查看: 10765|回复: 36
[不限流量] 【便宜NAT】NATseek 2.5元月付加拿大不限流量VPS测评
发表于 2023-11-18 14:22:21 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
买的最低配置,2.5元一个月,25一年,不限流量,100Mbps带宽,配置抄自官网:
1 core @ Xeon(R) CPU E3-1230 V2 CPU (FAIR USE)
256MB RAM
3GB Storage
100Mbps Port
Unlimited Bandwidth (FAIR USE)
1 NAT IPv4 (20Ports)
1 IPv6 Via Tunnel
FREE NO-DMCA Internal SOCKS5 Service
LXC Virtualization
更高配置的限速也不止100M。
注意:新商家,域名注册仅半个月,风险自行衡量。如果不放心,请月付!不要贪小便宜!
官网:(AFF)https://natseek.com/order/forms/a/MjM=
官网:(无AFF)https://natseek.com/
先跑个yabs:
  1. Sat Nov 18 13:50:04 CST 2023
  2. Basic System Information:
  3. ---------------------------------
  4. Uptime     : 1 days, 19 hours, 31 minutes
  5. Processor  : Intel(R) Xeon(R) CPU E3-1230 V2 @ 3.30GHz
  6. CPU cores  : 1 @ 3603.005 MHz
  7. AES-NI     : ✔ Enabled
  8. VM-x/AMD-V : ✔ Enabled
  9. RAM        : 256.0 MiB
  10. Swap       : 0.0 KiB
  11. Disk       : 2.9 GiB
  12. Distro     : Debian GNU/Linux 11 (bullseye)
  13. Kernel     : 6.2.16-19-pve
  14. VM Type    : LXC
  15. IPv4/IPv6  : ✔ Online / ✔ Online
  16. IPv6 Network Information:
  17. ---------------------------------
  18. ISP        : Hurricane Electric LLC
  19. ASN        : AS6939 Hurricane Electric LLC
  20. Host       : Hurricane Electric
  21. Location   : Toronto, Ontario (ON)
  22. Country    : Canada
  23. fio Disk Speed Tests (Mixed R/W 50/50):
  25. Block Size | 4k            (IOPS) | 64k           (IOPS)
  26.   ------   | ---            ----  | ----           ----
  27. Read       | 26.95 MB/s    (6.7k) | 46.43 MB/s     (725)
  28. Write      | 26.97 MB/s    (6.7k) | 46.64 MB/s     (728)
  29. Total      | 53.93 MB/s   (13.4k) | 93.08 MB/s    (1.4k)
  30.            |                      |
  31. Block Size | 512k          (IOPS) | 1m            (IOPS)
  33. Read       | 92.23 MB/s     (180) | 102.19 MB/s     (99)
  34. Write      | 97.13 MB/s     (189) | 109.00 MB/s    (106)
  35. Total      | 189.36 MB/s    (369) | 211.20 MB/s    (205)
  36. iperf3 Network Speed Tests (IPv4):
  37. ---------------------------------
  38. Provider        | Location (Link)           | Send Speed      | Recv Speed      | Ping
  39. -----           | -----                     | ----            | ----            | ----
  40. Clouvider       | London, UK (10G)          | 99.1 Mbits/sec  | 77.0 Mbits/sec  | 87.2 ms
  41. Scaleway        | Paris, FR (10G)           | busy            | 27.0 Mbits/sec  | 82.3 ms
  42. NovoServe       | North Holland, NL (40G)   | 99.0 Mbits/sec  | 80.4 Mbits/sec  | 90.1 ms
  43. Uztelecom       | Tashkent, UZ (10G)        | 92.4 Mbits/sec  | 23.5 Mbits/sec  | 190 ms
  44. Clouvider       | NYC, NY, US (10G)         | 104 Mbits/sec   | 90.8 Mbits/sec  | 25.0 ms
  45. Clouvider       | Dallas, TX, US (10G)      | 92.7 Mbits/sec  | 19.9 Mbits/sec  | 62.5 ms
  46. Clouvider       | Los Angeles, CA, US (10G) | 99.5 Mbits/sec  | 40.0 Mbits/sec  | 72.4 ms
  47. iperf3 Network Speed Tests (IPv6):
  48. ---------------------------------
  49. Provider        | Location (Link)           | Send Speed      | Recv Speed      | Ping
  50. -----           | -----                     | ----            | ----            | ----
  51. Clouvider       | London, UK (10G)          | 95.0 Mbits/sec  | 77.8 Mbits/sec  | 85.3 ms
  52. Scaleway        | Paris, FR (10G)           | 95.5 Mbits/sec  | busy            | 96.4 ms
  53. NovoServe       | North Holland, NL (40G)   | 96.0 Mbits/sec  | 77.9 Mbits/sec  | 90.1 ms
  54. Uztelecom       | Tashkent, UZ (10G)        | 91.8 Mbits/sec  | 55.9 Mbits/sec  | 171 ms
  55. Clouvider       | NYC, NY, US (10G)         | 102 Mbits/sec   | busy            | 22.1 ms
  56. Clouvider       | Dallas, TX, US (10G)      | 98.0 Mbits/sec  | 65.5 Mbits/sec  | 62.9 ms
  57. Clouvider       | Los Angeles, CA, US (10G) | busy            | 62.4 Mbits/sec  | 72.4 ms
  58. Geekbench test failed and low memory was detected. Add at least 1GB of SWAP or use GB4 instead (higher compatibility with low memory systems).
