楼主: njkml
[经验] 昨天买的sentris已经开通了,zhihao和各位请进!
发表于 2010-3-16 10:05:31 | 只看该作者
不错啊。哈哈
发表于 2010-3-16 10:06:24 | 只看该作者
发表于 2010-3-16 10:06:35 | 只看该作者
tracert结果
C:\Documents and Settings\Administrator>tracert 63.223.125.27
Tracing route to 63.223.125.27 over a maximum of 30 hops
  1    <1 ms    <1 ms    <1 ms  172.20.95.254
  2    <1 ms    <1 ms    <1 ms  172.20.255.20
  3     4 ms     3 ms     2 ms  210.51.173.129
  4     2 ms     1 ms     1 ms  210.51.176.113
  5     1 ms     2 ms     *     210.53.129.249
  6    27 ms    27 ms    26 ms  218.105.1.2
  7     *       27 ms    26 ms  218.105.10.26
  8     *      233 ms   231 ms  POS3-0.IG1.LAX7.ALTER.NET [208.222.0.97]
  9   226 ms   234 ms   225 ms  0.so-2-0-3.XT2.LAX7.ALTER.NET [152.63.117.214]
10   241 ms   228 ms   246 ms  0.so-7-0-0.XL4.LAX15.ALTER.NET [152.63.112.61]
11   227 ms   225 ms   226 ms  0.xe-11-1-0.BR2.LAX15.ALTER.NET [152.63.116.161]
12   401 ms   401 ms   412 ms  te7-2.ccr02.lax05.atlas.cogentco.com [154.54.13.
85]
13   390 ms   395 ms   390 ms  te3-8.ccr02.lax01.atlas.cogentco.com [130.117.50
.89]
14   405 ms   403 ms   401 ms  te1-2.ccr02.sfo01.atlas.cogentco.com [154.54.3.2
30]
15   542 ms   406 ms   402 ms  te3-1.ccr01.smf01.atlas.cogentco.com [154.54.29.
249]
16   418 ms   418 ms   418 ms  te3-3.ccr01.sea01.atlas.cogentco.com [154.54.3.9
0]
17   431 ms   419 ms   417 ms  te4-2.ccr01.sea02.atlas.cogentco.com [154.54.1.1
98]
18   423 ms   426 ms   433 ms  vl3830.na21.b001703-11.sea02.atlas.cogentco.com
[38.20.45.90]
19   424 ms   427 ms   423 ms  38.112.26.186
20   260 ms   267 ms   258 ms  204.8.32.82
21   417 ms   417 ms   424 ms  63.223.125.27
发表于 2010-3-16 10:07:14 | 只看该作者
不错,安徽电信
Microsoft Windows XP [版本 5.1.2600]
(C) 版权所有 1985-2001 Microsoft Corp.
C:\Documents and Settings\Administrator>ping 63.223.125.27
Pinging 63.223.125.27 with 32 bytes of data:
Reply from 63.223.125.27: bytes=32 time=236ms TTL=46
Reply from 63.223.125.27: bytes=32 time=235ms TTL=46
Ping statistics for 63.223.125.27:
    Minimum = 235ms, Maximum = 236ms, Average = 235ms
发表于 2010-3-16 10:30:31 | 只看该作者
回复 10# 的帖子
cogentco线路联通访问不大好。
发表于 2010-3-16 10:31:13 | 只看该作者
Reply from 63.223.125.27: bytes=32 time=254ms TTL=46
Reply from 63.223.125.27: bytes=32 time=290ms TTL=46
Reply from 63.223.125.27: bytes=32 time=289ms TTL=46
    Minimum = 254ms, Maximum = 290ms, Average = 271ms
发表于 2010-3-16 10:31:25 | 只看该作者
3    14 ms    14 ms    14 ms  218.85.150.89
  4    13 ms    14 ms    14 ms  61.154.238.73
  5    14 ms    14 ms    14 ms  61.154.236.2
  6    14 ms    14 ms    14 ms  202.97.42.85
  7    23 ms    24 ms    25 ms  202.97.33.98
  8    25 ms    25 ms    24 ms  202.97.33.154
  9   316 ms   317 ms   275 ms  202.97.51.42
10   273 ms   269 ms   265 ms  202.97.51.42
11   301 ms   305 ms   264 ms  te4-3.ccr01.lax01.atlas.cogentco.com [154.54.24.
