查看: 1122|回复: 6
新商家CSPT50Mbps1$优化线路测评
发表于 2023-11-1 11:37:05 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
来源:https://loc.qiche.eu.org/thread-1222722-1-1.html
配置:
  1. 1 Cores
  2. 1GB
  3. 10GB SSD RAID 10
  4. 1 IP
  5. 50Mbps Unlimited
  6. Free China Premium Network
  7. Free China Super Network
  8. 2Tbps DDOS
  9. Los Angeles
  10. 1USD
测试IP:154.217.64.1
路由:
  1. 去程:
  2. CT via CT163
  3. CU via CU169
  4. CM via CMIN2
  5. 回程:
  6. CT via CMIN2
  7. CU via CMIN2
  8. CM via CMIN2
YABS:
  1. Processor  : Intel(R) Xeon(R) CPU E5-2690 v4 @ 2.60GHz
  2. CPU cores  : 1 @  2600.000 MHz
  3. AES-NI     : ✔ Enabled
  4. VM-x/AMD-V : ✔ Enabled
  5. RAM        : 1.0 GiB
  6. Swap       : 1.0 GiB
  7. Disk       : 9.7 GiB
  8. Distro     : CentOS Linux 7 (Core)
  9. Kernel     : 3.10.0
  10. VM Type    : OPENVZ
  11. IPv4/IPv6  : ✔ Online / ❌ Offline
  12. IPv4 Network Information:
  13. ---------------------------------
  14. ISP        : Enzu Inc
  15. ASN        : AS18978 Enzu Inc
  16. Host       : WuHan YunWaiHeng Information Technology co.
  17. Location   : Los Angeles, California (CA)
  18. Country    : United States
  19. fio Disk Speed Tests (Mixed R/W 50/50):
  20. ---------------------------------
  21. Block Size | 4k            (IOPS) | 64k           (IOPS)
  22.   ------   | ---            ----  | ----           ----
  23. Read       | 69.34 MB/s   (17.3k) | 181.29 MB/s   (2.8k)
  24. Write      | 69.53 MB/s   (17.3k) | 182.25 MB/s   (2.8k)
  25. Total      | 138.87 MB/s  (34.7k) | 363.55 MB/s   (5.6k)
  26.            |                      |
  27. Block Size | 512k          (IOPS) | 1m            (IOPS)
  28.   ------   | ---            ----  | ----           ----
  29. Read       | 216.79 MB/s    (423) | 226.03 MB/s    (220)
  30. Write      | 228.31 MB/s    (445) | 241.08 MB/s    (235)
  31. Total      | 445.11 MB/s    (868) | 467.12 MB/s    (455)
  32. Geekbench 5 Benchmark Test:
  33. ---------------------------------
  34. Test            | Value
  35. Single Core     | 790
  36. Multi Core      |756
  37. Full Test  https://browser.geekbench.com/v5/cpu/21898705
SUPERBENCH:
  1. ————————————————————————————————————————————————————————————————————
  2. 测速服务器信息   ↑     上传/Mbps ↓     下载/Mbps ↕ 延迟/ms ϟ 抖动/ms
  3. ————————————————————————————————————————————————————————————————————
  4. 电信|上海        ↑     49.2 正常 ↓     49.0 正常 ↕   138.1 ϟ     7.4
  5. 电信|江苏镇江5G  ↑     23.8 正常 ↓     47.6 正常 ↕   161.3 ϟ    10.7
  6. 电信|江苏南京5G  ↑      9.1 正常 ↓     48.8 正常 ↕   162.4 ϟ    13.2
  7. 电信|安徽合肥5G  ↑     47.3 正常 ↓     48.8 正常 ↕   144.3 ϟ    16.1
  8. 电信|天津5G      ↑     46.0 正常 ↓     40.9 正常 ↕   166.9 ϟ     9.2
  9. 电信|天津        ↑     47.8 正常 ↓     48.9 正常 ↕   162.5 ϟ     5.4
  10. 电信|四川成都    ↑     22.7 正常 ↓     32.6 正常 ↕   282.3 ϟ     0.0
  11. 联通|河南郑州5G  ↑     50.2 正常 ↓     45.5 正常 ↕   187.6 ϟ     4.2
  12. 联通|湖南长沙5G  ↑     51.3 正常 ↓      6.7 正常 ↕   169.8 ϟ     3.2
  13. 联通|辽宁沈阳    ↑      4.8 正常 ↓     43.2 正常 ↕   206.7 ϟ     8.5
  14. 联通|福建福州    ↑     50.6 正常 ↓     49.0 正常 ↕   170.8 ϟ     4.6
  15. 移动|浙江杭州5G  ↑     48.5 正常 ↓     42.0 正常 ↕   166.3 ϟ     4.5
  16. 移动|陕西西安5G  ↑     51.7 正常 ↓     45.4 正常 ↕   164.8 ϟ    11.1
  17. 移动|四川成都    ↑     49.4 正常 ↓     44.0 正常 ↕   182.4 ϟ     5.6
  18. 移动|甘肃兰州    ↑     50.5 正常 ↓     49.4 正常 ↕   195.1 ϟ     7.1
总结:可以看到发帖的人为 Enzu的销售,可能是销售自己当ONEMAN来卖产品,或者是Enzu官方的子产品,架构虽为OpenVZ但就目前来看基本能跑满带宽,一月7块钱还是可以把玩的。
发表于 2023-11-1 11:41:19 来自手机 | 只看该作者
没折扣了,1刀还能玩玩,贵了就不值
TG联系
Send by DZ Reader
发表于 2023-11-1 11:44:50 | 只看该作者
买来玩玩还行,虽然昨天没去买。
发表于 2023-11-1 11:48:36 | 只看该作者
昨天看到时候优惠没了,不冲了
发表于 2023-11-1 12:21:46 来自手机 | 只看该作者
买了后有好些系统可用,现在只有一个centos7
太狗了,限制这个有机八用
Send by DZ Reader
发表于 2023-11-1 12:26:38 | 只看该作者
太狗了,限制这个有机八用
其他系统有问题,暂时不可选,最近几天修复好了就可以了
发表于 2023-11-1 14:49:21 | 只看该作者
暂时不可选
GMT+8, 2026-1-12 03:36 , Processed in 0.069805 second(s), 9 queries , Gzip On, MemCache On.