  59. YABS completed in 12 min 1 sec
融合怪脚本:
  1.
  2. ---------------------基础信息查询--感谢所有开源项目---------------------
  3. CPU 型号          : Intel(R) Xeon(R) CPU E3-1230 V2 @ 3.30GHz
  4. CPU 核心数        : 1
  5. CPU 频率          : 3669.536 MHz
  6. CPU 缓存          : L1: 128.00 KB / L2: 512.00 KB / L3: 0.00 KB
  7. 硬盘空间          : 577.75 MiB / 2950.79 MiB
  8. 启动盘路径        : /dev/loop1
  9. 内存              : 34.50 MiB / 256.00 MiB
  10. Swap              : [ no swap partition or swap file detected ]
  11. 系统在线时间      : 1 days, 19 hour 18 min
  12. 负载              : 0.61, 0.64, 0.64
  13. 系统              : Debian GNU/Linux 11 (bullseye) (x86_64)
  14. AES-NI指令集      : ✔ Enabled
  15. VM-x/AMD-V支持    : ✔ Enabled
  16. 架构              : x86_64 (64 Bit)
  17. 内核              : 6.2.16-19-pve
  18. TCP加速方式       : bbr
  19. 虚拟化架构        : LXC
  20. NAT类型           : 独立映射,独立过滤,不支持回环
  21. IPV4 ASN          : AS32613 iWeb Technologies Inc.
  22. IPV4 位置         : Laval / Quebec / CA
  23. IPV6 ASN          : AS6939 Hurricane Electric IPv6 Tunnel Broker
  24. IPV6 位置         : Toronto / Ontario
  25. ---------------------CPU测试--感谢lemonbench开源------------------------
  26. -> CPU 测试中 (Fast Mode, 1-Pass @ 5sec)
  27. 1 线程测试(1核)得分:                 997 Scores
  28. 4 线程测试(多核)得分:                 1000 Scores
  29. ---------------------内存测试--感谢lemonbench开源-----------------------
  30. -> 内存测试 Test (Fast Mode, 1-Pass @ 5sec)
  31. 单线程读测试:                22069.92 MB/s
  32. 单线程写测试:                16842.37 MB/s
  33. ------------------磁盘dd读写测试--感谢lemonbench开源--------------------
  34. -> 磁盘IO测试中 (4K Block/1M Block, Direct Mode)
  35. 测试操作                写速度                                        读速度
  36. 100MB-4K Block                186 MB/s (45.51 IOPS, 0.56s)                401 MB/s (97907 IOPS, 0.26s)
  37. 1GB-1M Block                655 MB/s (624 IOPS, 1.60s)                515 MB/s (491 IOPS, 2.04s)
  38. ---------------------磁盘fio读写测试--感谢yabs开源----------------------
  39. Block Size | 4k            (IOPS) | 64k           (IOPS)
  40.   ------   | ---            ----  | ----           ----
  41. Read       | 27.44 MB/s    (6.8k) | 45.86 MB/s     (716)
  42. Write      | 27.47 MB/s    (6.8k) | 46.11 MB/s     (720)
  43. Total      | 54.92 MB/s   (13.7k) | 91.97 MB/s    (1.4k)           |                      |
  44. Block Size | 512k          (IOPS) | 1m            (IOPS)
  46. Read       | 88.55 MB/s     (172) | 98.58 MB/s      (96)
  47. Write      | 93.25 MB/s     (182) | 105.15 MB/s    (102)
  48. Total      | 181.80 MB/s    (354) | 203.73 MB/s    (198)
