查看: 4007|回复: 29
[美国VPS] 斯巴达AMD 7950X跑分
发表于 2023-11-7 19:10:38 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
  1. Linux x.com 5.10.0-20-amd64 #1 SMP Debian 5.10.158-2 (2022-12-13) x86_64
  2. The programs included with the Debian GNU/Linux system are free software;
  3. the exact distribution terms for each program are described in the
  4. individual files in /usr/share/doc/*/copyright.
  5. Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
  6. permitted by applicable law.
  7. root@x:~# wget -qO- yabs.sh | bash
  8. # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## #
  9. #              Yet-Another-Bench-Script              #
  10. #                     v2023-09-06                    #
  11. # https://github.com/masonr/yet-another-bench-script #
  12. # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## #
  13. Tue 07 Nov 2023 06:52:01 PM CST
  14. Basic System Information:
  15. ---------------------------------
  16. Uptime     : 0 days, 4 hours, 12 minutes
  17. Processor  : AMD Ryzen 9 7950X 16-Core Processor
  18. CPU cores  : 2 @ 4499.964 MHz
  19. AES-NI     : ✔ Enabled
  20. VM-x/AMD-V : ✔ Enabled
  21. RAM        : 1.9 GiB
  22. Swap       : 4.0 GiB
  23. Disk       : 50.0 GiB
  24. Distro     : Debian GNU/Linux 11 (bullseye)
  25. Kernel     : 5.10.0-20-amd64
  26. VM Type    : KVM
  27. IPv4/IPv6  : ✔ Online / ✔ Online
  28. IPv6 Network Information:
  30. ISP        : Spartan Host LLC
  31. ASN        : AS201106 Spartan Host Ltd
  32. Host       : Spartan Host Ltd
  33. Location   : Seattle, Washington (WA)
  34. Country    : United States
  35. fio Disk Speed Tests (Mixed R/W 50/50):
  36. ---------------------------------
  37. Block Size | 4k            (IOPS) | 64k           (IOPS)
  38.   ------   | ---            ----  | ----           ----
  39. Read       | 620.55 MB/s (155.1k) | 3.30 GB/s    (51.6k)
  40. Write      | 622.19 MB/s (155.5k) | 3.32 GB/s    (51.9k)
  41. Total      | 1.24 GB/s   (310.6k) | 6.62 GB/s   (103.5k)
  42.            |                      |
  43. Block Size | 512k          (IOPS) | 1m            (IOPS)
  44.   ------   | ---            ----  | ----           ----
  45. Read       | 3.92 GB/s     (7.6k) | 4.29 GB/s     (4.1k)
  46. Write      | 4.12 GB/s     (8.0k) | 4.57 GB/s     (4.4k)
  47. Total      | 8.05 GB/s    (15.7k) | 8.86 GB/s     (8.6k)
  48. iperf3 Network Speed Tests (IPv4):
  49. ---------------------------------
  50. Provider        | Location (Link)           | Send Speed      | Recv Speed      | Ping
  51. -----           | -----                     | ----            | ----            | ----
  52. Clouvider       | London, UK (10G)          | 1.04 Gbits/sec  | 981 Mbits/sec   | 123 ms
  53. Scaleway        | Paris, FR (10G)           | busy            | busy            | 157 ms
  54. NovoServe       | North Holland, NL (40G)   | 1.07 Gbits/sec  | 102 Mbits/sec   | 128 ms
  55. Uztelecom       | Tashkent, UZ (10G)        | busy            | 394 Mbits/sec   | 211 ms
  56. Clouvider       | NYC, NY, US (10G)         | 2.45 Gbits/sec  | 1.33 Gbits/sec  | 56.4 ms
  57. Clouvider       | Dallas, TX, US (10G)      | 894 Mbits/sec   | 680 Mbits/sec   | 59.1 ms
  58. Clouvider       | Los Angeles, CA, US (10G) | 3.19 Gbits/sec  | 3.51 Gbits/sec  | 28.6 ms
  59. iperf3 Network Speed Tests (IPv6):
  60. ---------------------------------
  61. Provider        | Location (Link)           | Send Speed      | Recv Speed      | Ping
