查看: 4005|回复: 11
[已解决] cpu100%求助技术高手
发表于 2012-5-8 17:14:01 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
目前已经确认是这个原因:插件用了这个PHP 的 file_get_contents()
因为我用了一个dx2自动保存图片的插件
网上查到说可以换成这样<?php
$ctx = stream_context_create(array(
   'http' => array(
       'timeout' => 1 //设置一个超时时间,单位为秒
file_get_contents("http://loc.qiche.eu.org/", 0, $ctx);
但我不知道怎么换,有高手指点一下吗,试了几次都不行;要是有好用的dx2自动保存图片的插件共享下也行
插件源码如下
<?php
if(!defined('IN_DISCUZ')) {
        exit('Access Denied');
class
plugin_yxf_picdown {
class plugin_yxf_picdown_forum extends
        function post_picdown(){
global $_G;
                @extract($_G['cache']['plugin']
['yxf_picdown']);
                if(!$_POST) return '';
                if(!in_array
($_G['groupid'],(array)unserialize($usegids))) return '';
                if
(!in_array($_G['fid'],(array)unserialize($usefids))) return '';
                if
(preg_match_all("/\[img[^\]]*\](.*)\[\/img\]/isU",$_G['gp_message'],$regs)){
        @set_time_limit(0);
                        require_once libfile
('class/image');
                        $image = new image;
        if($downway==3){
                                require_once
libfile('class/ftp');
                                $ftp = new discuz_ftp();
                        if(!($_G['setting']['ftp']['connid'] = $ftp-
>connect())) {
                                        return
FALSE;
                $watermarkstatus=unserialize($_G['setting']
['watermarkstatus']);
$expdomains=explode("\n",str_replace("\r","",$expdomains));
$expdomains[]=$_G['siteurl'];
                        foreach ($regs[1] as
$key=>$url){
                                $url=trim($url);
                if(substr($url,0,7)!='http://') continue;
        $isexp=0;
                                foreach ($expdomains
as $domain){
$domain=trim($domain);
                                        if
($domain&&strpos($url,$domain)!==false){
                $isexp=1;
break;
                                if($isexp){
                continue;
                $ym=date('Ym');
$d=date('d');
                                $his=date('His');
                if($downway==1){//保存为文件
        $dir="data/downpic/";
if(!is_dir($dir)) @mkdir($dir);
$dir.="{$ym}/";
                                        if(!is_dir
                                        $dir.="{$d}/";
                        $target=$dir.md5($url).".jpg";
                $attachsave=savefile($url,$target);
                if($attachsave){
        if($watermarkstatus['forum'] && empty($_G['forum']
['disablewatermark'])) {
        $image->Watermark($target);
$_G['gp_message']=str_replace($url,$_G['siteurl'].$target,$_G
['gp_message']);
                                elseif
($downway==2||$downway==3){//保存为附件
        $remote=0;
                                        if
(!is_dir($_G['setting']['attachdir']."/forum/".$ym."/")) @mkdir($_G['setting']
['attachdir']."/forum/".$ym."/");
                                        if
(!is_dir($_G['setting']['attachdir']."/forum/".$ym."/".$d."/")) @mkdir($_G
['setting']['attachdir']."/forum/".$ym."/".$d."/");
        $attachmenturl=$ym."/".$d."/".$his.strtolower(random(16)).".jpg";
                                $target=$_G['setting']
['attachdir']."/forum/".$attachmenturl;
if($downway==3){
                                $target=$_G['setting']['ftp']
['attachurl'].'/forum/'.$attachmenturl;
$ftp->upload($url,'forum/'.$attachmenturl);
        $remote=1;
$sizeinfo=@getimagesize($url);
        $attachsave=$sizeinfo[0];
}else{
                                        if($attachsave){
                                $width=$attachsave;
                        $filename=$key.'.jpg';
                        $filetype='application/octet-stream';
                                $filesize=filesize($target);
                                $isimage=1;
                        $thumb=0;
if(!$remote){
$thumb = $image->Thumb($target, '', $_G['setting']['thumbwidth'], $_G
['setting']['thumbheight'], $_G['setting']['thumbstatus'], $_G['setting']
['thumbsource']) ? 1 : 0;
        if(!$_G['setting']['thumbsource']) {
                                $width = $image->imginfo['width'];
empty($_G['forum']['disablewatermark'])) {
                        DB::query("INSERT INTO ".DB::table
("forum_attachment_unused")." ( `aid` , `width` , `dateline` , `filename` ,
`filetype` , `filesize` , `attachment` , `downloads` , `isimage` , `uid` , `thumb` ,
`remote` )
VALUES (NULL , '0', '0', '$width', '{$_G['timestamp']}', '0', '0',
'{$filename}', '{$filetype}', '{$filesize}', '{$attachmenturl}', '0', '{$isimage}',
'{$_G['uid']}', '{$thumb}', '{$remote}');");
DB::query("INSERT INTO  ".DB::table("forum_attachment")."