  49. ---------------------流媒体解锁--感谢sjlleo开源-------------------------
  50. 以下测试的解锁地区是准确的,但是不是完整解锁的判断可能有误,这方面仅作参考使用
  51. ----------------有图比----------------
  52. [IPv4]
  53. 连接方式: 有图比 Video Server
  54. 视频缓存节点地域: YUL(YUL03S06)
  55. 有图比识别地域: 加拿大(CA)
  56. [IPv6]
  57. 连接方式: 有图比 Video Server
  58. 视频缓存节点地域: ORD(ORD38S25)
  59. 有图比识别地域: 无信息(null)
  60. ----------------Netflix----------------
  61. [IPv4]
  62. 您的出口IP完整解锁Netflix,支持非自制剧的观看
  63. NF所识别的IP地域信息:加拿大
  64. [IPv6]
  65. 您的出口IP完整解锁Netflix,支持非自制剧的观看
  66. NF所识别的IP地域信息:加拿大
  67. ---------------DisneyPlus---------------
  68. [IPv4]
  69. 当前IPv4出口解锁DisneyPlus
  70. 区域:加拿大区
  71. [IPv6]
  72. 当前IPv6出口解锁DisneyPlus
  73. 区域:加拿大区
  74. 解锁有图比,Netflix,DisneyPlus上面和下面进行比较,不同之处自行判断
  75. ----------------流媒体解锁--感谢RegionRestrictionCheck开源--------------
  76. 以下为IPV4网络测试,若无IPV4网络则无输出
  77. ============[ Multination ]============
  78. Dazn:                                        Yes (Region: CA)
  79. HotStar:                                No
  80. Disney+:                                No
  81. Netflix:                                Yes (Region: CA)
  82. 有图比 Premium:                        Yes (Region: CA)
  83. Amazon Prime Video:                        Yes (Region: CA)
  84. TVBAnywhere+:                                Yes
  85. iQyi Oversea Region:                        CA
  86. Viu.com:                                No
  87. 有图比 CDN:                                Montreal, PQ
  88. Netflix Preferred CDN:                        New York, NY
  89. Spotify Registration:                        No
  90. Steam Currency:                        CAD
  91. ChatGPT:                                Yes
  92. =======================================
  93. 以下为IPV6网络测试,若无IPV6网络则无输出
  94. ============[ Multination ]============
  95. Dazn:                                        Failed (Network Connection)
  96. HotStar:                                Yes (Region: CA)
  97. Disney+:                                Yes (Region: CA)
  98. Netflix:                                Yes (Region: CA)
  99. 有图比 Premium:                        Yes
  100. Amazon Prime Video:                        Unsupported
  101. TVBAnywhere+:                                Failed (Network Connection)
  102. iQyi Oversea Region:                        Failed
  103. Viu.com:                                Failed
  104. 有图比 CDN:                                Chicago, IL
  105. Netflix Preferred CDN:                        New York, NY
  106. Spotify Registration:                        No
