查看: 3229|回复: 13
[Windows VPS] 挂机宝这正常??? 内网IP延迟达到数秒
发表于 2012-5-2 14:49:14 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
昨天买冰山的一个php的挂机宝测试。 发现开始还行,但是到了昨晚凌晨3-4点之后,出现异常。 然后安装了mtr测试了下。
发现其网关的IP,延迟非常大。 经常有几秒的延迟。
挂机宝类的共享IP的VPS是不是都有这个问题?
找客服,客服开始说是我自己的网络问题, 无语, 在问, 就消失了, 不再搭话了。
[root@localhost ~]# ping  10.210.0.1
PING 10.210.0.1 (10.210.0.1) 56(84) bytes of data.
64 bytes from 10.210.0.1: icmp_seq=1 ttl=64 time=0.190 ms
64 bytes from 10.210.0.1: icmp_seq=2 ttl=64 time=0.215 ms
64 bytes from 10.210.0.1: icmp_seq=3 ttl=64 time=0.223 ms
64 bytes from 10.210.0.1: icmp_seq=4 ttl=64 time=0.228 ms
64 bytes from 10.210.0.1: icmp_seq=5 ttl=64 time=0.229 ms
64 bytes from 10.210.0.1: icmp_seq=6 ttl=64 time=0.207 ms
64 bytes from 10.210.0.1: icmp_seq=7 ttl=64 time=0.359 ms
64 bytes from 10.210.0.1: icmp_seq=8 ttl=64 time=0.230 ms
64 bytes from 10.210.0.1: icmp_seq=9 ttl=64 time=90.6 ms
64 bytes from 10.210.0.1: icmp_seq=10 ttl=64 time=2130 ms
64 bytes from 10.210.0.1: icmp_seq=11 ttl=64 time=1218 ms
64 bytes from 10.210.0.1: icmp_seq=12 ttl=64 time=297 ms
64 bytes from 10.210.0.1: icmp_seq=13 ttl=64 time=1623 ms
64 bytes from 10.210.0.1: icmp_seq=14 ttl=64 time=706 ms
64 bytes from 10.210.0.1: icmp_seq=15 ttl=64 time=0.196 ms
64 bytes from 10.210.0.1: icmp_seq=16 ttl=64 time=0.198 ms
64 bytes from 10.210.0.1: icmp_seq=17 ttl=64 time=0.212 ms
64 bytes from 10.210.0.1: icmp_seq=18 ttl=64 time=0.183 ms
64 bytes from 10.210.0.1: icmp_seq=19 ttl=64 time=0.190 ms
64 bytes from 10.210.0.1: icmp_seq=20 ttl=64 time=0.192 ms
64 bytes from 10.210.0.1: icmp_seq=21 ttl=64 time=0.185 ms
64 bytes from 10.210.0.1: icmp_seq=22 ttl=64 time=0.191 ms
64 bytes from 10.210.0.1: icmp_seq=23 ttl=64 time=0.232 ms
64 bytes from 10.210.0.1: icmp_seq=24 ttl=64 time=0.203 ms
64 bytes from 10.210.0.1: icmp_seq=25 ttl=64 time=0.215 ms
64 bytes from 10.210.0.1: icmp_seq=26 ttl=64 time=0.229 ms
64 bytes from 10.210.0.1: icmp_seq=27 ttl=64 time=0.216 ms
64 bytes from 10.210.0.1: icmp_seq=28 ttl=64 time=0.217 ms
64 bytes from 10.210.0.1: icmp_seq=29 ttl=64 time=0.224 ms
64 bytes from 10.210.0.1: icmp_seq=30 ttl=64 time=0.209 ms
64 bytes from 10.210.0.1: icmp_seq=31 ttl=64 time=0.224 ms
64 bytes from 10.210.0.1: icmp_seq=32 ttl=64 time=0.206 ms
64 bytes from 10.210.0.1: icmp_seq=33 ttl=64 time=0.216 ms
64 bytes from 10.210.0.1: icmp_seq=34 ttl=64 time=0.224 ms
64 bytes from 10.210.0.1: icmp_seq=35 ttl=64 time=0.195 ms
64 bytes from 10.210.0.1: icmp_seq=36 ttl=64 time=0.201 ms
64 bytes from 10.210.0.1: icmp_seq=37 ttl=64 time=0.218 ms
64 bytes from 10.210.0.1: icmp_seq=38 ttl=64 time=0.233 ms
64 bytes from 10.210.0.1: icmp_seq=39 ttl=64 time=0.144 ms
64 bytes from 10.210.0.1: icmp_seq=40 ttl=64 time=1388 ms
64 bytes from 10.210.0.1: icmp_seq=41 ttl=64 time=472 ms
64 bytes from 10.210.0.1: icmp_seq=42 ttl=64 time=2516 ms
64 bytes from 10.210.0.1: icmp_seq=43 ttl=64 time=1598 ms
64 bytes from 10.210.0.1: icmp_seq=44 ttl=64 time=681 ms
ping 百度
[root@localhost ~]# ping baidu.com
PING baidu.com (220.181.111.85) 56(84) bytes of data.
