查看: 955|回复: 7
QN机房罗马尼亚神姬,锐龙5950X搭配G口10T流量
发表于 2023-11-28 22:01:20 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
猜猜实际上是哪里的
  3. #                     v2023-11-24                    #
  6. Tue Nov 28 11:32:14 GMT 2023
  7. Basic System Information:
  9. Uptime     : 0 days, 4 hours, 46 minutes
  10. Processor  : AMD Ryzen 9 5950X 16-Core Processor
  11. CPU cores  : 1 @ 3393.622 MHz
  12. AES-NI     : ✔ Enabled
  13. VM-x/AMD-V : ✔ Enabled
  14. RAM        : 103.4 MiB
  15. Swap       : 128.0 MiB
  16. Disk       : 14.6 GiB
  17. Distro     : Ubuntu 18.04 LTS
  18. Kernel     : 4.15.0-20-generic
  19. VM Type    : KVM
  20. IPv4/IPv6  : ✔ Online / ❌ Offline
  21. IPv4 Network Information:
  23. ISP        : QuadraNet Enterprises LLC
  24. ASN        : AS8100 QuadraNet Enterprises LLC
  25. Host       : Virtual Machine Solutions LLC
  26. Location   : Bucharest, București (B)
  27. Country    : Romania
  28. fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/vda1):
  32. Read       | 454.31 MB/s (113.5k) | 522.38 MB/s   (8.1k)
  33. Write      | 455.51 MB/s (113.8k) | 525.13 MB/s   (8.2k)
  34. Total      | 909.82 MB/s (227.4k) | 1.04 GB/s    (16.3k)
  38. Read       | 1.02 GB/s     (2.0k) | 193.49 MB/s    (188)
  39. Write      | 1.08 GB/s     (2.1k) | 206.38 MB/s    (201)
  40. Total      | 2.10 GB/s     (4.1k) | 399.87 MB/s    (389)
  45. Clouvider       | London, UK (10G)          | 252 Mbits/sec   | 62.8 Mbits/sec  | 100 ms
  46. Scaleway        | Paris, FR (10G)           | busy            | busy            | 104 ms
  47. NovoServe       | North Holland, NL (40G)   | 194 Mbits/sec   | 119 Mbits/sec   | 117 ms
  48. Uztelecom       | Tashkent, UZ (10G)        | 101 Mbits/sec   | 55.0 Mbits/sec  | 199 ms
  49. Clouvider       | NYC, NY, US (10G)         | 884 Mbits/sec   | 166 Mbits/sec   | 27.1 ms
  50. Clouvider       | Dallas, TX, US (10G)      | 152 Mbits/sec   | 64.1 Mbits/sec  | 145 ms
  51. Clouvider       | Los Angeles, CA, US (10G) | 375 Mbits/sec   | 74.1 Mbits/sec  | 64.3 ms
  52. Geekbench test failed and low memory was detected. Add at least 1GB of SWAP or use GB4 instead (higher compatibility with low memory systems).
  53. YABS completed in 5 min 54 sec
发表于 2023-11-28 22:04:30 来自手机 | 只看该作者
看延迟是芝加哥?
发表于 2023-11-28 22:04:37 | 只看该作者
Buffalo.
发表于 2023-11-28 22:05:54 | 只看该作者
vir?是不是盲盒
发表于 2023-11-28 22:07:43 | 只看该作者
应该就是vir盲盒了,128m内存神鸡吗
发表于 2023-11-28 22:19:47 | 只看该作者
103.4 MiB? 咋还给你缩水了
发表于 2023-11-28 22:22:16 | 只看该作者
胖子开上兰博基尼,购买盲盒的mjj都有责任
发表于 2023-11-28 23:38:58 来自手机 | 只看该作者
128M内存 怎么愉快玩耍
GMT+8, 2025-12-25 12:57 , Processed in 0.061989 second(s), 9 queries , Gzip On, MemCache On.
