查看: 1718|回复: 3
[美国VPS] 求助关于内网转发
发表于 2023-8-18 16:57:02 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
有个内网集群01可以上外网比如ping通百度,02是个计算只有内网,能ping通01,我该怎么弄让02也可以ping通百度,来个大佬支个招
看下这个脚本哪里需要改一下
#!/bin/bash
# setup NAT gate service
# Run this on master node,
# Point the default gateway to master IP address on all slave nodes
# All slave nodes can access internet.
# You are happy to run yum -y update, etc.
## LAN, private interface
## LANNET, private network
## WAN, public interface
## set interface name first.
LAN="ens81"
WAN="eno1"
LANNET="10.0.0.0/24"
### Do not edit the following contents.
export LAN WAN LANNET
### Flush the original rules
/sbin/iptables -F
/sbin/iptables -X
/sbin/iptables -Z
/sbin/iptables -F -t nat
/sbin/iptables -X -t nat
/sbin/iptables -Z -t nat
### load modules
modprobe ip_tables         > /dev/null 2>&1
modprobe iptable_nat       > /dev/null 2>&1
modprobe ip_nat_ftp       > /dev/null 2>&1
modprobe ip_nat_irc       > /dev/null 2>&1
modprobe ipt_mark       > /dev/null 2>&1
modprobe ip_conntrack       > /dev/null 2>&1
modprobe ip_conntrack_ftp   > /dev/null 2>&1
modprobe ip_conntrack_irc   > /dev/null 2>&1
modprobe ipt_MASQUERADE   > /dev/null 2>&1
### enable the client to use 扶墙 service
modprobe ip_nat_pptp > /dev/null 2>&1
modprobe ip_nat_proto_gre  > /dev/null 2>&1
modprobe ip_conntrack_pptp  > /dev/null 2>&1
# Set Default Rules
/sbin/iptables -P INPUT        ACCEPT
/sbin/iptables -P OUTPUT  ACCEPT
/sbin/iptables -P FORWARD        ACCEPT
/sbin/iptables -t nat -P PREROUTING  ACCEPT
/sbin/iptables -t nat -P POSTROUTING ACCEPT
/sbin/iptables -t nat -P OUTPUT      ACCEPT
### Accept ping test
iptables -A INPUT -p icmp --icmp-type echo-request -j ACCEPT
iptables -A OUTPUT -p icmp --icmp-type echo-reply -j ACCEPT
### For NAT Gateway
# Starting NAT Server
echo "1" > /proc/sys/net/ipv4/ip_forward
# Stop NAT immediately
#echo "0" > /proc/sys/net/ipv4/ip_forward
# POSTROUTE  NAT Client
/sbin/iptables -t nat -A POSTROUTING -s $LANNET -o $WAN -j MASQUERADE
# the following two lines Enable iptables work in High Efficiency
/sbin/iptables -A FORWARD -m state --state ESTABLISHED,RELATED -j ACCEPT
# 5 may be useful for some sites,
#        configure the MTU value.
iptables -A FORWARD -p tcp -m tcp --tcp-flags SYN,RST SYN -m tcpmss \
          --mss 1400:1536 -j TCPMSS --clamp-mss-to-pmtu
 楼主| 发表于 2023-8-18 17:05:16 | 只看该作者
 楼主| 发表于 2023-8-18 17:18:29 | 只看该作者
GMT+8, 2026-4-14 05:51 , Processed in 0.056420 second(s), 9 queries , Gzip On, MemCache On.
