查看: 4662|回复: 14
[美国VPS] 买了一台contabo VPS的评测
发表于 2023-8-14 22:34:49 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
VPS L NVMe  8 cores 30GB 400 GB (100% NVMe)
Superbench.sh -- https://www.oldking.net/350.html
Mode  : Standard    Version : 1.1.7
Usage : wget -qO- sb.oldking.net | bash
CPU Model            : AMD EPYC 7282 16-Core Processor
CPU Cores            : 8 Cores 2794.748 MHz x86_64
CPU Cache            : 512 KB
OS                   : Ubuntu 20.04.6 LTS (64 Bit) KVM
Kernel               : 5.4.0-105-generic
Total Space          : 2.9 GB / 393.0 GB
Total RAM            : 115 MB / 30096 MB (502 MB Buff)
Total SWAP           : 0 MB / 0 MB
Uptime               : 0 days 4 hour 27 min
Load Average         : 0.07, 0.02, 0.00
TCP CC               : cubic
ASN & ISP            : AS40021, Nubes, LLC
Organization         : Contabo Inc
Region               : Missouri
I/O Speed( 1.0GB )   : 698 MB/s
I/O Speed( 1.0GB )   : 1.1 GB/s
Average I/O Speed    : 983.6 MB/s
Speedtest.net    568.09 Mbit/s     580.85 Mbit/s       7.09 ms
Fast.com         0.00 Mbit/s       130.7 Mbit/s        -
Nanjing 5G   CT  386.67 Mbit/s     561.80 Mbit/s       220.83 ms
Shanghai 5G  CU  412.70 Mbit/s     570.01 Mbit/s       209.93 ms
Finished in  : 1 min 48 sec
Timestamp    : 2023-08-14 22:28:42 GMT+8
Results      : ./superbench.log
Benchmark started on 14-Aug-2023 09:30:34
## System Information
OS Name     : Ubuntu 20.04.6 LTS (64 bit)
Kernel      : KVM / 5.4.0-105-generic
Hostname    : vmi1398899.contaboserver.net
CPU Cores   : 8 cores @  2794.748 MHz
CPU Cache   : 512 KB
Total RAM   : 30096 MiB (Free 29600 MiB)
Total SWAP  : SWAP not enabled
Total Space : 408GB (1% used)
Running for : 4hrs 31min 21sec
## CDN Speedtest
CacheFly :  61.58 MiB/s |  492.61 Mbps  | ping  13.427ms
Gdrive   :  40.29 MiB/s |  322.32 Mbps  | ping   6.996ms
## North America Speedtest
Softlayer, Washington, USA :  42.36 MiB/s |  338.89 Mbps  | ping  23.335ms
SoftLayer, San Jose, USA   :  25.55 MiB/s |  204.37 Mbps  | ping  55.139ms
SoftLayer, Dallas, USA     :       0 B/s |      N/A       | ping error!
Vultr, New Jersey, USA     :  13.63 MiB/s |  109.04 Mbps  | ping  31.282ms
Vultr, Seattle, USA        :  44.40 MiB/s |  355.24 Mbps  | ping  51.660ms
Vultr, Dallas, USA         :  56.92 MiB/s |  455.32 Mbps  | ping  22.971ms
Vultr, Los Angeles, USA    :  40.49 MiB/s |  323.89 Mbps  | ping  52.085ms
Ramnode, New York, USA     :  53.46 MiB/s |  427.66 Mbps  | ping  22.668ms
Ramnode, Atlanta, USA      :  54.16 MiB/s |  433.24 Mbps  | ping  26.183ms
OVH, Beauharnois, Canada   :ping: bhs.proof.ovh.net: Name or service not known
## Europe Speedtest
Vultr, London, UK            :  22.96 MiB/s |  183.70 Mbps  | ping  97.496ms
LeaseWeb, Frankfurt, Germany :  25.22 KiB/s |    0.20 Mbps  | ping 109.194ms
Hetzner, Germany             :   4.88 MiB/s |   39.01 Mbps  | ping 112.474ms
Ramnode, Alblasserdam, NL    :  23.55 MiB/s |  188.43 Mbps  | ping  96.432ms
Vultr, Amsterdam, NL         :  21.63 MiB/s |  173.06 Mbps  | ping 102.495ms
EDIS, Stockholm, Sweden      :     418 B/s |      N/A       | ping 118.465ms
OVH, Roubaix, France         :     326 B/s |      N/A       | ping 126.547ms
Online, France               :  21.22 MiB/s |  169.79 Mbps  | ping  98.744ms
Prometeus, Milan, Italy      :      41 B/s |      N/A       | ping 116.473ms
## Exotic Speedtest
Sydney, Australia     :   8.17 MiB/s |   65.33 Mbps  | ping 198.776ms
Lagoon, New Caledonia :     171 B/s |      N/A       | ping 208.747ms
Hosteasy, Moldova     :   8.55 MiB/s |   68.42 Mbps  | ping 154.299ms
Prima, Argentina      : 515.84 KiB/s |    4.03 Mbps  | ping error!
## Asia Speedtest
SoftLayer, Singapore : 359.92 KiB/s |    2.81 Mbps  | ping 230.103ms
Linode, Tokyo, Japan :   7.68 MiB/s |   61.47 Mbps  | ping 140.431ms
Linode, Singapore    :   4.95 MiB/s |   39.58 Mbps  | ping 249.970ms
Vultr, Tokyo, Japan  :  14.40 MiB/s |  115.22 Mbps  | ping 127.915ms
## IO Test
CPU Speed:
    bzip2 512MB -  98.8 MB/s
   sha256 512MB -   179 MB/s
   md5sum 512MB -   416 MB/s
Disk Speed (512MB):
   I/O Speed  - 737 MB/s
   I/O Direct - 381 MB/s
RAM Speed (1024MB):
   Avg. write - 2457.6 MB/s
   Avg. read  - 7884.8 MB/s
Benchmark finished in 114 seconds
   results saved on /root/bench.log
大家觉得如何?主要放图片。
发表于 2023-8-14 22:42:10 | 只看该作者
十核不如我单核
发表于 2023-8-14 22:40:10 | 只看该作者
这家超兽怪。不如netcup,再好点hetzner
发表于 2023-8-14 23:14:16 来自手机 | 只看该作者
超售小王子
发表于 2023-8-14 23:17:12 来自手机 | 只看该作者
建议netcup,直接秒成灰。
 楼主| 发表于 2023-8-15 09:11:20 | 只看该作者
v2w3.com 发表于 2023-8-14 23:17
建议netcup,直接秒成灰。
好的,netcup有美国机房吗?主要面向用户在美国。
如果没有的话,用netcup,有没有啥好的解决美国用户的延迟。
 楼主| 发表于 2023-8-15 09:13:09 | 只看该作者
这么夸张的吗。,你用的哪家?
发表于 2023-8-15 09:18:33 | 只看该作者
我是c罗 发表于 2023-8-15 09:13
这么夸张的吗。,你用的哪家?
只能说contabo太差
发表于 2023-8-15 09:22:57 | 只看该作者
跑个YABS看看。
  1. curl -sL yabs.sh | bash -s -- -5
GMT+8, 2026-4-23 22:05 , Processed in 0.062718 second(s), 11 queries , Gzip On, MemCache On.
