查看: 1531|回复: 1
[美国VPS] 无聊跑个测试 HostHatch-250G-2T-年付17刀小鸡
发表于 2023-9-7 15:36:14 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
STORAGE VMS
STOR250
CPU Cores
1
Storage
250.00 GB
RAM
512.00 MiB
Bandwidth
2.05 TB
Location
Los Angeles
Speedtest.net (Region: GLOBAL)
Location         Latency     Loss    DL Speed       UP Speed       Server
ISP: HostHatch LLC
Nearest          0.35 ms     N/A     10564.96 Mbps  11963.74 Mbps  Netprotect - Los Angeles, CA
Kochi, IN        262.64 ms   0.0%    1783.74 Mbps   270.68 Mbps    Asianet Broadband - Cochin
Bangalore, IN    237.66 ms   0.0%    1695.16 Mbps   265.37 Mbps    Bharti Airtel Ltd - Bangalore
Chennai, IN      212.95 ms   N/A     1842.74 Mbps   307.59 Mbps    Jio - Chennai
Mumbai, IN       227.75 ms   0.0%    1032.46 Mbps   284.77 Mbps    i3D.net - Mumbai
Delhi, IN        289.61 ms   0.0%    1688.88 Mbps   271.29 Mbps    Tata Teleservices Ltd - New Delhi
Seattle, US      32.29 ms    0.0%    3807.42 Mbps   2140.04 Mbps   Ziply Fiber - Seattle, WA
Los Angeles, US  0.35 ms     0.0%    5997.65 Mbps   7839.78 Mbps   ReliableSite Hosting - Los Angeles, CA
Dallas, US       31.93 ms    0.0%    3245.64 Mbps   2177.74 Mbps   Hivelocity - Dallas, TX
Miami, US        56.78 ms    0.0%    1853.84 Mbps   1183.21 Mbps   AT&T - Miami, FL
New York, US     67.87 ms    0.0%    2769.79 Mbps   1031.27 Mbps   GSL Networks - New York, NY
Toronto, CA      78.40 ms    0.0%    5257.32 Mbps   891.48 Mbps    Rogers - Toronto, ON
London, UK       131.73 ms   0.0%    3062.80 Mbps   508.63 Mbps    VeloxServ Communications - London
Amsterdam, NL    144.32 ms   0.0%    20.11 Mbps     14.29 Mbps     Clouvider Ltd - Amsterdam
Paris, FR        147.76 ms   N/A     2679.71 Mbps   456.27 Mbps    Axione - Paris
Frankfurt, DE    149.40 ms   0.0%    2570.18 Mbps   397.63 Mbps    23M GmbH - Frankfurt am Main
Avg DL Speed       : 3117.03 Mbps
Avg UL Speed       : 1875.24 Mbps
Total DL Data      : 60.82 GB
Total UL Data      : 44.01 GB
Total Data         : 104.83 GB
Duration           : 7 min 47 sec
System Time        : 07/09/2023 - 15:32:38 CST
Total Script Runs  : 22647
Result             : https://result.network-speed.xyz/r/1694071958_B570LI_GLOBAL.txt
版本:2023.08.26
更新日志:VPS融合怪测试(集百家之长)
CPU 型号          : Intel(R) Xeon(R) CPU E5-2680 v2 @ 2.80GHz
CPU 核心数        : 1
CPU 频率          : 2799.998 MHz
CPU 缓存          : L1: 32.00 KB / L2: 256.00 KB / L3: 25.00 MB
硬盘空间          : 1.88 GiB / 227.57 GiB
启动盘路径        : /dev/vda1
内存              : 125.51 MiB / 461.66 MiB
Swap              : 12 KiB / 510.00 MiB
系统在线时间      : 0 days, 6 hour 24 min
负载              : 1.10, 0.59, 0.24
AES-NI指令集      : ✔ Enabled
VM-x/AMD-V支持    : ❌ Disabled
内核              : 6.5.1-bbrplus
TCP加速方式       : bbr
虚拟化架构        : KVM
NAT类型           : 开放型
IPV4 ASN          : AS63473 HostHatch, LLC
IPV4 位置         : Los Angeles / California / US
1 线程测试(1核)得分:                 836 Scores
单线程读测试:                17355.08 MB/s
单线程写测试:                14998.16 MB/s
100MB-4K Block                15.7 MB/s (3833 IOPS, 6.68s)                391 kB/s (95 IOPS, 268.30s)
