CeraNetworks网络延迟测速工具IP归属甄别
查看: 4320|回复: 2
Upcoming Server Maintenance Window
发表于 2010-3-14 10:11:33 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
You are receiving this notification because Limestone Networks has scheduled a maintenance window which will result in a temporary loss of power to servers listed below. This window is being scheduled to consolidate several racks within our Databank facility due to recent expansion and we do not expect the duration of the power loss to be more than 1 hour. Efforts are being taken to streamline the process as much as possible and in some cases we expect the servers will be back online in less than 30 minutes.
The maintenance window is scheduled for the date associated with the server(s) above from 12:00AM to 6:00AM CST. Our technicians will attempt to cleanly power down the server before removing power, however please be aware in some cases this may not be possible if login to the server is required to initiate a power down from console. No IP modifications will be necessary and no network changes are taking place, so no configuration changes should be necessary on your server.
发表于 2010-3-14 19:06:18 | 只看该作者
我的中午到下午感觉全国大部分地区访问都慢了,是机房出口有问题么?
这句话要干嘛啊。。
 楼主| 发表于 2010-3-14 23:05:41 | 只看该作者
回复 2# 的帖子
他们搬迁机柜,IP设置不会改变。
GMT+8, 2026-1-14 08:00 , Processed in 0.061924 second(s), 8 queries , Gzip On, MemCache On.
