查看: 1715|回复: 9
请教一下,申请burst.net的IP包后,对方给我的邮件看不懂
发表于 2012-5-4 01:03:43 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Guy H. has responded to your ticket.
Please preserve the subject line. This is important.
(Guy H.)
Hello,
You have been emailed twice regarding this order and no response has been received. Your order is currently on hold waiting for IP Justification responses. I have pasted the email sent to you below. All of the information in this email is required.
To:     这里是邮箱
Subject:        BurstNET - Order 100000xxxxx -这个是定单号
Body:   Hello,
Your IP allocation order has been put on hold pending IP justification.
Please respond to this email/ticket with detailed justification. We require justification according to ARIN's guidelines. You would be required to fill out the IP justification form below.
Provide detailed information on how these IP addresses will be utilized. It is not acceptable to provide information such as "I want my sites on different IPs" or "I have multiple customer who want their own IP":
BurstNET Technologies, Inc.
IP Address Justification Form v2.1
• Overview
The completion of this form is required when requesting additional IP addresses greater than:
• The initial /29 (5 usable) allocated to your dedicated server
• The initial /32 (1 usable) allocated to your VPS or Cloud service
BurstNET Technologies, Inc. strictly observes the policies of American Registry for Internet Numbers (ARIN), Réseaux IP
Européens (RIPE) or other Regional Internet Registrys (RIR). We require all customers to provide written justification for
any additional IP allocations requested beyond the initial assignment. This justification is needed in order to demonstrate
to ARIN or RIPE that IP allocations assigned to BurstNET are being used efficiently.
• Justification Policy
BurstNET will ONLY allocate IPs in cases where name-based hosting is not possible because of technological restrictions not
yet overcome (e.g. SSL). IPs may not be used for any purpose that violates BurstNET’s acceptable use policy (AUP) or terms
of service (TOS). If your additional IP request can be justified, we will assign the allocation to you. In order to qualify,
the following information must be provided:
• Number of IPs needed
• If you have a previous allocation for this service, you must demonstrate 80% utilization, provide the following
information:
o Existing server name
o Main server IP address
o Total number of IPs assigned to the server
o Total number of IPs actively used by a domain(s)
o Total number of IPs not actively used by a domain(s)
o List of currently assigned IP addresses, include how each one is utilized and its domain name
• Describe the purpose of EACH IP address requested
• Verifiable domain for EACH IP address requested
Each request is thoroughly reviewed before this order will be approved. If this request is for more than a /27 (32 IP
addresses), it may take up to 24 hours to complete this request.
IP Justification Form (copy and paste the completed form into your IP Order)
Company Web address:
Company Name:
Address:
City:
State/Providence:
Zip Code:
Phone:
Email:
Note: By completing and submitting this for to BurstNET Technologies, Inc. you hereby certify that you are authorized to
represent the company listed above and that all of the information provided below is accurate and truthful to the best of
your knowledge. You under that IPv4 address space limited and that BurstNET is responsible for conserving address space and
that it is utilized efficiently.
1. Provide the server host name:
2. Server's primary IP address:
3. Current IP address space utilization:
a. Total number of IP address(es) assigned to this server:
b. Total number of IP address(es) actively used by domains on this server:
c. Total number of IP address(es) not actively used by domains on this server:
d. List each currently assigned IP address, how its currently used and by which domain name:
Example:
1. xxx.xxx.xxx.xxx - www点xxxx点com - SSL eCommerace site
2. xxx.xxx.xxx.xxy - mail.somedomain点com - mailserver for somedomain点com
1.
2.
3.
4.
5.
6.
7.
8.
Feel free to add additional lines as needed
Note: 80% of your IP space must be utilized before applying for additional allocations.
4. Number of additional IP address requested:
5. Provide detailed information on how these IP addresses will be utilized. You must provide FQDN (fully qualified domain name).
