查看: 1760|回复: 0
Kibana的搭建与配置
发表于 2023-11-3 22:06:42 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Kibana是一个开源的分析与可视化平台,设计出来用于和Elasticsearch一起使用的。你可以用kibana搜索、查看、交互存放在Elasticsearch索引里的数据,使用各种不同的图表、表格、地图等kibana能够很轻易地展示高级数据分析与可视化。
注意:kibana和Elasticsearch的版本要一致,否则会有问题
下载与解压
wget https://artifacts.elastic.co/downloads/kibana/kibana-6.6.1-linux-x86_64.tar.gz
tar -xvf kibana-6.6.1-linux-x86_64.tar.gz
mv kibana-6.6.1-linux-x86_64 /usr/local/kibana
修改配置文件
/usr/local/kibana/config/kibana.yml
# Kibana is served by a back end server. This setting specifies the port to use.
server.port: 5601 #监听端口
# Specifies the address to which the Kibana server will bind. IP addresses and host names are both valid values.
# The default is 'localhost', which usually means remote machines will not be able to connect.
# To allow connections from remote users, set this parameter to a non-loopback address.
server.host: "0.0.0.0" #服务ip
# Enables you to specify a path to mount Kibana at if you are running behind a proxy. This only affects
# the URLs generated by Kibana, your proxy is expected to remove the basePath value before forwarding requests
# to Kibana. This setting cannot end in a slash.
#server.basePath: ""
# The maximum payload size in bytes for incoming server requests.
#server.maxPayloadBytes: 1048576
# The Kibana server's name.  This is used for display purposes.
#server.name: "your-hostname"
# The URL of the Elasticsearch instance to use for all your queries.
elasticsearch.url: "http://10.1.1.1:9200" #elasticsearch集群中其中IP
# When this setting's value is true Kibana uses the hostname specified in the server.host
# setting. When the value of this setting is false, Kibana uses the hostname of the host
# that connects to this Kibana instance.
elasticsearch.preserveHost: true
# Kibana uses an index in Elasticsearch to store saved searches, visualizations and
# dashboards. Kibana creates a new index if the index doesn't already exist.
kibana.index: ".kibana"
# The default application to load.
kibana.defaultAppId: "discover"
启动脚本
保存文件/lib/systemd/system/kibana.service
[Unit]
Description=Kibana
After=network.target
[Service]
ExecStart=/workspace/kibana/bin/kibana
Type=simple
PIDFile=/var/run/kibana.pid
Restart=always
[Install]
WantedBy=default.target
systemctl enable kibana #开机自启动
systemctl start kibana #启动kibana
GMT+8, 2026-5-2 05:18 , Processed in 0.056217 second(s), 10 queries , Gzip On, MemCache On.