  107. Steam Currency:                        Failed (Network Connection)
  108. ChatGPT:                                Yes
  109. =======================================
  110. ---------------TikTok解锁--感谢lmc999的源脚本及fscarmen PR--------------
  111. Tiktok Region:                【CA】
优点:
1.便宜,2.5元一个月,一卷卫生纸都比这贵了……
2.解锁优秀,适合看加拿大流媒体的MJJ
3.性能不错,目前看样子资源充足,暂时没有超售的迹象
缺点:
1.LXC虚拟化,折腾受到制约
2.IPv6是HE提供的隧道,听说不能套CF,但实测可以,建站需要考虑风险。
3.商家成立时间太短,风险需要自行权衡
实际体验:
搭了个xui,vmess,本地联通200M宽带。
不错,有图比4K秒开,跑满带宽。昨晚晚高峰测试。
写不下了,2L继续融合怪脚本:
来自 2#
 楼主| 发表于 2023-11-18 14:23:57 | 只看该作者
融合怪:
  1. -------------------欺诈分数以及IP质量检测--本脚本原创-------------------
  2. 数据仅作参考,不代表100%准确,如果和实际情况不一致请手动查询多个数据库比对
  3. 以下为各数据库编号,输出结果后将自带数据库来源对应的编号
  4. ipinfo数据库 ①  | scamalytics数据库 ②  | virustotal数据库 ③  | abuseipdb数据库 ④  | ip2location数据库   ⑤
  5. ip-api数据库 ⑥  | ipwhois数据库     ⑦  | ipregistry数据库 ⑧  | ipdata数据库    ⑨  | ipgeolocation数据库 ⑩
  6. 欺诈分数(越低越好): 0②
  7. abuse得分(越低越好): 0④
  8. IP类型:
  9.   使用类型(usage_type):hosting①  Data Center/Web Hosting/Transit⑤  hosting⑧  hosting⑨
  10.   公司类型(company_type):hosting①
  11.   云服务提供商(cloud_provider):  Yes⑧
  12.   数据中心(datacenter):  Yes② ⑥ ⑨
  13.   移动网络(mobile):  No⑥
  14.   代理(proxy):  No① ② ⑥ ⑦ ⑧ ⑨
  15.   扶墙(扶墙):  No① ② ⑦ ⑧
  16.   TOR(tor):  No① ② ⑦ ⑧ ⑨
  17.   TOR出口(tor_exit):  No⑧
  18.   搜索引擎机器人(search_engine_robot):  No②
  19.   匿名代理(anonymous):  No⑦ ⑧ ⑨
  20.   攻击方(attacker):  No⑧ ⑨
  21.   滥用者(abuser):  No⑧ ⑨
  22.   威胁(threat):  No⑧ ⑨
  23.   iCloud中继(icloud_relay):  No① ⑧ ⑨
  24.   未分配IP(bogon):  No⑧ ⑨
  25. 黑名单记录统计(有多少个黑名单网站有记录): 无害0 恶意0 可疑0 未检测88 ③
  26. Google搜索可行性:NO
  27. 端口25检测:
  28.   本地: No
  29.   163邮箱: Yes
  30.   gmail邮箱: Yes
  31.   outlook邮箱: Yes
  32.   qq邮箱:No
  33.   yandex邮箱: Yes
  34. ------以下为IPV6检测------
  35. 欺诈分数(越低越好): 51②
  36. abuse得分(越低越好): 0④
  37. IP类型: Data Center/Web Hosting/Transit⑤
  38. ----------------三网回程--感谢zhanghanyun/backtrace开源-----------------
  39. 国家: CA 城市: Laval 服务商: AS32613 iWeb Technologies Inc.
  40. 北京电信 219.141.136.12  电信163 [普通线路]
  41. 北京联通 202.106.50.1    联通4837[普通线路]
  42. 北京移动 221.179.155.161 测试超时
  43. 上海电信 202.96.209.133  电信163 [普通线路]
  44. 上海联通 210.22.97.1     联通4837[普通线路]
  45. 上海移动 211.136.112.200 测试超时
  46. 广州电信 58.60.188.222   电信163 [普通线路]
  47. 广州联通 210.21.196.6    测试超时
  48. 广州移动 120.196.165.24  移动CMI [普通线路]
  49. 成都电信 61.139.2.69     电信163 [普通线路]
  50. 成都联通 119.6.6.6       联通4837[普通线路]
  51. 成都移动 211.137.96.205  测试超时
  52. ---------------------回程路由--感谢fscarmen开源及PR---------------------
  53. 依次测试电信/联通/移动经过的地区及线路,核心程序来自ipip.net或nexttrace,请知悉!