1GB-1M Block                54.4 MB/s (52 IOPS, 19.29s)                8.6 MB/s (8 IOPS, 121.77s)
Read       | 1.28 MB/s      (322) | 15.66 MB/s     (244)
Write      | 1.32 MB/s      (330) | 16.16 MB/s     (252)
Total      | 2.60 MB/s      (652) | 31.83 MB/s     (496)           |                      |
Read       | 34.80 MB/s      (67) | 34.46 MB/s      (33)
Write      | 37.05 MB/s      (72) | 37.19 MB/s      (36)
Total      | 71.85 MB/s     (139) | 71.65 MB/s      (69)
[IPv4]
NF所识别的IP地域信息:美国
[IPv6]
您的网络可能没有正常配置IPv6,或者没有IPv6网络接入
[IPv4]
当前IPv4出口解锁DisneyPlus
区域:美国区
以下为IPV4网络测试,若无IPV4网络则无输出
Dazn:                                        Unsupport
HotStar:                                No
Disney+:                                No
Netflix:                                Originals Only
有图比 Premium:                        Yes
Amazon Prime Video:                        Yes (Region: US)
TVBAnywhere+:                                Failed
iQyi Oversea Region:                        US
Viu.com:                                No
有图比 CDN:                                Los Angeles, CA
Netflix Preferred CDN:                        Associated with [] in [Dallas, TX ]
Steam Currency:                        USD
以下为IPV6网络测试,若无IPV6网络则无输出
Tiktok Region:                【US】
以下为各数据库编号,输出结果后将自带数据库来源对应的编号
欺诈分数(越低越好): 34②
abuse得分(越低越好): 0④
IP类型:
  使用类型(usage_type):hosting①  Data Center/Web Hosting/Transit⑤  hosting⑧
  公司类型(company_type):hosting①  business⑧
  云服务提供商(cloud_provider):  Yes⑧
  数据中心(datacenter):  No②   Yes⑥ ⑨
  移动网络(mobile):  No⑥
  代理(proxy):  No① ②   Yes⑥ ⑦ ⑧ ⑨ ⑩
  扶墙(扶墙):  No①   Yes② ⑦ ⑧
  TOR(tor):  No① ② ⑦ ⑧ ⑨
  TOR出口(tor_exit):  No⑧
  搜索引擎机器人(search_engine_robot):  No②
  匿名代理(anonymous):  Yes⑦ ⑧   No⑨
  攻击方(attacker):  No⑧ ⑨
  滥用者(abuser):  No⑧ ⑨
  威胁(threat):  No⑧ ⑨
  未分配IP(bogon):  No⑧ ⑨
Google搜索可行性:YES
国家: US 城市: Los Angeles 服务商: AS63473 HostHatch, LLC
北京电信 219.141.136.12  测试超时
上海电信 202.96.209.133  测试超时
广州电信 58.60.188.222   电信163 [普通线路]
成都电信 61.139.2.69     测试超时
成都移动 211.137.96.205  测试超时
2023/09/07 14:39:16 测试完成!
Speedtest.net         10404.21 Mbps         8952.01 Mbps         0.34          NULL
洛杉矶                 6629.68 Mbps         8301.18 Mbps         0.75          0.0%
日本东京         1052.05 Mbps         1387.68 Mbps         98.90          NULL
联通沈阳         3.10 Mbps         130.50 Mbps         184.65          17.4%
联通WuXi         2.64 Mbps         10.88 Mbps         188.67          9.5%
电信Zhenjiang5G         280.98 Mbps         1499.37 Mbps         139.36          NULL
电信合肥5G         263.70 Mbps         671.59 Mbps         153.62          0.7%
移动Chengdu         513.23 Mbps         741.74 Mbps         208.46          0.0%
移动Lanzhou         114.90 Mbps         241.51 Mbps         229.00          NULL
总共花费      : 17 分 17 秒
时间          : Thu Sep  7 14:44:40 CST 2023
  短链:
    http://paste.spiritlhl.net/u/aEi8S6.txt
发表于 2023-9-7 16:08:31 | 只看该作者
有个2年60的HH
GMT+8, 2026-4-27 15:18 , Processed in 0.061009 second(s), 10 queries , Gzip On, MemCache On.
