查看: 918|回复: 10
这是什么原因造成的?如何解决
发表于 2012-5-10 16:01:22 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我空间绑定了两个域名 上传好程序 用A域名浏览安装,安装完之后 A域名访问正常 用B域名访问 也可以访问 不过头部就出现下面这个错误代码
Warning: session_start() [function.session-start]: open(/tmp/sess_29a414bb551c05bb7dbf273b498e6ffc, O_RDWR) failed: Permission denied (13) in /home/ftp/1520/netna/xwucom/include/common.php on line 28
下载common.php下来看 第28行是:session_start();
这是为什么呢?
发表于 2012-5-10 16:05:51 | 只看该作者
你不贴全代码,咩咩都帮不了你
 楼主| 发表于 2012-5-10 16:08:34 | 只看该作者
lazyzhu 发表于 2012-5-10 16:05
你不贴全代码,咩咩都帮不了你
<?php
if (!defined('IN_PHPMPS'))
    die('Access Denied');
error_reporting(E_ERROR | E_WARNING | E_PARSE);
define('PHPMPS_ROOT', str_replace("\\", '/', substr(dirname(__FILE__), 0, -7)));
$PHP_SELF = isset($_SERVER['PHP_SELF']) ? $_SERVER['PHP_SELF'] : $_SERVER['SCRIPT_NAME'];
if ('/' == substr($php_self, -1))$PHP_SELF .= 'index.php';
$PHP_QUERYSTRING = $_SERVER['QUERY_STRING'];
$PHP_DOMAIN = $_SERVER['SERVER_NAME'];
$PHP_SCHEME = $_SERVER['SERVER_PORT'] == '443' ? 'https://' : 'http://';
$PHP_PORT = $_SERVER['SERVER_PORT'] == '80' ? '' : ':'.$_SERVER['SERVER_PORT'];
$PHP_URL = $PHP_SCHEME.$PHP_DOMAIN.$PHP_PORT.$PHP_SELF.($PHP_QUERYSTRING ? '?'.$PHP_QUERYSTRING : '');
if (!file_exists(PHPMPS_ROOT . 'data/install.lock')) {
        header("Location:./install/index.php");
        exit;
require PHPMPS_ROOT . 'data/config.php';
require PHPMPS_ROOT . 'include/global.fun.php';
@set_magic_quotes_runtime(0);
@ini_set('session.auto_start', 0);
session_start();
header('Content-type: text/html; charset='.$charset);
if(!get_magic_quotes_gpc()) {
        if (!empty($_GET))$_GET  = addslashes_deep($_GET);
    if (!empty($_POST))$_POST = addslashes_deep($_POST);
    $_COOKIE   = addslashes_deep($_COOKIE);
    $_REQUEST  = addslashes_deep($_REQUEST);
if(function_exists('date_default_timezone_set')){
    date_default_timezone_set('Asia/Shanghai');
require PHPMPS_ROOT . 'include/mysql.class.php';
$db = new mysql($db_host, $db_user, $db_pass, $db_name, '1');
$db_host = $db_user = $db_pass = $db_name = NULL;
$CFG = get_config();
if($CFG['closesystem']) showmsg($CFG['close_tips']);
$_userid = 0;
$_username = '';
$uid = $_SESSION['userid'] ? $_SESSION['userid'] : $_COOKIE['userid'];
if(!empty($uid)) {
        $user_info = $db->getRow("select userid,username,lastposttime,status from {$table}member where userid='$uid' ");
        if($user_info) {
                $_userid = $user_info['userid'];
                $_username = $user_info['username'];
                $_lastposttime = $user_info['lastposttime'];
                $_status = $user_info['status'];
define('DEBUG_MODE', 0);
define('PHPMPS_PATH', $CFG['weburl'].'/');//网址
define('CSS_PATH', $CFG['weburl'].'/templates/'.$CFG['tplname'].'/style/');//css网址
define('IMG_PATH', $CFG['weburl'].'/templates/'.$CFG['tplname'].'/images/');//图片网址
require PHPMPS_ROOT . 'include/header.php';
发表于 2012-5-10 16:15:04 | 只看该作者
chmod 1777 /tmp
发表于 2012-5-10 16:15:27 | 只看该作者
/tmp 的权限问题。。。
参与人数 1威望 +20 收起 理由
Kokgog + 20 咩咩与真相同在......
发表于 2012-5-10 16:16:19 | 只看该作者
发表于 2012-5-10 16:19:26 | 只看该作者
给tmp文件夹777的递归权限
 楼主| 发表于 2012-5-10 16:19:49 | 只看该作者
pathletboy 发表于 2012-5-10 16:15
chmod 1777 /tmp
我试试看 不过很奇怪 在IE下访问会有问题 在OPERA上没有出现什么问题
发表于 2012-5-10 16:21:20 来自手机 | 只看该作者
28行什么意思啊
发表于 2012-5-10 16:22:04 来自手机 | 只看该作者
缓存问题吧。  试试不开缓存,或者重新缓存
GMT+8, 2026-4-22 09:48 , Processed in 0.113336 second(s), 13 queries , Gzip On, MemCache On.
