查看: 1099|回复: 3
hostslick 35€ 1T fio测试
发表于 2023-11-27 09:56:51 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
  1. [root@mx ~]# fio --name=test --ioengine=sync --iodepth=1 --rw=randwrite --bs=4k --size=1G --numjobs=1 --time_based --runtime=5m --ramp_time=5s
  2. test: (g=0): rw=randwrite, bs=(R) 4096B-4096B, (W) 4096B-4096B, (T) 4096B-4096B, ioengine=sync, iodepth=1
  3. fio-3.7
  4. Starting 1 process
  5. test: Laying out IO file (1 file / 1024MiB)
  6. Jobs: 1 (f=1): [w(1)][100.0%][r=0KiB/s,w=0KiB/s][r=0,w=0 IOPS][eta 00m:00s]
  7. test: (groupid=0, jobs=1): err= 0: pid=16827: Sun Nov 26 20:46:08 2023
  8.   write: IOPS=6049, BW=23.6MiB/s (24.8MB/s)(7147MiB/302453msec)
  9.     clat (nsec): min=1132, max=6140.2M, avg=77681.52, stdev=17430450.17
  10.      lat (nsec): min=1353, max=6140.2M, avg=77915.79, stdev=17430452.22
  11.     clat percentiles (nsec):
  12.      |  1.00th=[    1432],  5.00th=[    1496], 10.00th=[    1528],
  13.      | 20.00th=[    1608], 30.00th=[    1656], 40.00th=[    1704],
  14.      | 50.00th=[    1752], 60.00th=[    1816], 70.00th=[    1912],
  15.      | 80.00th=[    2040], 90.00th=[    2320], 95.00th=[    2896],
  16.      | 99.00th=[    5280], 99.50th=[    7776], 99.90th=[ 6848512],
  17.      | 99.95th=[ 8290304], 99.99th=[12255232]
  18.    bw (  KiB/s): min=    8, max=1185496, per=100.00%, avg=160820.30, stdev=262275.47, samples=91
  19.    iops        : min=    2, max=296374, avg=40205.07, stdev=65568.87, samples=91
  20.   lat (usec)   : 2=77.52%, 4=20.57%, 10=1.54%, 20=0.20%, 50=0.01%
  21.   lat (usec)   : 100=0.01%, 250=0.01%
  22.   lat (msec)   : 10=0.15%, 20=0.01%, 50=0.01%, 100=0.01%, 250=0.01%
  23.   lat (msec)   : 500=0.01%, 750=0.01%
  24.   cpu          : usr=0.40%, sys=2.15%, ctx=16015, majf=0, minf=7
  25.   IO depths    : 1=112.8%, 2=0.0%, 4=0.0%, 8=0.0%, 16=0.0%, 32=0.0%, >=64=0.0%
  26.      submit    : 0=0.0%, 4=100.0%, 8=0.0%, 16=0.0%, 32=0.0%, 64=0.0%, >=64=0.0%
  27.      complete  : 0=0.0%, 4=100.0%, 8=0.0%, 16=0.0%, 32=0.0%, 64=0.0%, >=64=0.0%
  28.      issued rwts: total=0,1829606,0,0 short=0,0,0,0 dropped=0,0,0,0
  29.      latency   : target=0, window=0, percentile=100.00%, depth=1
  30. Run status group 0 (all jobs):
  31.   WRITE: bw=23.6MiB/s (24.8MB/s), 23.6MiB/s-23.6MiB/s (24.8MB/s-24.8MB/s), io=7147MiB (7494MB), run=302453-302453msec
  32. Disk stats (read/write):
  33.   vda: ios=0/218884, merge=0/7891, ticks=0/73502849, in_queue=73502849, util=99.53%
发表于 2023-11-27 09:57:52 | 只看该作者
测试结果不错!
发表于 2023-11-27 17:36:35 | 只看该作者
hostslick 35€ 1T 带ddos防御吗
GMT+8, 2025-12-25 08:49 , Processed in 0.104791 second(s), 10 queries , Gzip On, MemCache On.