  62. -----           | -----                     | ----            | ----            | ----
  63. Clouvider       | London, UK (10G)          | 1.25 Gbits/sec  | 1.22 Gbits/sec  | 123 ms
  64. Scaleway        | Paris, FR (10G)           | busy            | busy            | 133 ms
  65. NovoServe       | North Holland, NL (40G)   | 1.34 Gbits/sec  | 143 Mbits/sec   | 128 ms
  66. Uztelecom       | Tashkent, UZ (10G)        | 120 Mbits/sec   | 576 Mbits/sec   | 207 ms
  67. Clouvider       | NYC, NY, US (10G)         | 2.79 Gbits/sec  | busy            | 56.6 ms
  68. Clouvider       | Dallas, TX, US (10G)      | 2.65 Gbits/sec  | 943 Mbits/sec   | 59.1 ms
  69. Clouvider       | Los Angeles, CA, US (10G) | 6.61 Gbits/sec  | 2.68 Gbits/sec  | 27.0 ms
  70. Geekbench 6 Benchmark Test:
  71. ---------------------------------
  72. Test            | Value
  73.                 |
  74. Single Core     | 2854
  75. Multi Core      | 5055
  76. Full Test       | https://browser.geekbench.com/v6/cpu/3433562
  77. YABS completed in 12 min 54 sec
配置:2C2G50G
月付:9.6/刀
AFF:https://billing.spartanhost.net/aff.php?aff=2358&gid=12
跑分比某些杜甫还猛
另外,收AMD黑五款有割爱的大佬论坛pm我一下
来自 29#
 楼主| 发表于 2023-11-7 21:01:56 | 只看该作者
2life.top 发表于 2023-11-7 20:35
能跑一下融合怪脚本不,地址:https://github.com/spiritLHLS/ecs
  3. 版本:2023.11.07
  4. 更新日志:VPS融合怪测试(集百家之长)
  6. CPU 型号          : AMD Ryzen 9 7950X 16-Core Processor
  7. CPU 核心数        : 2
  8. CPU 频率          : 4499.964 MHz
  9. CPU 缓存          : L1: 128.00 KB / L2: 2.00 MB / L3: 128.00 MB
  10. 硬盘空间          : 9.03 GiB / 49.87 GiB
  11. 启动盘路径        : /dev/sda3
  12. 内存              : 654.46 MiB / 1.90 GiB
  13. Swap              : 4.62 MiB / 4.00 GiB
  14. 系统在线时间      : 0 days, 6 hour 14 min
  15. 负载              : 0.07, 0.04, 0.01
  16. 系统              : Debian GNU/Linux 11 (bullseye) (x86_64)
  17. AES-NI指令集      : ✔ Enabled
  18. VM-x/AMD-V支持    : ✔ Enabled
  20. 内核              : 5.10.0-20-amd64
  21. TCP加速方式       : cubic
  22. 虚拟化架构        : KVM
  23. NAT类型           : 开放型
  24. IPV4 ASN          : AS50131 Spartan Host Ltd
  25. IPV4 位置         : Seattle / Washington / US
  26. IPV6 ASN          : AS50131 Spartan Host
  27. IPV6 位置         : Seattle / Washington
  28. ---------------------CPU测试--感谢lemonbench开源------------------------
  29. -> CPU 测试中 (Fast Mode, 1-Pass @ 5sec)
  30. 1 线程测试(1核)得分:           6260 Scores
  31. 2 线程测试(多核)得分:          12392 Scores
  32. ---------------------内存测试--感谢lemonbench开源-----------------------
  33. -> 内存测试 Test (Fast Mode, 1-Pass @ 5sec)
  34. 单线程读测试:          75983.30 MB/s
  35. 单线程写测试:          37471.18 MB/s
  36. ------------------磁盘dd读写测试--感谢lemonbench开源--------------------
  37. -> 磁盘IO测试中 (4K Block/1M Block, Direct Mode)
  38. 测试操作               写速度                                  读速度
  39. 100MB-4K Block         90.1 MB/s (22.00 IOPS, 1.16s))          108 MB/s (26443 IOPS, 0.97s)
  40. 1GB-1M Block           3.6 GB/s (3417 IOPS, 0.29s)             3.7 GB/s (3527 IOPS, 0.28s)
  41. ---------------------磁盘fio读写测试--感谢yabs开源----------------------
  42. Block Size | 4k            (IOPS) | 64k           (IOPS)
  43.   ------   | ---            ----  | ----           ----
  44. Read       | 568.66 MB/s (142.1k) | 3.34 GB/s    (52.2k)
  45. Write      | 570.16 MB/s (142.5k) | 3.36 GB/s    (52.5k)
  46. Total      | 1.13 GB/s   (284.7k) | 6.71 GB/s   (104.8k)           |                      |
