查看: 2105|回复: 8
Ucloud 轻量129款简单评测
发表于 2023-10-13 13:19:50 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
看到MJJ要评测,就简单发下吧
IP:165.154.46.XX(2位)
国内机子:腾讯云上海 iperf3 -Rc UCLOUD
  1. [ ID] Interval           Transfer     Bitrate         Retr  Cwnd
  2. [  5]   0.00-1.00   sec  9.29 MBytes  77.9 Mbits/sec  2620    145 KBytes
  3. [  5]   1.00-2.00   sec  3.75 MBytes  31.5 Mbits/sec  2712    138 KBytes
  4. [  5]   2.00-3.00   sec  2.50 MBytes  21.0 Mbits/sec  2144    170 KBytes
  5. [  5]   3.00-4.00   sec  3.75 MBytes  31.5 Mbits/sec  296    131 KBytes
  6. [  5]   4.00-5.00   sec  3.75 MBytes  31.5 Mbits/sec    0    148 KBytes
  7. [  5]   5.00-6.00   sec  2.50 MBytes  21.0 Mbits/sec   13    126 KBytes
  8. [  5]   6.00-7.00   sec  3.75 MBytes  31.5 Mbits/sec    0    142 KBytes
  9. [  5]   7.00-8.00   sec  3.75 MBytes  31.5 Mbits/sec    0    154 KBytes
  10. [  5]   8.00-9.00   sec  3.75 MBytes  31.5 Mbits/sec   18    131 KBytes
  11. [  5]   9.00-10.00  sec  3.75 MBytes  31.5 Mbits/sec    0    149 KBytes
  12. - - - - - - - - - - - - - - - - - - - - - - - - -
  13. [ ID] Interval           Transfer     Bitrate         Retr
  14. [  5]   0.00-10.04  sec  40.5 MBytes  33.9 Mbits/sec  7803             sender
  15. -----------------------------------------------------------
  16. Server listening on 5201
腾讯云上海PING
  1. 64 bytes from 165.154.46.XX: icmp_seq=1 ttl=39 time=34.6 ms
  2. 64 bytes from 165.154.46.XX: icmp_seq=2 ttl=39 time=34.0 ms
  3. 64 bytes from 165.154.46.XX: icmp_seq=3 ttl=39 time=34.1 ms
  4. 64 bytes from 165.154.46.XX: icmp_seq=4 ttl=39 time=34.0 ms
  5. 64 bytes from 165.154.46.XX: icmp_seq=5 ttl=39 time=34.1 ms
  6. 64 bytes from 165.154.46.XX: icmp_seq=6 ttl=39 time=34.1 ms
本地电信ping
  1. 来自 165.154.46.xx 的回复: 字节=32 时间=59ms TTL=38
  2. 请求超时。
  3. 来自 165.154.46.xx 的回复: 字节=32 时间=55ms TTL=38
  4. 来自 165.154.46.xx 的回复: 字节=32 时间=60ms TTL=38
  5. 来自 165.154.46.xx 的回复: 字节=32 时间=62ms TTL=38
  6. 来自 165.154.46.xx 的回复: 字节=32 时间=65ms TTL=38
  7. 来自 165.154.46.xx 的回复: 字节=32 时间=100ms TTL=38
  8. 来自 165.154.46.xx 的回复: 字节=32 时间=57ms TTL=38
回程MTR
AS10099-AS4837-三网各自AS
解锁:
  1. ** 您的网络为: Ucloud Information Technology Hk Limited (165.154.*.*)
  2. ============[ Multination ]============
  3. Dazn:                                        Yes (Region: HK)
  4. HotStar:                                No
  5. Disney+:                                No
  6. Netflix:                                Originals Only
  7. 有图比 Premium:                        Yes (Region: HK)
  8. Amazon Prime Video:                        Yes (Region: HK)
  9. TVBAnywhere+:                                No
  10. iQyi Oversea Region:                        HK
  11. Viu.com:                                Yes (Region: HK)
  12. 有图比 CDN:                                Hong Kong
  13. Netflix Preferred CDN:                        Hong Kong
  14. Spotify Registration:                        No
  15. Steam Currency:                        HKD
  16. ChatGPT:                                Yes
本地speedtest
  1.    Speedtest by Ookla
  2.       Server: STC - Hong Kong (id: 1536)
  3.          ISP: Ucloud Information Technology Hk Limited
  4. Idle Latency:     2.70 ms   (jitter: 0.03ms, low: 2.68ms, high: 2.72ms)
  5.     Download:    95.49 Mbps (data used: 154.6 MB)
  6.                   1.80 ms   (jitter: 0.08ms, low: 1.63ms, high: 2.30ms)
  7.       Upload:    28.55 Mbps (data used: 47.1 MB)
  8.                   1.84 ms   (jitter: 1.81ms, low: 1.67ms, high: 211.55ms)
  9. Packet Loss: Not available.
  10.   Result URL: https://www.speedtest.net/result/c/1a4aa1a6-743d-42aa-9513-ec3d119b79e7
已退款,丢包,跳ping,不如阿里云(白天)
发表于 2023-10-13 13:27:30 | 只看该作者
跟阿里云和腾讯云差远了。。
野鸡商家,稍大一点的oneman,又咳得。
发表于 2023-10-13 13:22:04 | 只看该作者
大佬评价一下,小白看不懂数据
发表于 2023-10-13 13:22:57 来自手机 | 只看该作者
请教大佬这款续费是优惠价一百块吗?
 楼主| 发表于 2023-10-13 13:24:14 | 只看该作者
厂弟 发表于 2023-10-13 13:22
请教大佬这款续费是优惠价一百块吗?
894
 楼主| 发表于 2023-10-13 13:28:52 | 只看该作者
hsppc 发表于 2023-10-13 13:22
大佬评价一下,小白看不懂数据
和阿里云轻量香港差不多,只不过阿里云去程是CN2,这个去程也是走联通4837
如果高峰期不砍网速,不丢包,后期不调路由,稳定不变的话,那和阿里云差不多
香港30M性价比很高了
发表于 2023-10-13 13:29:18 来自手机 | 只看该作者
发表于 2023-10-13 13:31:29 | 只看该作者
回程也是走联通10099吗?
发表于 2023-10-13 13:33:53 | 只看该作者
信不过信不过。。。慎重上车
GMT+8, 2026-5-2 10:17 , Processed in 0.069427 second(s), 11 queries , Gzip On, MemCache On.
