查看: 945|回复: 4
Vir 两条机器,续费前取消另外一台机器会触发账户关闭?
发表于 2023-11-13 11:18:09 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
The following action has been taken:
Any payments made via Alipay, PayPal, or credit card within the last 6 months have been refunded.
If the refund has caused your service to expire, we will provide a one week grace period for any currently active services.
Any unpaid invoices have been cancelled. Any automatic billing will be disabled.
Any active services will have cancellation requests placed at end of term, if this is not automatically placed, please be sure to place a cancellation request yourself as your account will be closed, even if there is a renewal.
Any active services will continue until their expiry period, unless further notice is provided. Please only create a ticket if you qualify for free support under the agreement. For example, limited support specials will only qualify for reporting a valid technical issue with your service causing it to be inoperable. Otherwise, you may incur a support ticket fee, and as we are no longer accepting further payments from your account, it will result in the account being flagged for more immediate closure.
Once service duration has expired for all services, your account will be closed. Please do not make any further payments or service renewals on your account. Do not remove cancellation request. If cancellation request placed for your service is removed, all services will instead be changed to termination with a maximum of one week grace period.
If you have any disagreements, please feel free to contact us so we can instead proceed with the normal account closure process, which would be immediate termination of all services and account closure upon receipt of your ticket regarding this matter (we may still provide a grace period at our discretion in this case.) If there are any payment disputes on your account, your services and account may be immediately terminated and closed. If you have any other accounts, they may also be processed per the above, or as an immediate termination after the one week grace period (November XXX, 2023) without any further notifications.
关键另外一台已经续费,结果给我退了
可能跟我的1刀神机有关,强制被取消,退费了。
后续来了,账户已经被关闭了,服务器没到期也被关闭了
另外就一个账户,没有多账户
发表于 2023-11-13 11:19:20 | 只看该作者
没办法,人为刀俎,我为鱼肉
发表于 2023-11-13 11:21:10 | 只看该作者
就是你信誉不佳(付费少,发过工单),看你不爽,跟操作没关系
发表于 2023-11-13 11:38:44 来自手机 | 只看该作者
不会。主要是你账号被标记了(发工单,或者多账号。)。和操作没关系
发表于 2023-11-14 09:27:58 | 只看该作者
最近在清退多账号的账户,一个账号取消不会有问题
GMT+8, 2026-4-18 11:54 , Processed in 0.061450 second(s), 10 queries , Gzip On, MemCache On.