  47. Block Size | 512k          (IOPS) | 1m            (IOPS)
  48.   ------   | ---            ----  | ----           ----
  49. Read       | 4.08 GB/s     (7.9k) | 4.28 GB/s     (4.1k)
  50. Write      | 4.30 GB/s     (8.4k) | 4.56 GB/s     (4.4k)
  51. Total      | 8.38 GB/s    (16.3k) | 8.84 GB/s     (8.6k)
  52. ---------------------流媒体解锁--感谢sjlleo开源-------------------------
  53. 以下测试的解锁地区是准确的,但是不是完整解锁的判断可能有误,这方面仅作参考使用
  54. ----------------有图比----------------
  55. [IPv4]
  56. 连接方式: 有图比 Video Server
  57. 视频缓存节点地域: 美国  西雅图(SEA09S34)
  58. 有图比识别地域: 无信息(null)
  59. [IPv6]
  60. 连接方式: 有图比 Video Server
  61. 视频缓存节点地域: 美国  西雅图(SEA09S34)
  62. 有图比识别地域: 无信息(null)
  63. ----------------Netflix----------------
  64. [IPv4]
  65. 您的出口IP可以使用Netflix,但仅可看Netflix自制剧
  66. NF所识别的IP地域信息:美国
  67. [IPv6]
  68. 您的出口IP可以使用Netflix,但仅可看Netflix自制剧
  69. NF所识别的IP地域信息:美国
  70. ---------------DisneyPlus---------------
  71. [IPv4]
  72. 当前IPv4出口解锁DisneyPlus
  73. 区域:美国区
  74. [IPv6]
  75. 当前IPv6出口解锁DisneyPlus
  76. 区域:美国区
  77. 解锁有图比,Netflix,DisneyPlus上面和下面进行比较,不同之处自行判断
  78. ----------------流媒体解锁--感谢RegionRestrictionCheck开源--------------
  79. 以下为IPV4网络测试,若无IPV4网络则无输出
  80. ============[ Multination ]============
  81. Dazn:                                  Yes (Region: US)
  82. HotStar:                               No
  83. Disney+:                               No
  84. Netflix:                               Originals Only
  85. 有图比 Premium:                       Yes
  86. Amazon Prime Video:                    Yes (Region: US)
  87. TVBAnywhere+:                          Yes
  88. iQyi Oversea Region:                   US
  89. Viu.com:                               No
  90. 有图比 CDN:                           Seattle, WA
  91. Netflix Preferred CDN:                 Seattle, WA
  92. Spotify Registration:                  No
  93. Steam Currency:                        USD
  94. ChatGPT:                               Yes
  95. =======================================
  96. 以下为IPV6网络测试,若无IPV6网络则无输出
  97. ============[ Multination ]============
  98. Dazn:                                  Failed (Network Connection)
  99. HotStar:                               Yes (Region: US)
  100. Disney+:                               Yes (Region: US)
  101. Netflix:                               Originals Only
  102. 有图比 Premium:                       Yes
  103. Amazon Prime Video:                    Unsupported
  104. TVBAnywhere+:                          Failed (Network Connection)
  105. iQyi Oversea Region:                   Failed
  106. Viu.com:                               Failed
  107. 有图比 CDN:                           Seattle, WA
  108. Netflix Preferred CDN:                 Seattle, WA
  109. Spotify Registration:                  No
  110. Steam Currency:                        Failed (Network Connection)
  111. ChatGPT:                               Yes
  112. =======================================
  113. ---------------TikTok解锁--感谢lmc999的源脚本及fscarmen PR--------------
  114. Tiktok Region:         【US】
  115. -------------------欺诈分数以及IP质量检测--本脚本原创-------------------
  116. 数据仅作参考,不代表100%准确,如果和实际情况不一致请手动查询多个数据库比对
  117. 以下为各数据库编号,输出结果后将自带数据库来源对应的编号
  118. ipinfo数据库 ①  | scamalytics数据库 ②  | virustotal数据库 ③  | abuseipdb数据库 ④  | ip2location数据库   ⑤
  119. ip-api数据库 ⑥  | ipwhois数据库     ⑦  | ipregistry数据库 ⑧  | ipdata数据库    ⑨  | ipgeolocation数据库 ⑩