69]
12   311 ms   323 ms   286 ms  te4-3.ccr01.lax01.atlas.cogentco.com [154.54.24.
69]
13   234 ms   195 ms   197 ms  te3-1.ccr01.smf01.atlas.cogentco.com [154.54.29.
249]
14   196 ms   195 ms   231 ms  te3-1.ccr01.smf01.atlas.cogentco.com [154.54.29.
249]
15   288 ms   290 ms   252 ms  te4-4.ccr01.sea02.atlas.cogentco.com [154.54.3.1
46]
16   290 ms   415 ms   442 ms  te4-4.ccr01.sea02.atlas.cogentco.com [154.54.3.1
46]
17   289 ms   254 ms   289 ms  38.112.26.186
18   291 ms   287 ms   253 ms  38.112.26.186
19   291 ms   253 ms   290 ms  63.223.125.27
Trace complete.
 楼主| 发表于 2010-3-16 10:37:31 | 只看该作者
c大,知道为什么配置和下单的不一样吗?
还有这个cpu是怎么回事?
[root@njkml ~]# cat /proc/cpuinfo
processor       : 0
vendor_id       : AuthenticAMD
cpu family      : 16
model           : 2
model name      : AMD Phenom(tm) 8450 Triple-Core Processor
stepping        : 3
cpu MHz         : 1100.000
cache size      : 512 KB
physical id     : 0
siblings        : 3
core id         : 0
cpu cores       : 3
apicid          : 0
fdiv_bug        : no
hlt_bug         : no
f00f_bug        : no
coma_bug        : no
fpu             : yes
fpu_exception   : yes
cpuid level     : 5
wp              : yes
flags           : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush mmx fxsr sse sse2 ht syscall nx mmxext fxsr_opt pdpe1gb rdtscp lm 3dnowext 3dnow constant_tsc nonstop_tsc pni cx16 popcnt lahf_lm cmp_legacy svm extapic cr8legacy abm sse4a misalignsse 3dnowprefetch osvw ibs ts ttp tm stc 100mhzsteps hwpstate [8]
bogomips        : 2210.16
processor       : 1
cpu family      : 16
model           : 2
stepping        : 3
cpu MHz         : 1100.000
cache size      : 512 KB
physical id     : 0
siblings        : 3
core id         : 2
cpu cores       : 3
apicid          : 2
fdiv_bug        : no
hlt_bug         : no
f00f_bug        : no
coma_bug        : no
fpu             : yes
fpu_exception   : yes
cpuid level     : 5
wp              : yes
bogomips        : 2210.16
processor       : 2
cpu family      : 16
model           : 2
stepping        : 3
cpu MHz         : 1100.000
cache size      : 512 KB
physical id     : 0
siblings        : 3
core id         : 1
cpu cores       : 3
apicid          : 1
fdiv_bug        : no
hlt_bug         : no
f00f_bug        : no
coma_bug        : no
fpu             : yes
fpu_exception   : yes
cpuid level     : 5
wp              : yes
bogomips        : 2210.16
发表于 2010-3-16 10:39:31 | 只看该作者
没抢到,
20#
发表于 2010-3-16 10:42:31 | 只看该作者
机器配置不一样是因为他们机房没有现有配置 给你多填上补配置的. 另外哥们如果机器不要的话 可以转给我哦.
这家机房 除了SUPPORT不行  其他都很不错 不过WINDOWS貌似会无故死机 LINUX暂时不知道.
带宽质量非常好 相对于美国来说 算西雅图比较大的一个机房了. 比什么WOWRACK大很多哦
GMT+8, 2026-5-7 16:18 , Processed in 0.071693 second(s), 9 queries , Gzip On, MemCache On.
