查看: 4651|回复: 7
HYTRON评测+八折优惠活动
发表于 2023-8-15 23:30:50 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
评测的是hytron 老1刀鸡,流媒体解锁不错 适合当落地(部分IP段可能不解锁!!!)
八折优惠码:AJWP7462TP
$16.80 USD
2 vCPU
1024MB RAM
5G SSD Storage
5000 GB Transfer (IN & OUT)
5Gbps VirtIO Interface
1 IPv4
https://idc.hytron.io/aff.php?aff=86&pid=6
$20.16 USD
二年繳
1 vCPU
512MB RAM
5G SSD Storage
3000 GB Transfer (IN & OUT)
1 IPv4
https://idc.hytron.io/aff.php?aff=86&pid=10
欢迎关注补货监控:
https://t.me/hytron1
YABS:
#              Yet-Another-Bench-Script              #
#                     v2023-04-23                    #
# https://github.com/masonr/yet-another-bench-script #
Tue 15 Aug 2023 11:20:32 AM EDT
Basic System Information:
Uptime     : 71 days, 2 hours, 0 minutes
Processor  : Common KVM processor
CPU cores  : 1 @ 2394.454 MHz
AES-NI     : ❌ Disabled
VM-x/AMD-V : ❌ Disabled
RAM        : 483.3 MiB
Swap       : 0.0 KiB
Disk       : 9.8 GiB
Distro     : Debian GNU/Linux 10 (buster)
Kernel     : 4.19.0-5-amd64
VM Type    : KVM
IPv4/IPv6  : ✔ Online / ❌ Offline
IPv4 Network Information:
ISP        : Hytron Network Services Limited
ASN        : AS202662 Hytron Network Services Limited
Host       : Hytron Network Services Limited
Country    : Hong Kong
fio Disk Speed Tests (Mixed R/W 50/50):
Read       | 154.71 MB/s  (38.6k) | 1.19 GB/s    (18.6k)
Write      | 155.12 MB/s  (38.7k) | 1.20 GB/s    (18.7k)
Total      | 309.83 MB/s  (77.4k) | 2.39 GB/s    (37.4k)
Read       | 1.24 GB/s     (2.4k) | 1.29 GB/s     (1.2k)
Write      | 1.31 GB/s     (2.5k) | 1.37 GB/s     (1.3k)
Total      | 2.55 GB/s     (4.9k) | 2.66 GB/s     (2.6k)
Provider        | Location (Link)           | Send Speed      | Recv Speed      | Ping
Clouvider       | London, UK (10G)          | 20.6 Mbits/sec  | 27.8 Mbits/sec  | 190 ms
Scaleway        | Paris, FR (10G)           | busy            | busy            | 195 ms
NovoServe       | North Holland, NL (40G)   | 534 Mbits/sec   | 510 Mbits/sec   | 186 ms
Uztelecom       | Tashkent, UZ (10G)        | 551 Mbits/sec   | 216 Mbits/sec   | 187 ms
Clouvider       | NYC, NY, US (10G)         | 482 Mbits/sec   | 38.9 Mbits/sec  | 191 ms
Clouvider       | Dallas, TX, US (10G)      | 554 Mbits/sec   | 221 Mbits/sec   | 181 ms
Clouvider       | Los Angeles, CA, US (10G) | 617 Mbits/sec   | 319 Mbits/sec   | 163 ms
Geekbench test failed and low memory was detected. Add at least 1GB of SWAP or use GB4 instead (higher compatibility with low memory systems).
YABS completed in 4 min 38 sec
流媒体测试:
** 正在测试IPv4解锁情况
** 您的网络为: Hytron Network Services Limited (38.150.*.*)
Dazn:                                  No
HotStar:                               No
Disney+:                               Yes (Region: HK)
Netflix:                               Yes (Region: HK)
有图比 Premium:                       Yes (Region: HK)
Amazon Prime Video:                    Yes (Region: HK)
TVBAnywhere+:                          No
iQyi Oversea Region:                   HK
Viu.com:                               Yes (Region: HK)
有图比 CDN:                           Hong Kong
Netflix Preferred CDN:                 Hong Kong
Spotify Registration:                  Yes (Region: HK)
Steam Currency:                        HKD
=============[ Hong Kong ]=============
Now E:                                 Failed (Unexpected Result: )
Viu.TV:                                Yes
MyTVSuper:                             No
HBO GO Asia:                           Yes (Region: HK)
BiliBili Hongkong/Macau/Taiwan:        Yes
当前主机不支持IPv6,跳过...
本次测试已结束,感谢使用此脚本
发表于 2023-8-16 00:51:00 | 只看该作者
一键增加Swap脚本,测下GB5有几百
  1. wget https://raw.githubusercontent.com/ChellyL/swap_change/main/swap.sh && bash swap.sh
发表于 2023-8-16 01:05:58 | 只看该作者
用官方 dns 10.10.10.10 就可以做到ip段都解锁~
发表于 2023-8-16 02:04:08 | 只看该作者
流量跑的嗖嗖的!感觉流量是翻着倍跑。同样5T流量recloud比他多用十来天
发表于 2023-8-16 09:21:58 | 只看该作者
两年的折后16刀。。。有点想剁手了
发表于 2023-8-16 09:26:54 | 只看该作者
danielzi 发表于 2023-8-16 09:21
两年的折后16刀。。。有点想剁手了
落地可以,但转念想想要加个中转,有点亏
并且老版10刀硬盘10g,灵活太多
发表于 2023-8-16 13:52:03 | 只看该作者
落地还行啊,nnr拉也不贵
发表于 2023-8-16 19:33:24 | 只看该作者
那个文件?可以给下路径不!
GMT+8, 2026-5-8 09:38 , Processed in 0.062073 second(s), 10 queries , Gzip On, MemCache On.