  120. 欺诈分数(越低越好): 50②
  121. abuse得分(越低越好): 0④
  122. IP类型:
  123.   使用类型(usage_type):hosting①  Data Center/Web Hosting/Transit⑤  hosting⑧  business⑨
  124.   公司类型(company_type):hosting①  business⑧
  125.   云服务提供商(cloud_provider):  Yes⑧
  126.   数据中心(datacenter):  No②   Yes⑥ ⑨
  127.   移动网络(mobile):  No⑥
  128.   代理(proxy):  No①   Yes② ⑥ ⑦ ⑧ ⑨ ⑩
  129.   扶墙(扶墙):  No① ② ⑦ ⑧
  130.   TOR(tor):  No① ② ⑦ ⑧ ⑨
  131.   TOR出口(tor_exit):  No⑧
  132.   搜索引擎机器人(search_engine_robot):  No②
  133.   匿名代理(anonymous):  Yes⑦ ⑧   No⑨
  134.   攻击方(attacker):  No⑧ ⑨
  135.   滥用者(abuser):  No⑧ ⑨
  136.   威胁(threat):  No⑧ ⑨
  137.   iCloud中继(icloud_relay):  No① ⑧ ⑨
  138.   未分配IP(bogon):  No⑧ ⑨
  139. Google搜索可行性:YES
  140. 端口25检测:
  141.   本地: Yes
  142.   163邮箱: Yes
  143.   gmail邮箱: Yes
  144.   outlook邮箱: Yes
  145.   yandex邮箱: Yes
  146.   qq邮箱: Yes
  147. ------以下为IPV6检测------
  148. 欺诈分数(越低越好): 0②
  149. abuse得分(越低越好): 0④
  150. IP类型: Data Center/Web Hosting/Transit⑤
  151. ----------------三网回程--感谢zhanghanyun/backtrace开源-----------------
  152. 国家: US 城市: Seattle 服务商: AS50131 Spartan Host Ltd
  153. 北京电信 219.141.136.12  联通4837[普通线路]
  154. 北京联通 202.106.50.1    联通4837[普通线路]
  155. 北京移动 221.179.155.161 移动CMI [普通线路]
  156. 上海电信 202.96.209.133  联通4837[普通线路]
  157. 上海联通 210.22.97.1     联通4837[普通线路]
  158. 上海移动 211.136.112.200 移动CMI [普通线路]
  159. 广州电信 58.60.188.222   联通4837[普通线路]
  160. 广州联通 210.21.196.6    联通4837[普通线路]
  161. 广州移动 120.196.165.24  移动CMI [普通线路]
  162. 成都电信 61.139.2.69     联通4837[普通线路]
  163. 成都联通 119.6.6.6       联通4837[普通线路]
  164. 成都移动 211.137.96.205  移动CMI [普通线路]
  165. ---------------------回程路由--感谢fscarmen开源及PR---------------------
  166. 核心程序来自ipip.net或nexttrace,请知悉!
  167. --------------------自动更新测速节点列表--本脚本原创--------------------
  168. 位置             上传速度        下载速度        延迟     丢包率
  169. Speedtest.net    957.77 Mbps     8922.21 Mbps    0.26     0.0%
  170. 洛杉矶           1608.48 Mbps    3148.81 Mbps    27.75    0.0%
  171. 法兰克福         513.70 Mbps     3259.96 Mbps    158.18   NULL
  172. 联通上海5G       568.65 Mbps     4089.80 Mbps    134.97   0.0%
  173. 联通湖南5G       473.38 Mbps     383.51 Mbps     161.77   NULL
  174. 电信江苏5G       233.19 Mbps     2735.69 Mbps    150.47   0.0%
  175. 电信浙江         347.63 Mbps     1204.80 Mbps    159.06   NULL
  176. 移动硬核通信     287.40 Mbps     561.76 Mbps     200.56   NULL
  177. ------------------------------------------------------------------------
  178. 总共花费      : 5 分 20 秒
  179. 时间          : Tue Nov  7 20:59:35 CST 2023
  180. ------------------------------------------------------------------------
发表于 2023-11-7 19:35:19 来自手机 | 只看该作者
我的hostbrr也是这个配置 季付4.2刀
发表于 2023-11-7 19:46:51 来自手机 | 只看该作者
发表于 2023-11-7 19:20:14 | 只看该作者
双核顶绿云9周年9核   10周年5核
发表于 2023-11-7 19:13:45 | 只看该作者
没有 5 折,一年得 93 刀,不如我的 63 刀划算,就是 CPU 变成 5950x,完全够用了
 楼主| 发表于 2023-11-7 19:15:24 来自手机 | 只看该作者
solomon314 发表于 2023-11-7 19:13
没有 5 折,一年得 93 刀,不如我的 63 刀划算,就是 CPU 变成 5950x,完全够用了 ...
同感,收不到63先买个9.6的过度一下吧
发表于 2023-11-7 19:15:28 | 只看该作者
我看全是5950x啊
发表于 2023-11-7 19:16:05 | 只看该作者
只是写的这样,开出来就是 7950x 了
发表于 2023-11-7 19:16:43 | 只看该作者
普通建站的话用不到这么好的机器吧,这是为计算准备的?
 楼主| 发表于 2023-11-7 19:17:37 来自手机 | 只看该作者
吃灰准备,买个体验体验
发表于 2023-11-7 19:18:17 | 只看该作者
说不定今年还搞优惠呢?
毕竟挣钱不寒碜,赌一把,黑五时候问问客服,虽然我问的是在西雅图不搞活动
发表于 2023-11-7 19:18:49 | 只看该作者
山爱一 发表于 2023-11-7 19:17
吃灰准备,买个体验体验
线路和搬瓦工gia比差多少,测试了吗
GMT+8, 2026-4-27 10:17 , Processed in 0.068438 second(s), 13 queries , Gzip On, MemCache On.
