  2. Version            : v2023-10-15
  3. Usage              : wget -qO- bench.sh | bash
  4. ----------------------------------------------------------------------
  5. CPU Model          : AMD EPYC 7551 32-Core Processor
  6. CPU Cores          : 2 [url=home.php?mod=space&uid=175]@[/url] 1996.247 MHz
  7. CPU Cache          : 512 KB
  8. AES-NI             : ✓ Enabled
  9. VM-x/AMD-V         : ✗ Disabled
  10. Total Disk         : 48.9 GB (2.8 GB Used)
  11. Total Mem          : 955.4 MB (460.9 MB Used)
  12. Total Swap         : 976.0 MB (0 Used)
  13. System uptime      : 0 days, 0 hour 11 min
  14. Load average       : 0.05, 0.12, 0.05
  15. OS                 : Debian GNU/Linux 12
  16. Arch               : x86_64 (64 Bit)
  17. Kernel             : 6.1.0-13-amd64
  18. TCP CC             : bbr
  19. Virtualization     : KVM
  20. IPv4/IPv6          : ✓ Online / ✗ Offline
  21. Organization       : AS31898 Oracle Corporation
  22. Location           : Paripark / KR
  23. Region             : Seoul
  24. ----------------------------------------------------------------------
  25. I/O Speed(1st run) : 54.3 MB/s
  26. I/O Speed(2nd run) : 51.0 MB/s
  27. I/O Speed(3rd run) : 51.5 MB/s
  28. I/O Speed(average) : 52.3 MB/s
  29. ----------------------------------------------------------------------
  30. Node Name        Upload Speed      Download Speed      Latency
  31. Speedtest.net    48.04 Mbps        49.02 Mbps          24.39 ms
  32. Los Angeles, US  50.86 Mbps        50.22 Mbps          131.96 ms
  33. Dallas, US       52.01 Mbps        50.44 Mbps          188.27 ms
  34. Montreal, CA     49.04 Mbps        50.45 Mbps          209.10 ms
  35. Paris, FR        49.08 Mbps        54.64 Mbps          298.63 ms
  36. Amsterdam, NL    49.53 Mbps        48.86 Mbps          304.97 ms
  37. Shanghai, CN     48.73 Mbps        48.84 Mbps          54.82 ms
  38. Chongqing, CN    48.82 Mbps        52.26 Mbps          227.96 ms
  39. Hongkong, CN     48.51 Mbps        48.82 Mbps          60.87 ms
  40. Mumbai, IN       51.03 Mbps        50.82 Mbps          125.87 ms
  41. Singapore, SG    52.74 Mbps        49.59 Mbps          86.41 ms
  42. Tokyo, JP        48.81 Mbps        48.74 Mbps          83.77 ms
  43. ----------------------------------------------------------------------
  44. Finished in        : 6 min 24 sec
  45. Timestamp          : 2023-11-29 04:58:07 EST
  46. ----------------------------------------------------------------------
发表于 2023-11-29 17:59:44 | 只看该作者
可以试试新开个ARM,好像还没限制。
发表于 2023-11-29 18:00:14 | 只看该作者
希望ARM也能限速50M,这样东京应该就能正常用了
发表于 2023-11-29 18:00:19 | 只看该作者
是的。失联有很多方法可以救。
发表于 2023-11-29 18:02:07 | 只看该作者
开arm就行了,首尔随便开
 楼主| 发表于 2023-11-29 18:04:08 | 只看该作者
ngnw 发表于 2023-11-29 18:02
开arm就行了,首尔随便开
现在 不能注册首尔了 资源随便开了?
发表于 2023-11-29 18:07:25 | 只看该作者
开arm就行了
发表于 2023-11-29 18:15:03 来自手机 | 只看该作者
ggoo 发表于 2023-11-29 18:04
现在 不能注册首尔了 资源随便开了?
可以开,其他区才需要运气抢货
GMT+8, 2026-4-16 20:46 , Processed in 0.061958 second(s), 8 queries , Gzip On, MemCache On.
