查看: 5409|回复: 24
[美国VPS] TMT Hosting 斯巴达下游测评
发表于 2023-10-9 12:12:43 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
https://billing.tmthosting.net/cart.php
斯巴达下游。
NVMe款最低配 用六折优惠码 clearancesalevps2023 后年付26.99刀,月流量2T。
HDD款最低配用优惠码后 年付20.99刀,月流量1.5T。
HDD款 硬盘4K读写速度 5MB/s左右
下面测试是NVMe款。
  1. Processor  : Intel(R) Xeon(R) CPU E3-1270 v3 [url=home.php?mod=space&uid=175]@[/url] 3.50GHz
  2. CPU cores  : 1 @ 3500.012 MHz
  3. AES-NI     : ✔ Enabled
  4. VM-x/AMD-V : ❌ Disabled
  5. RAM        : 483.3 MiB
  6. Swap       : 1.5 GiB
  7. Disk       : 15.3 GiB
  8. Distro     : Debian GNU/Linux 10 (buster)
  9. Kernel     : 4.19.0-5-amd64
  10. VM Type    : KVM
  11. IPv4/IPv6  : ✔ Online / ✔ Online
  12. IPv6 Network Information:
  13. ---------------------------------
  14. ISP        : Spartan Host Ltd
  15. ASN        : AS201106 Spartan Host Ltd
  16. Host       : Spartan Host Ltd
  17. Location   : Seattle, Washington (WA)
  18. Country    : United States
  19. fio Disk Speed Tests (Mixed R/W 50/50):
  20. ---------------------------------
  21. Block Size | 4k            (IOPS) | 64k           (IOPS)
  22.   ------   | ---            ----  | ----           ----
  23. Read       | 115.48 MB/s  (28.8k) | 716.80 MB/s  (11.2k)
  24. Write      | 115.79 MB/s  (28.9k) | 720.58 MB/s  (11.2k)
  25. Total      | 231.28 MB/s  (57.8k) | 1.43 GB/s    (22.4k)
  26.            |                      |
  27. Block Size | 512k          (IOPS) | 1m            (IOPS)
  28.   ------   | ---            ----  | ----           ----
  29. Read       | 237.54 MB/s    (463) | 230.34 MB/s    (224)
  30. Write      | 250.16 MB/s    (488) | 245.68 MB/s    (239)
  31. Total      | 487.70 MB/s    (951) | 476.02 MB/s    (463)
  32. Geekbench 5 Benchmark Test:
  33. ---------------------------------
  34. Test            | Value
  35.                 |
  36. Single Core     | 756
  37. Multi Core      | 778
  38. Full Test       | https://browser.geekbench.com/v5/cpu/21818101
  39. ---------------------------- network-speed.xyz ----------------------------
  40.       A simple script to test network performance using speedtest-cli
  41. ---------------------------------------------------------------------------
  42. Version            : v2023.09.30
  43. Global Speedtest   : wget -qO- network-speed.xyz | bash
  44. Region Speedtest   : wget -qO- network-speed.xyz | bash -s -- -r <region>
  45. ---------------------------------------------------------------------------
  46. Basic System Info
  47. ---------------------------------------------------------------------------
  48. CPU Model          : Intel(R) Xeon(R) CPU E3-1270 v3 @ 3.50GHz
  49. CPU Cores          : 1 @ 3500.012 MHz
  50. CPU Cache          : 8192 KB
  51. AES-NI             : ✔ Enabled
  52. VM-x/AMD-V         : ❌ Disabled
  53. Total Disk         : 15.3 GB (1.3 GB Used)
  54. Total RAM          : 483.3 MB (56.1 MB Used)
  55. Total Swap         : 1.5 GB (9.9 MB Used)
  56. System uptime      : 0 days, 0 hour 20 min
  57. Load average       : 0.00, 0.04, 0.12
  58. OS                 : Debian GNU/Linux 10
  59. Arch               : x86_64 (64 Bit)
  60. Kernel             : 4.19.0-5-amd64
  61. Virtualization     : KVM
  62. ---------------------------------------------------------------------------
  63. Basic Network Info
  64. ---------------------------------------------------------------------------
  65. IPv6 Access        : ✔ Online
  66. IPv4 Access        : ✔ Online
  67. ISP                : Spartan Host Ltd
  68. ASN                : AS201106 Spartan Host Ltd
  69. Host               : Spartan Host Ltd
  70. Location           : Seattle, Washington-WA, United States
  71. ---------------------------------------------------------------------------
  72. Speedtest.net (Region: GLOBAL)
  73. ---------------------------------------------------------------------------
  74. Location         Latency     Loss    DL Speed       UP Speed       Server
  75. ISP: Spartan Host Ltd
  76. Nearest          0.30 ms     0.0%    922.13 Mbps    926.27 Mbps    Wowrack - Seattle, WA
  77. Kochi, IN        269.19 ms   0.0%    627.33 Mbps    304.27 Mbps    Asianet Broadband - Cochin
  78. Bangalore, IN    245.86 ms   0.0%    675.90 Mbps    273.99 Mbps    Bharti Airtel Ltd - Bangalore