  54. 广州电信 58.60.188.222
  55. 0.16 ms         * RFC1918
  56. 0.40 ms         AS32613 加拿大 魁北克省 拉瓦勒 iweb.com
  57. 0.41 ms         AS32613 加拿大 魁北克省 蒙特利尔 iweb.com
  58. 1.27 ms         AS174 加拿大 魁北克省 多尔瓦勒 cogentco.com
  59. 1.28 ms         AS174 [COGENT-BONE] 加拿大 魁北克省 蒙特利尔 cogentco.com
  60. 2.00 ms         AS174 [COGENT-BONE] 加拿大 魁北克省 蒙特利尔 cogentco.com
  61. 70.83 ms         AS174 [COGENT-BONE] 英国 默西赛德郡 南码头 cogentco.com
  62. 74.96 ms         AS174 [COGENT-BONE] 英国 英格兰 斯劳 cogentco.com
  63. 76.32 ms         AS174 [COGENT-BONE] 英国 英格兰 伦敦 cogentco.com
  64. 76.43 ms         AS174 [COGENT-BONE] 英国 英格兰 伦敦 cogentco.com
  65. 82.93 ms         AS174 [COGENT-149] 英国 英格兰 伦敦 Cogent-CT-Peer cogentco.com
  66. 339.03 ms         AS4134 [CHINANET-BB] 中国 广东省 广州市 X-I chinatelecom.com.cn 电信
  67. 240.19 ms         AS4134 [CHINANET-BB] 中国 广东省 广州市 chinatelecom.com.cn 电信
  68. 253.21 ms         AS134774 [CHINANET-GD] 中国 广东省 深圳市 chinatelecom.cn 电信
  69. 259.85 ms         AS4134 中国 广东省 深圳市 福田区 chinatelecom.com.cn 电信
  70. 广州联通 210.21.196.6
  71. 0.27 ms         * RFC1918
  72. 0.41 ms         AS32613 加拿大 魁北克省 拉瓦勒 iweb.com
  73. 0.56 ms         AS32613 加拿大 魁北克省 蒙特利尔 iweb.com
  74. 1.30 ms         AS174 加拿大 魁北克省 多尔瓦勒 cogentco.com
  75. 1.40 ms         AS174 [COGENT-BONE] 加拿大 魁北克省 蒙特利尔 cogentco.com
  76. 1.59 ms         AS174 [COGENT-BONE] 加拿大 魁北克省 蒙特利尔 cogentco.com
  77. 9.14 ms         AS174 [COGENT-BONE] 加拿大 安大略省 多伦多 cogentco.com
  78. 15.64 ms         AS174 [COGENT-BONE] 美国 俄亥俄州 克里夫兰 cogentco.com
  79. 22.95 ms         AS174 [COGENT-BONE] 美国 伊利诺伊州 芝加哥 cogentco.com
  80. 33.77 ms         AS174 [COGENT-BONE] 美国 密苏里州 堪萨斯城 cogentco.com
  81. 45.05 ms         AS174 [COGENT-BONE] 美国 科罗拉多州 丹佛 cogentco.com
  82. 57.80 ms         AS174 [COGENT-BONE] 美国 得克萨斯州 埃尔帕索 cogentco.com
  83. 66.17 ms         AS174 [COGENT-BONE] 美国 亚利桑那州 凤凰城 cogentco.com
  84. 77.83 ms         AS174 [COGENT-BONE] 美国 加利福尼亚州 洛杉矶 cogentco.com
  85. 78.39 ms         AS174 [COGENT-BONE] 美国 加利福尼亚州 洛杉矶 cogentco.com
  86. 414.03 ms         AS174 美国 加利福尼亚州 洛杉矶 cogentco.com
  87. 446.61 ms         AS4837 [CU169-BACKBONE] 中国 广东省 广州市 chinaunicom.cn 联通
  88. 389.22 ms         AS4837 [CU169-BACKBONE] 中国 广东省 广州市 chinaunicom.cn 联通
  89. 427.50 ms         AS17816 [APNIC-AP] 中国 广东省 深圳市 chinaunicom.cn 联通
  90. 455.45 ms         AS17623 [APNIC-AP] 中国 广东省 深圳市 chinaunicom.cn 联通
  91. 427.93 ms         AS17623 [APNIC-AP] 中国 广东省 深圳市 宝安区 chinaunicom.cn 联通
  92. 广州移动 120.196.165.24
  93. 0.25 ms         * RFC1918
  94. 0.42 ms         AS32613 加拿大 魁北克省 拉瓦勒 iweb.com
  95. 0.46 ms         AS32613 加拿大 魁北克省 蒙特利尔 iweb.com
  96. 1.22 ms         AS32613 加拿大 魁北克省 蒙特利尔 iweb.com
  97. 1.77 ms         AS174 加拿大 魁北克省 蒙特利尔 cogentco.com
  98. 1.88 ms         AS174 [COGENT-BONE] 加拿大 魁北克省 蒙特利尔 cogentco.com
  99. 70.93 ms         AS174 [COGENT-BONE] 英国 默西赛德郡 南码头 cogentco.com