                        (  `aid` ,  `tid` ,  `pid` ,  `uid` ,  `tableid` ,
`downloads` )
VALUES
                                                (NULL ,  '0',
'0',  '{$_G['uid']}',  '127',  '0');");
$aid=DB::insert_id();
DB::query("INSERT INTO  ".DB::table("forum_attachment_unused")."
                                (  `aid` ,  `uid` ,  `dateline` ,
`filename` ,  `filesize` , `attachment` ,  `remote` ,  `isimage` ,  `width` ,
`thumb` )
                                                VALUES
                                ('$aid',  '{$_G['uid']}',  '{$_G
['timestamp']}',  '{$filename}','{$filesize}',  '{$attachmenturl}',   '{$remote}',
'{$isimage}',  '{$width}',  '{$thumb}');");
$_G['gp_attachnew'][$aid]=array();
        $_G['gp_message']=str_replace_once($regs[0]
[$key],"[attachimg]{$aid}[/attachimg]",$_G['gp_message']);//因为当前DX不支
持多次引用附件
                        if
($downway==3){
                                $ftp->ftp_close();
                //die();
function
xdfopen($url, $limit = 0, $post = '', $cookie = '', $bysocket = FALSE, $ip = '',
$timeout = 15, $block = TRUE) {
        $return = '';
        $matches =
parse_url($url);
        $host = $matches['host'];
        $path = $matches
['path'] ? $matches['path'].(isset($matches['query']) && $matches['query'] ?
'?'.$matches['query'] : '') : '/';
        $port = !empty($matches['port']) ? $matches
['port'] : 80;
        if($post) {
                $out = "POST $path HTTP/1.0
\r\n";
                $out .= "Accept: */*\r\n";
                $out .=
"Accept-Language: zh-cn\r\n";
                $out .= "Content-Type:
application/x-www-form-urlencoded\r\n";
                $out .= "User-Agent:
$_SERVER[HTTP_USER_AGENT]\r\n";
                $out .= "Host:
$host\r\n";
                $out .= 'Content-Length: '.strlen($post)."\r\n";
$out .= "Connection: Close\r\n";
                $out .= "Cache-Control: no-
cache\r\n";
                $out .= "Cookie: $cookie\r\n\r\n";
$out .= $post;
        } else {
                $out = "GET $path HTTP/1.0\r\n";
                $out .= "Accept-
                $out .= "User-Agent: $_SERVER
                $out .= "Host: $host\r\n";
        $fp = @fsockopen(($ip ? $ip : $host), $port, $errno, $errstr,
$timeout);
        if(!$fp) {
                return '';
        } else {
stream_set_blocking($fp, $block);
                stream_set_timeout
($fp, $timeout);
                @fwrite($fp, $out);
                $status =
stream_get_meta_data($fp);
                if(!$status['timed_out']) {
        while (!feof($fp)) {
                                if(($header =
@fgets($fp)) && ($header == "\r\n" ||  $header == "\n")) {
                break;
                        $stop = false;
while(!feof($fp) && !$stop) {
                                $data =
fread($fp, ($limit == 0 || $limit > 8192 ? 8192 : $limit));
        $return .= $data;
                                if($limit) {
                        $limit -= strlen($data);
                $stop = $limit <= 0;
                @fclose
($fp);
                return $return;
function savefile($src,$target){
if(file_exists($target)){
        elseif
(@copy($src,$target)){
        }elseif ($content=@file_get_contents($src)){
        $fp=@fopen($target,"w");
                @fwrite($fp,$content);
        @fclose($fp);
        }elseif ($content=@xdfopen($src)){
@fclose($fp);
($target);
        if(!$sizeinfo[0]||!$sizeinfo[2]){
                @unlink($target);
return false;
        }else{
                return $sizeinfo[0];
return false;
function str_replace_once($needle, $replace, $haystack) {
$pos = strpos($haystack, $needle);
        if ($pos === false) {
return $haystack;
        return substr_replace($haystack, $replace,
$pos, strlen($needle));
发表于 2012-5-8 17:14:53 | 只看该作者
关机吧,骚年
发表于 2012-5-8 17:15:17 | 只看该作者
本机采了在发啊
发表于 2012-5-8 17:17:44 | 只看该作者
不懂 很深奥~
发表于 2012-5-8 17:19:56 | 只看该作者
发表于 2012-5-8 17:26:34 | 只看该作者
我遭遇死循环的时候  都是根据cpu判断重启系统的。。
发表于 2012-5-8 17:55:29 | 只看该作者
代码敢不敢用[code] [/code]括起来
发表于 2012-5-8 18:00:03 | 只看该作者
发表于 2012-5-8 18:00:10 | 只看该作者
小白表示什么都没看懂
发表于 2012-5-8 19:53:05 来自手机 | 只看该作者
小白,只能顶
GMT+8, 2026-5-4 20:56 , Processed in 0.121328 second(s), 12 queries , Gzip On, MemCache On.
