查看: 1448|回复: 5
cloudcone发邮件换ip了
发表于 2023-11-3 16:28:36 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
You are receiving this email because you have one or more VPS or SC2 instances in your account that is undergoing an IPv4 address change.
Our datacenter has informed us of an IPv4 re-numbering process that will result in a change of your VPS or SC2 IPv4 addresses.
We understand that this change causes inconvenience for you. In order to minimize the impact, you have the option to schedule the above steps during a maintenance window of your choice, before November 30th, 2023.
During that time, if you require any assistance in configuring your IP, reach out to our support team through a support ticket and we should be able to assist you.
We thank you for understanding, if you have any quick questions, please do reply to this email.
这几年图便宜买的小鸡vir家的,cc家的都在频繁换ip啊
 楼主| 发表于 2023-11-3 16:30:48 | 只看该作者
频繁指vir,感觉有一台机器被迫换了4次ip了。cc倒是第一次
发表于 2023-11-3 18:50:00 来自手机 | 只看该作者
rn那边不知道咋回事,换个ip网速都看不下去了,换鸡才好。我觉得这换ip和线路没啥关系吧
Send by DZ Reader
发表于 2023-11-3 18:54:14 | 只看该作者
Send by DZ Reade ...
cloudcone和racknerd都是用的MC机房的 他俩也是“被迫”换IP 因为MC那边要换
发表于 2023-11-3 18:55:57 来自手机 | 只看该作者
blues 发表于 2023/11/3周五 18:54:14
我知道是被迫的,只是不明白换ip怎么会影响线路(技术层面上)
Send by DZ Reader
GMT+8, 2026-4-19 12:50 , Processed in 0.061353 second(s), 10 queries , Gzip On, MemCache On.