  100. 74.83 ms         AS174 [COGENT-BONE] 英国 英格兰 斯劳 cogentco.com
  101. 75.19 ms         AS174 [COGENT-BONE] 英国 英格兰 斯劳 cogentco.com
  102. 74.76 ms         AS174 [COGENT-149] 英国 伯克郡 斯劳 Cogent-CMI-Peer cogentco.com
  103. 74.75 ms         AS58453 [CMI-INT] 英国 伯克郡 斯劳 cmi.chinamobile.com 移动
  104. 250.19 ms         AS58453 [CMI-INT] 英国 英格兰 伦敦 cmi.chinamobile.com 移动
  105. 255.66 ms         AS9808 [CMNET] 中国 广东省 广州市 chinamobile.com 移动
  106. 249.99 ms         AS9808 [CMNET] 中国 广东省 广州市 chinamobile.com 移动
  107. 352.85 ms         AS9808 [CMNET] 中国 广东省 广州市 chinamobile.com 移动
  108. 257.65 ms         AS9808 [CMNET] 中国 广东省 广州市 chinamobile.com 移动
  109. 255.17 ms         AS9808 [CMNET] 中国 海南省 海口市 chinamobile.com 移动
  110. 253.17 ms         AS56040 [APNIC-AP] 中国 广东省 深圳市 chinamobile.com 移动
  111. --------------------自动更新测速节点列表--本脚本原创--------------------
  112. 位置                 上传速度         下载速度         延迟          丢包率
  113. Speedtest.net         103.42 Mbps         101.19 Mbps         0.88          0.0%
  114. 洛杉矶                 104.78 Mbps         101.03 Mbps         81.88          3.7%
  115. 法兰克福         104.39 Mbps         101.48 Mbps         94.38          0.0%
  116. 联通WuXi         42.16 Mbps         3.00 Mbps         358.46          1.0%
  117. 联通郑州5G         49.64 Mbps         66.44 Mbps         361.16          NULL
  118. 电信浙江         97.09 Mbps         12.23 Mbps         245.55          NULL
  119. 电信天津5G         0.19 Mbps         32.84 Mbps         438.69          12.4%
  120. 移动硬核通信         89.51 Mbps         94.92 Mbps         262.42          NULL
  121. ------------------------------------------------------------------------
  122. 总共花费      : 7 分 53 秒
  123. 时间          : Sat Nov 18 13:45:39 CST 2023
  124. ------------------------------------------------------------------------
发表于 2023-11-18 16:38:52 | 只看该作者
甚至支持花呗实体店红包付款
发表于 2023-11-18 23:31:07 | 只看该作者
看完了,技术堪忧啊。甚至说是个小白啊。
容器的lxcfs没有开启,可以看到宿主的信息。
ExecStart=/usr/bin/lxcfs  -l /var/lib/lxcfs
自己改下把。
然后机器是ovh的ks1,做的raid0。没有保障啊。
上个zfs不香嘛?调整成25%的arc就行了。起码可以跑出4G/s 的性能。
 楼主| 发表于 2023-11-18 17:31:04 | 只看该作者
21922 发表于 2023-11-18 17:05
买了一个  登录不上ssh
不应该这么快就被墙qiang吧,我刚试了下还通着,ipv4的ssh端口是你[内网ip尾数&22],内网ip在面板上看,我的内网ip是10.10.10.103,ssh端口就是公网IP:10322,可用端口是 10301~10320,算起来确实挺麻烦的,面板不显示IPv6,要进系统看。
发表于 2023-11-18 17:05:06 | 只看该作者
买了一个  登录不上ssh
 楼主| 发表于 2023-11-18 16:27:59 | 只看该作者
WuZihan 发表于 2023-11-18 14:31
确实25块要什么自行车,不过默认CNY计价有点搞
看来现在都瞄准MJJ做生意了 ,那个colo机房本来是好多VPS供应商的上游,现在也亲自下海卖Cheap VPS了
发表于 2023-11-18 14:35:51 | 只看该作者
看了下 英文界面 价格单位直接就是CNY了
发表于 2023-11-18 14:31:59 来自手机 | 只看该作者
发表于 2023-11-18 16:01:27 | 只看该作者
买了个富强 还行
发表于 2023-11-18 17:44:20 来自手机 | 只看该作者
大机不赚钱,小鸡赚啊,没有中间商赚cha jia t
GMT+8, 2026-4-16 23:20 , Processed in 0.075107 second(s), 11 queries , Gzip On, MemCache On.
