查看: 2621|回复: 19
刚注册了loc,还顺便把racknerd的小鸡免费迁移到洛杉矶dc2了
发表于 2023-11-2 16:17:52 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
rn小鸡是10月6号买的,买完后就尝试发工单找客服切换机房了,当时听说洛杉矶dc2速度可以,结果当时扯皮说没库存了,最后答应一个月以后重新发工单联系客服。
今天看到rn的双11活动,dc2机房出新库存了,我就立马尝试找客服切换,果然还是扯皮说我的型号不支持迁移,说1h1g的套餐没库存,扯半天后客服答应3美刀就迁移,我就重新回复:700m内存,10g储存的服务器都在dc2有库存,为什么我的比那个配置高都没库存?(那个套餐11.3刀,我买的是10.98刀的),结果客服同意免费迁移了
现在已经迁移完成了,正在扯皮要ipv6和恢复双倍流量(之前在let网站获得的双倍流量消失了)
发表于 2023-11-2 16:20:47 | 只看该作者
怎么说呢 MMJ 精神到位了
发表于 2023-11-2 16:20:06 | 只看该作者
不是说最近DC02不好吗,我还在想181把我的圣何塞迁移到dc2
 楼主| 发表于 2023-11-2 16:25:09 | 只看该作者
我之前服务器是达拉斯的,直接ping的延迟是230~280乱跳,但是我目前的dc2 ping延迟是195~210,长ping了10分钟左右,待会试试搭节点看看延迟吧,晚上有空我再发晚高峰期延迟
 楼主| 发表于 2023-11-2 16:26:26 | 只看该作者
我遇到的所有都是英文客服,然后我拿个翻译器和对面交流,没一点阻碍
估计是我发工单的时候就是英文问的吧,如果你拿中文发工单估计会遇到中文客服
 楼主| 发表于 2023-11-2 16:36:08 | 只看该作者
我不知道为什么论坛发图片要link,直接粘贴文字吧
然后双倍流量也恢复了,变成6t了
Hello,
Your request has been completed. Please let us know if you require any further assistance.
We have successfully added the IPV6 address for your server please allow some time for the configuration.
And also please note For Ubuntu & Debian instance needs to enable IPV6 manually after configuring. Kindly follow the below-mentioned steps to enable the IPv6 address for your server.
Login to your server via ssh connection and adding the the below entries in sysctl.conf file:
nano /etc/sysctl.conf
Scroll all the way down, and add the following lines at the end:
net.ipv6.conf.all.autoconf = 0
net.ipv6.conf.all.accept_ra = 0
net.ipv6.conf.eth0.autoconf = 0
net.ipv6.conf.eth0.accept_ra = 0
To check run:
sysctl -p
Then try to restart network
systemctl restart networking
Then check with
ping6 google.com
If its still not working try to reboot your VPS once.
Note: Lastly, also ensure that your /etc/sysctl.conf file does not have any values in place that might be disabling IPv6 connectivity. If it does, be sure to comment those out and refresh your settings afterwards by using "sysctl -p" or by rebooting your VPS.
Feel free to contact us for further assistance.
Thank You,
发表于 2023-11-2 16:41:20 | 只看该作者
phigros 发表于 2023-11-2 16:25
我之前服务器是达拉斯的,直接ping的延迟是230~280乱跳,但是我目前的dc2 ping延迟是195~210,长ping了10 ...
哦哦,好的,我看看要不要也迁移过去,圣何塞现在100-300内好像,我用itdog测了下
GMT+8, 2026-5-1 07:55 , Processed in 0.069511 second(s), 11 queries , Gzip On, MemCache On.
