查看: 4059|回复: 28
[美国VPS] 斯巴达25$ 1T hdd大盘鸡 只测mjj来评
发表于 2023-11-28 04:04:17 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
可恶的斯巴达又是凌晨两三点放鸡(隔了一个太平洋,没办法)
运气好 捡漏了,一共十台
  1. SpartanHost: $25/yr 1TB HDD KVM VPS in Dallas
  2. 1GB RAM
  3. 1 vCore CPU (Intel E5-2690 v4)
  4. 1TB raid 10 HDD disk space
  5. 3TB bandwidth [url=home.php?mod=space&uid=175]@[/url] 10Gb/s shared
  6. Location: Dallas, TX
  7. Quantity: 10
  1. YABS测试:
  2. Basic System Information:
  3. ---------------------------------
  4. Uptime     : 0 days, 0 hours, 2 minutes
  5. Processor  : Intel(R) Xeon(R) CPU E5-2690 v4 @ 2.60GHz
  6. CPU cores  : 1 @ 2599.988 MHz
  7. AES-NI     : ✔ Enabled
  8. VM-x/AMD-V : ✔ Enabled
  9. RAM        : 964.6 MiB
  10. Swap       : 511.0 MiB
  11. Disk       : 983.7 GiB
  12. Distro     : Debian GNU/Linux 11 (bullseye)
  13. Kernel     : 5.10.0-22-amd64
  14. VM Type    : KVM
  15. IPv4/IPv6  : ✔ Online / ✔ Online
  16. IPv6 Network Information:
  17. ---------------------------------
  18. ISP        : Spartan Host LLC
  19. ASN        : AS50131 Spartan Host Ltd
  20. Host       : Spartan Host Ltd
  21. Location   : Dallas, Texas (TX)
  22. Country    : United States
  23. fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/sda1):
  25. Block Size | 4k            (IOPS) | 64k           (IOPS)
  26.   ------   | ---            ----  | ----           ----
  27. Read       | 140.61 MB/s  (35.1k) | 1.42 GB/s    (22.2k)
  28. Write      | 140.99 MB/s  (35.2k) | 1.43 GB/s    (22.4k)
  29. Total      | 281.60 MB/s  (70.4k) | 2.86 GB/s    (44.7k)
  30.            |                      |
  31. Block Size | 512k          (IOPS) | 1m            (IOPS)
  33. Read       | 2.30 GB/s     (4.5k) | 3.17 GB/s     (3.1k)
  34. Write      | 2.42 GB/s     (4.7k) | 3.38 GB/s     (3.3k)
  35. Total      | 4.73 GB/s     (9.2k) | 6.56 GB/s     (6.4k)
  36. iperf3 Network Speed Tests (IPv4):
  37. ---------------------------------
  38. Provider        | Location (Link)           | Send Speed      | Recv Speed      | Ping
  39. -----           | -----                     | ----            | ----            | ----
  40. Clouvider       | London, UK (10G)          | 1.47 Gbits/sec  | 639 Mbits/sec   | 104 ms
  41. Scaleway        | Paris, FR (10G)           | busy            | busy            | 113 ms
  42. NovoServe       | North Holland, NL (40G)   | busy            | busy            | --
  43. Uztelecom       | Tashkent, UZ (10G)        | 15.3 Mbits/sec  | busy            | 245 ms
  44. Clouvider       | NYC, NY, US (10G)         | 1.08 Gbits/sec  | 1.19 Gbits/sec  | 37.9 ms
  45. Clouvider       | Dallas, TX, US (10G)      | 1.48 Gbits/sec  | 1.26 Gbits/sec  | 3.05 ms
  46. Clouvider       | Los Angeles, CA, US (10G) | 2.30 Gbits/sec  | 1.26 Gbits/sec  | 30.9 ms
  47. iperf3 Network Speed Tests (IPv6):
  48. ---------------------------------
  49. Provider        | Location (Link)           | Send Speed      | Recv Speed      | Ping
  50. -----           | -----                     | ----            | ----            | ----
  51. Clouvider       | London, UK (10G)          | 1.46 Gbits/sec  | 1.48 Gbits/sec  | 104 ms
  52. Scaleway        | Paris, FR (10G)           | 1.30 Gbits/sec  | busy            | 111 ms
  53. NovoServe       | North Holland, NL (40G)   | 1.44 Gbits/sec  | 312 Mbits/sec   | 116 ms
  54. Uztelecom       | Tashkent, UZ (10G)        | busy            | 297 Mbits/sec   | 245 ms
  55. Clouvider       | NYC, NY, US (10G)         | 3.46 Gbits/sec  | busy            | 37.8 ms
  56. Clouvider       | Dallas, TX, US (10G)      | 8.33 Gbits/sec  | 7.64 Gbits/sec  | 0.512 ms
  57. Clouvider       | Los Angeles, CA, US (10G) | 2.16 Gbits/sec  | busy            | 31.2 ms
  58. Geekbench 5 Benchmark Test:
  59. ---------------------------------
  60. Test            | Value
  61.                 |
  62. Single Core     | 725
  63. Multi Core      | 688
发表于 2023-11-28 04:12:28 来自手机 | 只看该作者
taotao 发表于 2023-11-28 04:07
分享下我的抢购历程:第一次抢到了挂代理下单,结果风控。开工单,刚客服,没用
然后砍单,捡漏了。真的不 ...
因为今年没啥MJJ关注斯巴达,所以你能买到,换做去年和前年,你连斯巴达官网都挤不进去。。。。。
发表于 2023-11-28 04:06:50 | 只看该作者
可恶啊,这能给你捡到
 楼主| 发表于 2023-11-28 04:07:42 | 只看该作者
然后砍单,捡漏了。真的不能挂代理,斯巴达99%风控,直连下单就很丝滑。
还有就是ip更换了之后,网站会立马登出账号
所以尽量保持全程都是直连 无代理
 楼主| 发表于 2023-11-28 04:09:17 | 只看该作者
还有请教mjj,服务商是怎么检测代理之类的,如果代理用Tun模式能避开检测吗
发表于 2023-11-28 04:10:47 | 只看该作者
斯巴达风控我香港直接过的根本就没99%风控
感谢,HK的能直接下。我之前都是SG/US 可能跑太远了  发表于 2023-11-28 04:14
 楼主| 发表于 2023-11-28 04:11:39 | 只看该作者
NRV 发表于 2023-11-28 04:06
可恶啊,这能给你捡到
功夫不负有心人,我一边刚客服,一边F5  可算抢到了
 楼主| 发表于 2023-11-28 04:12:51 | 只看该作者
很疑惑,可能注册ip的关系吧
我一会儿试试hk ip
发表于 2023-11-28 04:14:43 | 只看该作者
taotao 发表于 2023-11-28 04:12
很疑惑,可能注册ip的关系吧
我一会儿试试hk ip
浏览器 有指纹, websocket能看到你真实的IP
GMT+8, 2026-4-23 05:25 , Processed in 0.065339 second(s), 12 queries , Gzip On, MemCache On.
