查看: 2778|回复: 14
[美国VPS] 富强求助
发表于 2023-11-26 10:39:14 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
求助神通广大的mjj,楼主是个小白,用x-ui搭建了vless+reality之后客户端测试节点,出现一下报错信息
Warning] [3209821953] app/proxyman/outbound: failed to process outbound traffic > proxy/vless/outbound: failed to find an available destination > common/retry: [read tcp 10.21.204.68:62202->142.171.184.114:54332: wsarecv: An existing connection was forcibly closed by the remote host. read tcp 10.21.204.68:62203->142.171.184.114:54332: wsarecv: An existing connection was forcibly closed by the remote host. read tcp 10.21.204.68:62204->142.171.184.114:54332: wsarecv: An existing connection was forcibly closed by the remote host. read tcp 10.21.204.68:62205->142.171.184.122:54332: wsarecv: An existing connection was forcibly closed by the remote host. read tcp 10.21.204.68:62206->142.171.184.122:54332: wsarecv: An existing connection was forcibly closed by the remote host.] > common/retry: all retry attempts failed
请问该如何解决呢
发表于 2023-11-26 10:40:42 | 只看该作者
说明连不上。
 楼主| 发表于 2023-11-26 10:42:11 | 只看该作者
翻译过来好像是连接被我的服务器中断了???
该如何解决呀
发表于 2023-11-26 10:43:16 来自手机 | 只看该作者
别用x-ui了,用A大的八合一吧,reality轻松弄
发表于 2023-11-26 10:43:41 | 只看该作者
用这个重新装一下吧 别整啥x-ui了花里胡哨没卵用
bash <(curl -Ls https://gitlab.com/rwkgyg/sing-box-yg/raw/main/sb.sh)
装完输入sb就能进设置
 楼主| 发表于 2023-11-26 10:44:38 | 只看该作者
bash
好的好的谢谢佬
 楼主| 发表于 2023-11-26 10:45:41 | 只看该作者
谢谢老哥,老哥可否提供一下脚本地址呀
发表于 2023-11-26 10:46:34 | 只看该作者
54332这个端口不通,检查防火墙设置
发表于 2023-11-26 10:48:12 来自手机 | 只看该作者
V2ray-agent 八合一脚本,或者用fscarmen的sing-box全家桶都可以
发表于 2023-11-26 10:49:59 | 只看该作者
tcy6 发表于 2023-11-26 10:45
谢谢老哥,老哥可否提供一下脚本地址呀
https://www.v2ray-agent.com/archives/1680104902581
GMT+8, 2026-5-1 22:47 , Processed in 0.076167 second(s), 10 queries , Gzip On, MemCache On.
