查看: 1619|回复: 7
[美国VPS] xray配置请教
发表于 2023-11-29 03:05:56 来自手机 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
原本的xray配置是netflix流量走新加坡小鸡,现在需要加一条disney的流量走这本机的v6出,不走新加坡小鸡,自己改了几次都是改崩了,有没有大佬指导一下
  "api": {
    "services": [
      "HandlerService",
      "LoggerService",
      "StatsService"
    "tag": "api"
  "inbounds": [
    "listen": "127.0.0.1",
    "port": 30000,
    "protocol": "socks",
    "sniffing": {
        "enabled": true,
        "destOverride": ["http", "tls"]
  "outbounds": [
      "protocol": "freedom",
      "settings": {}
      "tag": "netflix_proxy",
      "protocol": "shadowsocks",
      "settings": {
        "servers": [
            "address": "xxxx.新加坡小鸡.xxx",
            "method": "aes-256-gcm",
            "ota": false,
            "password": "4xxx/xxxxxxxxxxxx",
            "port": 5xxx0,
            "level": 1
      "streamSettings": {
        "network": "tcp"
      "mux": {
        "enabled": false,
        "concurrency": -1
      "protocol": "blackhole",
      "settings": {},
      "tag": "blocked"
  "policy": {
    "levels": {
      "0": {
        "handshake": 10,
        "connIdle": 100,
        "uplinkOnly": 2,
        "downlinkOnly": 3,
        "statsUserUplink": true,
        "statsUserDownlink": true,
        "bufferSize": 10240
    "system": {
      "statsInboundDownlink": true,
      "statsInboundUplink": true
  "routing": {
    "rules": [
    "type": "field",
    "outboundTag": "netflix_proxy",
    "domain": [
        "geosite:netflix"
        "inboundTag": [
          "api"
        "outboundTag": "api",
        "type": "field"
        "ip": [
          "geoip:private"
        "outboundTag": "blocked",
        "type": "field"
        "protocol": [
          "bittorrent"
        "type": "field"
  "stats": {}
发表于 2023-11-29 03:28:17 | 只看该作者
ipv4还是ipv6出栈要在落地机上配置,中转机控制不了这个
 楼主| 发表于 2023-11-29 06:02:45 | 只看该作者
前面稀里糊涂需求写错了,应该是netflix由新加坡小鸡中转,disney本机v6,这个怎么改啊
 楼主| 发表于 2023-11-29 06:25:44 来自手机 | 只看该作者
发表于 2023-11-29 06:36:24 | 只看该作者
outbounds里添加一个tag,配置"domainStrategy": "UseIPv6",routing里通过geosite的迪士尼,流量引入那个tag就行了
 楼主| 发表于 2023-11-29 06:46:33 来自手机 | 只看该作者
wuxudd 发表于 2023-11-29 06:36
outbounds里添加一个tag,配置"domainStrategy": "UseIPv6",routing里通过geosite的迪士尼,流量引入那个t ...
我再试试
发表于 2023-11-29 07:53:44 | 只看该作者
迪斯尼走v6就加这个"domainStrategy": "UseIPv6",
发表于 2023-11-29 08:27:03 | 只看该作者
直接面板走起啊,何须麻烦   https://github.com/FranzKafkaYu/x-ui
GMT+8, 2026-4-21 22:40 , Processed in 0.063610 second(s), 9 queries , Gzip On, MemCache On.