64 bytes from 220.181.111.85: icmp_seq=1 ttl=54 time=25.8 ms
64 bytes from 220.181.111.85: icmp_seq=2 ttl=54 time=24.7 ms
64 bytes from 220.181.111.85: icmp_seq=3 ttl=54 time=24.6 ms
64 bytes from 220.181.111.85: icmp_seq=5 ttl=54 time=26.1 ms
64 bytes from 220.181.111.85: icmp_seq=6 ttl=54 time=24.7 ms
64 bytes from 220.181.111.85: icmp_seq=7 ttl=54 time=25.8 ms
64 bytes from 220.181.111.85: icmp_seq=8 ttl=54 time=24.7 ms
64 bytes from 220.181.111.85: icmp_seq=9 ttl=54 time=25.2 ms
64 bytes from 220.181.111.85: icmp_seq=10 ttl=54 time=24.7 ms
64 bytes from 220.181.111.85: icmp_seq=11 ttl=54 time=25.2 ms
64 bytes from 220.181.111.85: icmp_seq=12 ttl=54 time=25.1 ms
64 bytes from 220.181.111.85: icmp_seq=13 ttl=54 time=26.2 ms
64 bytes from 220.181.111.85: icmp_seq=14 ttl=54 time=24.8 ms
64 bytes from 220.181.111.85: icmp_seq=15 ttl=54 time=613 ms
64 bytes from 220.181.111.85: icmp_seq=16 ttl=54 time=3200 ms
64 bytes from 220.181.111.85: icmp_seq=17 ttl=54 time=2284 ms
64 bytes from 220.181.111.85: icmp_seq=18 ttl=54 time=1367 ms
64 bytes from 220.181.111.85: icmp_seq=19 ttl=54 time=450 ms
64 bytes from 220.181.111.85: icmp_seq=20 ttl=54 time=73.6 ms
64 bytes from 220.181.111.85: icmp_seq=21 ttl=54 time=26.0 ms
64 bytes from 220.181.111.85: icmp_seq=22 ttl=54 time=24.7 ms
64 bytes from 220.181.111.85: icmp_seq=23 ttl=54 time=25.0 ms
64 bytes from 220.181.111.85: icmp_seq=24 ttl=54 time=25.6 ms
64 bytes from 220.181.111.85: icmp_seq=25 ttl=54 time=24.7 ms
64 bytes from 220.181.111.85: icmp_seq=26 ttl=54 time=24.8 ms
64 bytes from 220.181.111.85: icmp_seq=27 ttl=54 time=25.8 ms
64 bytes from 220.181.111.85: icmp_seq=28 ttl=54 time=25.5 ms
64 bytes from 220.181.111.85: icmp_seq=29 ttl=54 time=24.7 ms
64 bytes from 220.181.111.85: icmp_seq=30 ttl=54 time=25.7 ms
--- baidu.com ping statistics ---
31 packets transmitted, 29 received, 6% packet loss, time 30003ms
rtt min/avg/max/mdev = 24.694/295.564/3200.251/728.616 ms, pipe 4
[root@localhost ~]#
发表于 2012-5-2 14:52:23 | 只看该作者
这证明客服只会 卖不会技术啊
 楼主| 发表于 2012-5-2 14:52:54 | 只看该作者
是技术客服啊 。
发表于 2012-5-2 14:59:26 | 只看该作者
有吧
发表于 2012-5-2 15:39:38 | 只看该作者
可能内网有攻击吧
 楼主| 发表于 2012-5-2 15:52:20 | 只看该作者
Vita 发表于 2012-5-2 15:39
可能内网有攻击吧
现在也没有搞清楚。
但是每隔 10 几秒就有一次大的网络波动。 搞的很悲催。
发表于 2012-5-2 16:29:56 | 只看该作者
酱油
发表于 2012-5-2 16:31:06 | 只看该作者
这个垦定是VPS的问题,不是网络问题。太明显了,这技术客服,有够火兰的。
发表于 2012-5-2 16:34:05 | 只看该作者
我母鸡没内存了……要不早就卖你了……现在就剩下192MB的内存……
发表于 2012-5-2 18:15:00 | 只看该作者
母鸡要重启下看看,然后看下有没内网arp
GMT+8, 2026-5-3 13:44 , Processed in 0.068554 second(s), 12 queries , Gzip On, MemCache On.
