查看: 1566|回复: 6
OPLINK 这家好像没什么热度, 都没人关注
发表于 2023-11-25 17:03:47 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
买了这款, 感觉性价比非常好
  1. Pro VPS
  2. 4 AMD Ryzen vCores
  3. 8 GB Memory
  4. 400 GB NVMe Storage (Raid 10)
  5. 10 Gbps Port
  6. 32 TB Data Per Month
  7. 1 IPv4 + 1 IPv6
  8. Always On DDoS Protection
  9. ★ $9.95 per month ★ (Get an extra 5% off if paid annually)
  10. ★ No Setup Fee ★
补个测试
  3. #                     v2023-11-24                    #
  6. Sat Nov 25 11:18:48 UTC 2023
  7. Basic System Information:
  9. Uptime     : 0 days, 0 hours, 5 minutes
  10. Processor  : AMD Ryzen 9 7950X 16-Core Processor
  11. CPU cores  : 4 @ 4499.980 MHz
  12. AES-NI     : ✔ Enabled
  13. VM-x/AMD-V : ✔ Enabled
  14. RAM        : 7.6 GiB
  15. Swap       : 0.0 KiB
  16. Disk       : 400.0 GiB
  17. Distro     : CentOS Linux 7 (Core)
  18. Kernel     : 3.10.0-1160.80.1.el7.x86_64
  19. VM Type    : KVM
  20. IPv4/IPv6  : ✔ Online / ✔ Online
  21. IPv6 Network Information:
  23. ISP        : The Optimal Link Corporation
  24. ASN        : AS40156 The Optimal Link Corporation
  25. Host       : The Optimal Link Corporation
  26. Location   : Houston, Texas (TX)
  27. Country    : United States
  28. fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/sda1):
  32. Read       | 403.54 MB/s (100.8k) | 5.08 GB/s    (79.5k)
  33. Write      | 404.60 MB/s (101.1k) | 5.11 GB/s    (79.9k)
  34. Total      | 808.15 MB/s (202.0k) | 10.20 GB/s  (159.4k)
  38. Read       | 7.91 GB/s    (15.4k) | 9.18 GB/s     (8.9k)
  39. Write      | 8.33 GB/s    (16.2k) | 9.79 GB/s     (9.5k)
  40. Total      | 16.25 GB/s   (31.7k) | 18.97 GB/s   (18.5k)
  45. Clouvider       | London, UK (10G)          | 1.74 Gbits/sec  | 1.49 Gbits/sec  | 100 ms
  46. Scaleway        | Paris, FR (10G)           | 1.16 Gbits/sec  | 922 Mbits/sec   | 103 ms
  47. NovoServe       | North Holland, NL (40G)   | 1.52 Gbits/sec  | 948 Mbits/sec   | 112 ms
  48. Uztelecom       | Tashkent, UZ (10G)        | 792 Mbits/sec   | 340 Mbits/sec   | 238 ms
  49. Clouvider       | NYC, NY, US (10G)         | 4.06 Gbits/sec  | 2.95 Gbits/sec  | 32.5 ms
  50. Clouvider       | Dallas, TX, US (10G)      | 1.19 Gbits/sec  | 377 Mbits/sec   | 116 ms
  51. Clouvider       | Los Angeles, CA, US (10G) | 2.65 Gbits/sec  | 958 Mbits/sec   | 35.3 ms
  52. iperf3 Network Speed Tests (IPv6):
  53. ---------------------------------
  54. Provider        | Location (Link)           | Send Speed      | Recv Speed      | Ping
  55. -----           | -----                     | ----            | ----            | ----
  56. Clouvider       | London, UK (10G)          | 1.62 Gbits/sec  | 1.22 Gbits/sec  | 101 ms
  57. Scaleway        | Paris, FR (10G)           | 1.75 Gbits/sec  | 1.19 Gbits/sec  | --
  58. NovoServe       | North Holland, NL (40G)   | 1.46 Gbits/sec  | 1.44 Gbits/sec  | 112 ms
  59. Uztelecom       | Tashkent, UZ (10G)        | 922 Mbits/sec   | 521 Mbits/sec   | 238 ms
  60. Clouvider       | NYC, NY, US (10G)         | 4.51 Gbits/sec  | 2.42 Gbits/sec  | 32.5 ms
  61. Clouvider       | Dallas, TX, US (10G)      | 8.16 Gbits/sec  | 4.39 Gbits/sec  | 116 ms
  62. Clouvider       | Los Angeles, CA, US (10G) | busy            | 2.85 Gbits/sec  | 35.2 ms
  63. Geekbench 6 test failed. Run manually to determine cause.
  64. YABS completed in 7 min 18 sec
发表于 2023-11-25 17:33:40 | 只看该作者
今年都被99刀震撼到了,其他都索然无味
发表于 2023-11-25 17:38:17 | 只看该作者
netcup 四核独享
发表于 2023-11-25 17:40:08 | 只看该作者
mymyhope 发表于 2023-11-25 17:33
今年都被99刀震撼到了,其他都索然无味
99一出其他都暗淡无光没有购买欲望顿时不香了。ovh辣鸡爬开
发表于 2023-11-25 18:39:52 来自手机 | 只看该作者
每个人只能升级一个硬盘
发表于 2023-11-25 18:54:07 来自手机 | 只看该作者
买了他家大盘的,感觉还不错,就是买他家机器需要发身份证
GMT+8, 2026-5-1 22:46 , Processed in 0.070970 second(s), 10 queries , Gzip On, MemCache On.
