查看: 1065|回复: 17
求测速,有分加
发表于 2012-5-10 19:18:14 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
RT,前2页有分
PING和访问下,看看速度
特别是看下是哪个IP响应的
http://www.wohensha.com/
www.wohensha.com
发表于 2012-5-10 19:19:56 | 只看该作者
参与人数 1威望 +3 收起 理由
01801l + 3 赞一个!
发表于 2012-5-10 19:20:32 | 只看该作者
Pinging Wohensha-Firewall-DDoS.wohensha.com [218.77.
a:
Reply from 218.77.79.100: bytes=32 time=23ms TTL=53
Reply from 218.77.79.100: bytes=32 time=35ms TTL=53
Reply from 218.77.79.100: bytes=32 time=22ms TTL=53
参与人数 1威望 +5 收起 理由
01801l + 5 赞一个!
发表于 2012-5-10 19:21:56 | 只看该作者
Ping has started…
PING wohensha-firewall-ddos.wohensha.com (218.77.79.100): 56 data bytes
64 bytes from 218.77.79.100: icmp_seq=0 ttl=46 time=155.545 ms
64 bytes from 218.77.79.100: icmp_seq=1 ttl=46 time=156.272 ms
64 bytes from 218.77.79.100: icmp_seq=2 ttl=46 time=164.753 ms
64 bytes from 218.77.79.100: icmp_seq=3 ttl=46 time=165.270 ms
64 bytes from 218.77.79.100: icmp_seq=4 ttl=46 time=160.742 ms
64 bytes from 218.77.79.100: icmp_seq=5 ttl=46 time=163.030 ms
64 bytes from 218.77.79.100: icmp_seq=6 ttl=46 time=161.950 ms
64 bytes from 218.77.79.100: icmp_seq=7 ttl=46 time=167.562 ms
64 bytes from 218.77.79.100: icmp_seq=8 ttl=46 time=163.367 ms
64 bytes from 218.77.79.100: icmp_seq=9 ttl=46 time=160.667 ms
--- wohensha-firewall-ddos.wohensha.com ping statistics ---
10 packets transmitted, 10 packets received, 0.0% packet loss
round-trip min/avg/max/stddev = 155.545/161.916/167.562/3.604 ms
参与人数 1威望 +5 收起 理由
01801l + 5 赞一个!
发表于 2012-5-10 19:24:16 | 只看该作者
|                                      WinMTR statistics                                   |
|                       Host              -   %  | Sent | Recv | Best | Avrg | Wrst | Last |
|                          180.169.29.149 -    0 |   16 |   16 |    0 |    0 |    3 |    3 |
|                             218.1.7.141 -    0 |   16 |   16 |    1 |    2 |    6 |    2 |
|                          124.74.210.141 -    0 |   16 |   16 |    1 |    2 |    4 |    3 |
|                           202.101.63.74 -    0 |   16 |   16 |   19 |   24 |   97 |   19 |
|                             61.137.0.66 -    0 |   16 |   16 |   22 |   22 |   26 |   22 |
|                         220.169.231.130 -    0 |   16 |   16 |   32 |   32 |   34 |   32 |
|                         222.241.151.238 -    0 |   16 |   16 |   25 |   26 |   41 |   26 |
|                           218.77.79.242 -    0 |   16 |   16 |   22 |   23 |   27 |   23 |
|                           218.77.79.100 -    0 |   16 |   16 |   22 |   22 |   22 |   22 |
|________________________________________________|______|______|______|______|______|______|
   WinMTR v0.92 GPL V2 by Appnor MSP - Fully Managed Hosting & Cloud Provider
参与人数 1威望 +3 收起 理由
01801l + 3 赞一个!
发表于 2012-5-10 19:25:54 | 只看该作者
发表于 2012-5-10 19:26:26 | 只看该作者
218.77.79.100
135ms
参与人数 1威望 +3 收起 理由
01801l + 3 赞一个!
发表于 2012-5-10 19:28:51 | 只看该作者
发表于 2012-5-10 19:30:46 | 只看该作者
Microsoft Windows [版本 6.1.7601]
版权所有 (c) 2009 Microsoft Corporation。保留所有权利。
C:\Windows\System32>ping www.wohensha.com -t
正在 Ping Wohensha-Firewall-DDoS.wohensha.com [218.77.79.100] 具有 32 字节的数据
来自 218.77.79.100 的回复: 字节=32 时间=276ms TTL=50
来自 218.77.79.100 的回复: 字节=32 时间=277ms TTL=50
请求超时。
请求超时。
请求超时。
来自 218.77.79.100 的回复: 字节=32 时间=278ms TTL=50
参与人数 1威望 +3 收起 理由
01801l + 3 赞一个!
发表于 2012-5-10 19:34:03 来自手机 | 只看该作者
手机表示第二个比较快
参与人数 1威望 +1 收起 理由
01801l + 1 赞一个!
GMT+8, 2026-5-4 02:04 , Processed in 0.095670 second(s), 26 queries , Gzip On, MemCache On.
