查看: 7068|回复: 12
[Windows VPS] Host1Free 这家是独立IP吗?
发表于 2012-4-29 10:50:53 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Host1Free 这家是独立IP吗?共享IP?
发表于 2012-4-29 10:51:29 | 只看该作者
母鸡了!
 楼主| 发表于 2012-4-29 10:56:11 | 只看该作者
共享IP就木有意义了
发表于 2012-4-29 10:58:03 | 只看该作者
独立IP,
目前注册成功了2个
昨晚又注册了1个,还没有收到第2封信
参与人数 1威望 +1 收起 理由
blu + 1 赞一个!
发表于 2012-4-29 11:01:02 | 只看该作者
内存信息:        已用:74.85M 空闲:53.15M 总共:128M
系统负载:        0.00 0.00 0.07 1/31
已启动:        5天8小时6分钟
发表于 2012-4-29 11:03:26 | 只看该作者
SolusVM 面板
CentOS 5 32bit
CentOS is an Enterprise-class Linux Distribution derived from sources freely provided to the public by a prominent North American Enterprise Linux vendor. CentOS conforms fully with the upstream vendors redistribution policy and aims to be 100% binary compatible. (CentOS mainly changes packages to remove upstream vendor branding and artwork.) CentOS is free.
        CentOS 6 32bit
        Debian 5 32bit
The Debian Project is an association of individuals who have made common cause to create a free operating system. This operating system is called Debian GNU/Linux, or simply Debian for short. Debian systems currently use the Linux kernel. Linux is a completely free piece of software started by Linus Torvalds and supported by thousands of programmers worldwide. Of course, the thing that people want is application software: programs to help them get what they want to do done, from editing documents to running a business to playing games to writing more software. Debian comes with over 20,000 packages (precompiled software that is bundled up in a nice format for easy installation on your machine) - all of it free. It's a bit like a tower. At the base is the kernel. On top of that are all the basic tools. Next is all the software that you run on the computer. At the top of the tower is Debian -- carefully organizing and fitting everything so it all works together.
        Debian 6 32bit
发表于 2012-4-29 11:09:25 | 只看该作者
发表于 2012-4-29 11:16:01 | 只看该作者
Maser 发表于 2012-4-29 11:09
N久前弄过,那不是虚拟空间吗,怎么变VPS了
out man
发表于 2012-4-29 11:21:33 | 只看该作者
RE: Host1Free 这家是独立IP吗?
独立ip
参与人数 1威望 +1 收起 理由
blu + 1 很给力!
发表于 2012-4-29 11:29:41 来自手机 | 只看该作者
GMT+8, 2026-4-13 22:20 , Processed in 0.068378 second(s), 10 queries , Gzip On, MemCache On.