Thanks
发表于 2012-5-4 01:25:25 | 只看该作者
谷歌翻译啊 亲
Guy H. 回应你的TK
请注意线下面的。这一点很重要。
你已经通过邮件发了2次关于这个订单,并没有收到回应。
您的订单是目前状态是等待你答复申请IP的理由?。我已经把下面东西给你这个MJJ发送了电子邮件。此电子邮件中的信息是必需的。
发表于 2012-5-4 01:26:57 | 只看该作者
盖伊H.的回应你的票。 请保留主题行。这一点很重要。 ---------------------------------------------- - (H。盖伊) -------------------------------------------- --- 您好, 您已通过电子邮件发送两次关于这个顺序,并已收到任何响应。您的订单是目前保持等待IP正当性反应的。我已经粘贴下面给你发送的电子邮件。此电子邮件中的信息是必需的。 :这里是邮箱 从:    sales@burst.net 主题:BurstNET -订购100000xxxxx -这个什么定单号技术 机构:您好, 您的IP分配秩序已搁置,待知识产权的理由。 请回应此电子邮件/购票的详细理由。据阿林的指引,我们需要的理由。你会被要求填写下面的IP的理由形式。 提供如何将利用这些IP地址的详细信息。这是不能接受的,如“我想我的网站在不同的IP地址”或“我有多个客户希望自己的IP”提供的信息: BurstNET技术,公司的 IP地址的理由表2.1 概述 完成此表格要求时,需要额外的IP地址大于 初始/ 29(5个可用)分配给您的专用服务器 •初始/ 32(1可用)分配给您的VPS或云服务 BurstNET科技公司严格遵守政策美国注册互联网号码机构(ARIN),RESEAUX的知识产权 Européens(熟)或其他地区互联网书记官处的管理机构(RIR)。我们要求所有的客户提供书面理由, 任何额外的IP分配的要求超出了最初的任务。 •正当性政策 BurstNET只会分配IP地址的情况下,基于名称的主机是没有可能的,因为技术的限制, 尚未克服(如 BurstNET分配到的IP分配正在使用的有效证明到ARIN的或RIPE 需要这个理由。SSL),不得用于任何目的,违反BurstNET的可接受使用政策(AUP)或 服务条款 (TOS)的 IP地址。如果可以证明你的额外的IP请求,我们将分配给你分配。 以下信息,以便有资格,必须提供: •所需的IP地址数量 •如果你有这个服务以前的分配,你必须表现出80%的利用率,提供以下 信息: Ø现有服务器的名称 Ø主服务器的IP地址 Ø总数分配给服务器的IP O的积极域(S)的IP地址总数 Ø域(S)不积极使用的IP地址总数 Ø当前分配的IP地址列表,包括如何利用每一个其域名 •描述要求每个IP地址的目的, 为每个IP地址的可验证域要求 每个请求都被彻底检讨,在此之前的订单将被批准。如果这个请求是超过/ 27(32个IP 地址),它可能需要24小时才能完成这个请求。 IP理由表(副本及填妥的表格粘贴到你的IP 网址: 公司名称: 地址: 城市: 州/静宜: 邮编: 电话: 电子邮件: 注:完成并提交本BurstNET技术有限公司兹证明您被授权 代表以上和上市公司下面提供的所有信息是准确和真实的 你的知识下,IPv4地址空间有限,BurstNET是负责保护的地址空间,并 有效利用 (1)提供服务器的主机名: 2 。服务器的主IP地址: 3当前的IP地址空间的利用率:。 。总数量的IP地址(ES)分配给该服务器: 。b IP地址的总人数(ES)积极在此服务器上的域使用: Ç总数。不积极通过此服务器上的域使用的IP地址(ES) ,D列出每个当前分配的IP地址,其目前的使用和域名: 例如: 1。XXX.XXX.XXX.XXX - WWW点XXXX点COM - SSL eCommerace网站 2 xxx.xxx.xxx.xxy - mail.somedomain点COM -邮件服务器为somedomain点COM 1 2 3 4 5 6 7 8。 随时需要添加额外的线路 注:您的IP地址空间的80%必须用于前申请追加拨款。 数4要求额外的IP地址 。5提供如何将利用这些IP地址的详细信息,你必须提供的FQDN(完全限定的域名)。 是不能接受的,如“我想我的网站在不同的IP地址”或“谁希望自己的IP,我有多个客户提供”信息: 谢谢
发表于 2012-5-4 01:28:52 | 只看该作者
总之,这封邮件很重要
发表于 2012-5-4 02:52:46 | 只看该作者
让你提供申请ip的理由。按下面个的表填上。理由要充分。
 楼主| 发表于 2012-5-4 12:00:49 | 只看该作者
大家知道,这些东西,怎么填吗,不会呀。我记得我填过一次的,但好象不成功
发表于 2012-5-4 12:12:24 | 只看该作者
不懂英文,所以用国人vps
发表于 2012-5-4 12:15:16 | 只看该作者
楼主。。。你没有原因的就突然申请IP了?
发表于 2012-5-4 12:41:46 | 只看该作者
亲,你的申请被hold了,需要填写下面的表格 .
发表于 2012-5-4 12:47:12 | 只看该作者
虽然不知道你在说什么,但是好像很厉害的样子
GMT+8, 2026-4-26 12:17 , Processed in 0.063405 second(s), 11 queries , Gzip On, MemCache On.