  79. Chennai, IN      239.64 ms   N/A     708.09 Mbps    272.23 Mbps    Jio - Chennai
  80. Mumbai, IN       239.64 ms   0.0%    633.71 Mbps    287.36 Mbps    i3D.net - Mumbai
  81. Delhi, IN        254.75 ms   0.0%    671.35 Mbps    271.87 Mbps    Tata Teleservices Ltd - New Delhi
  82. Seattle, US      0.46 ms     0.0%    919.35 Mbps    922.10 Mbps    Ziply Fiber - Seattle, WA
  83. Los Angeles, US  25.26 ms    0.0%    929.41 Mbps    923.71 Mbps    ReliableSite Hosting - Los Angeles, CA
  84. Dallas, US       58.36 ms    0.0%    789.25 Mbps    892.23 Mbps    Hivelocity - Dallas, TX
  85. Miami, US        87.31 ms    0.0%    898.45 Mbps    802.87 Mbps    AT&T - Miami, FL
  86. New York, US     62.54 ms    0.0%    760.43 Mbps    898.21 Mbps    GSL Networks - New York, NY
  87. Toronto, CA      51.53 ms    0.0%    913.37 Mbps    891.89 Mbps    Rogers - Toronto, ON
  88. London, UK       122.87 ms   0.0%    600.72 Mbps    582.00 Mbps    VeloxServ Communications - London
  89. Amsterdam, NL    158.91 ms   0.0%    520.50 Mbps    463.91 Mbps    31173 Services AB - Amsterdam
  90. Paris, FR        170.65 ms   N/A     541.37 Mbps    417.30 Mbps    Axione - Paris
  91. Frankfurt, DE    134.57 ms   0.0%    905.60 Mbps    499.15 Mbps    23M GmbH - Frankfurt am Main
  92. Warsaw, PL       171.57 ms   0.0%    727.17 Mbps    494.13 Mbps    UPC Polska - Warszawa
  93. Bucharest, RO    198.57 ms   0.0%    720.21 Mbps    359.00 Mbps    Vodafone Romania Fixed – Bucharest - Bucharest
  94. Jeddah, SA       192.04 ms   0.0%    463.27 Mbps    359.58 Mbps    Saudi Telecom Company
  95. Dubai, AE        254.78 ms   0.0%    545.45 Mbps    271.24 Mbps    du - Dubai
  96. Fujairah, AE     263.10 ms   0.0%    399.19 Mbps    258.66 Mbps    ETISALAT-UAE - Fujairah
  97. Tokyo, JP        148.40 ms   N/A     721.53 Mbps    566.48 Mbps    fdcservers.net - Tokyo
  98. Shanghai, CU-CN  134.52 ms   0.0%    931.42 Mbps    533.72 Mbps    China Unicom 5G - Shanghai
  99. Nanjing, CT-CN   154.88 ms   0.3%    867.11 Mbps    370.40 Mbps    China Telecom JiangSu 5G - Nanjing
  100. Hong Kong, CN    170.09 ms   N/A     898.05 Mbps    416.24 Mbps    STC - Hong Kong
  101. Singapore, SG    149.01 ms   0.0%    892.16 Mbps    485.67 Mbps    i3D.net - Singapore
  102. Jakarta, ID      164.40 ms   0.0%    865.61 Mbps    422.19 Mbps    PT. Telekomunikasi Indonesia - Jakarta
  103. ---------------------------------------------------------------------------
  104. Avg DL Speed       : 742.53 Mbps
  105. Avg UL Speed       : 524.69 Mbps
  106. Total DL Data      : 27.56 GB
  107. Total UL Data      : 16.89 GB
  108. Total Data         : 44.45 GB
  109. ---------------------------------------------------------------------------
发表于 2023-10-9 13:35:31 | 只看该作者
1270开小鸡。。。。这得超多少回本
发表于 2023-10-9 20:15:55 | 只看该作者
https://billing.tmthosting.net/aff.php?aff=45
 楼主| 发表于 2023-10-9 16:47:05 | 只看该作者
radiogaga 发表于 2023-10-9 16:07
楼主测速脚本可以发下嘛
感觉地区很全
https://network-speed.xyz/
发表于 2023-10-9 12:21:32 | 只看该作者
好像买个杜甫自己开小鸡
 楼主| 发表于 2023-10-9 12:24:25 | 只看该作者
zgs 发表于 2023-10-9 12:21
好像买个杜甫自己开小鸡
比较好奇这家是不是就是斯巴达的马甲,这个价格开杜甫卖小鸡纯纯亏本啊,而且这家也有好几年了。
发表于 2023-10-9 12:27:27 | 只看该作者
楼主看一下能解GPT吗
 楼主| 发表于 2023-10-9 13:16:03 | 只看该作者
jiangjk 发表于 2023-10-9 12:27
楼主看一下能解GPT吗
没问题
  1. ============[ Multination ]============
  2. Dazn:                                  Yes (Region: US)
  3. HotStar:                               No
  4. Disney+:                               No
  5. Netflix:                               Originals Only
  6. 有图比 Premium:                       Yes
  7. Amazon Prime Video:                    Yes (Region: US)
  8. TVBAnywhere+:                          Yes
  9. iQyi Oversea Region:                   US
  10. Viu.com:                               No
  11. 有图比 CDN:                           Seattle, WA
  12. Netflix Preferred CDN:                 Seattle, WA
  13. Spotify Registration:                  No
  14. Steam Currency:                        USD
  15. ChatGPT:                               Yes
  16. =======================================
发表于 2023-10-9 13:31:44 | 只看该作者
不知道中国晚高峰时怎么样
发表于 2023-10-9 13:33:09 | 只看该作者
这啥线路来着
发表于 2023-10-9 16:07:48 | 只看该作者
楼主测速脚本可以发下嘛
感觉地区很全
发表于 2023-10-9 16:12:48 | 只看该作者
走的是啥线路??
GMT+8, 2026-4-17 05:29 , Processed in 0.067723 second(s), 11 queries , Gzip On, MemCache On.
