查看: 949|回复: 1
Github上的一个tg 机器人项目 有没有谁能解释下怎么用
发表于 2023-10-18 15:58:13 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
https://github.com/aryazakaria01/**Hub
这个项目
目前已经运行起来了 但是 tg bot 没任何反应!
启动日志
root@ryzen:~/**Hub# python3 -m **Hub^C
root@ryzen:~/**Hub# python3 -m **Hub &
[1] 19631
root@ryzen:~/**Hub# pyrogram.session.auth.create | INFO | Start creating a new auth key on DC2
pyrogram.connection.connection.connect | INFO | Connecting...
pyrogram.connection.connection.connect | INFO | Connected! Production DC2 - IPv4
pyrogram.session.auth.create | INFO | Done auth key exchange: DhGenOk
pyrogram.connection.connection.close | INFO | Disconnected
pyrogram.session.session.recv_worker | INFO | NetworkTask started
pyrogram.session.session.start | INFO | Session initialized: Layer 158
pyrogram.session.session.start | INFO | Device: CPython 3.9.2 - **Hub v2.0.1b4
pyrogram.session.session.start | INFO | System: Linux 5.10.0-20-amd64 (en)
pyrogram.session.session.start | INFO | Session started
pyrogram.session.session.ping_worker | INFO | PingTask started
pyrogram.session.session.ping_worker | INFO | PingTask stopped
pyrogram.session.session.recv_worker | INFO | NetworkTask stopped
pyrogram.session.session.stop | INFO | Session stopped
pyrogram.session.auth.create | INFO | Start creating a new auth key on DC1
pyrogram.connection.connection.connect | INFO | Connected! Production DC1 - IPv4
pyrogram.client.load_plugins | WARNING | [**hub] No plugin loaded from "**hub.plugins"
pyrogram.dispatcher.start | INFO | Started 13 HandlerTasks
**Hub.bot.start | INFO | **Hub running with Pyrogram v2.0.106 (Layer 158) started on ptotg_bot. Hello!
**Hub.bot.start | WARNING | Unable to send message to log_chat!
发表于 2023-10-18 16:28:12 | 只看该作者
plugins 这个文件夹找不到
GMT+8, 2026-4-25 00:10 , Processed in 0.055858 second(s), 9 queries , Gzip On, MemCache On.
